Is the BU40N still the best overall choice?
Mucio
Re: Is the BU40N still the best overall choice?
Please note that the LG HLDS BU40N.ARAA10B plug-in USB-C port can be moved to the USB-C port. Please note that only 1 meter of cable can be used on the PC computer. From the 1-meter USB C cable to the USB C cable, the LG HLDS BU40N.ARAA10B can be connected to the PC and cannot be used for UHD 4K films. Please note that the cable from the LG HLDS BU40N.ARAA10B must be turned on but the cable must be 15 centymeters away from the normal cable. Please note that the USB C type cable must be operated with maximum power, without the power of the 4K UHD player being available.
Sayaka
I am having trouble understanding this post, and I am unlikely to be the only one (and I am also wondering whether it was created with the help of an AI translation tool). Could you please rephrase this ?Mucio wrote: Sun Jun 07, 2026 11:41 am Please note that the LG HLDS BU40N.ARAA10B plug-in USB-C port can be moved to the USB-C port. Please note that only 1 meter of cable can be used on the PC computer. From the 1-meter USB C cable to the USB C cable, the LG HLDS BU40N.ARAA10B can be connected to the PC and cannot be used for UHD 4K films. Please note that the cable from the LG HLDS BU40N.ARAA10B must be turned on but the cable must be 15 centymeters away from the normal cable. Please note that the USB C type cable must be operated with maximum power, without the power of the 4K UHD player being available.
AI babble bullshit.Sayaka wrote: Sun Jun 07, 2026 9:07 pmI am having trouble understanding this post, and I am unlikely to be the only one (and I am also wondering whether it was created with the help of an AI translation tool). Could you please rephrase this ?Mucio wrote: Sun Jun 07, 2026 11:41 am Please note that the LG HLDS BU40N.ARAA10B plug-in USB-C port can be moved to the USB-C port. Please note that only 1 meter of cable can be used on the PC computer. From the 1-meter USB C cable to the USB C cable, the LG HLDS BU40N.ARAA10B can be connected to the PC and cannot be used for UHD 4K films. Please note that the cable from the LG HLDS BU40N.ARAA10B must be turned on but the cable must be 15 centymeters away from the normal cable. Please note that the USB C type cable must be operated with maximum power, without the power of the 4K UHD player being available.
Mucio
Sorry, Google Translate messed it up for me too. What I mean is that the USB-C cable should not be longer than one meter, as this can cause power issues with the LG HLDS BU40N.ARAA10B Drive.
Mucio
Tell me how to convert Dolby Atmos audio in TrueHD format to E-AC-3 audio from Dolby Amos so that the player in HISENSE C1 4K (3840 x 2160) does not block the Atmos audio?
Mucio
Problem solved. I connected my computer via HDMI 2.1 through a home theater receiver, and then to the HISENSE C1 4K. The receiver took over the sound, and the HISENSE C1 4K took over the image. The sound is in Dolby Atmos and DTS:X.
babayaga
I have no clue why you didn't use the receiver from the start - also there are many forums better aimed for discussing projectors and receivers than a forum for a software made for ripping optical discs =)Mucio wrote: Tue Jun 09, 2026 10:19 am Problem solved. I connected my computer via HDMI 2.1 through a home theater receiver, and then to the HISENSE C1 4K. The receiver took over the sound, and the HISENSE C1 4K took over the image. The sound is in Dolby Atmos and DTS:X.![]()
Mucio
You should use your mind and then you will understand.
babayaga
With your feet in the air and your head on the ground
Try this trick and spin it, (Yeah) yeah
Your head will collapse, if there's nothing in it
And you'll ask yourself...
HSH1979
hello, i found a BU40N at a reasonable price, not like those sold at a crazy price on the forum here, can i use it directly to rip 4k UHD disks?
yes see guide belowHSH1979 wrote: Mon Sep 14, 2026 2:28 pm hello, i found a BU40N at a reasonable price, not like those sold at a crazy price on the forum here, can i use it directly to rip 4k UHD disks?
or email me or marty for an automated flasher
see below for email
HSH1979
are the flashers free? i would like to avoid paying for this stuff
The guide is free personal help is paidHSH1979 wrote: Mon Sep 14, 2026 4:30 pm are the flashers free? i would like to avoid paying for this stuff
first_name
Hi all,
Alright, so LG and Pioneer are no longer manufacturing optical drives.
Since I have a mini PC, I need an external USB drive.
Getting a LG BU40N is hard to get in my region and if so it would be pricey.
What would be a solid drive for UHD, nothing fancy, since it would be used occasionally.
What about the ASUS BW-16D1HT?
Which external enclosure should I use?
The ASUS BW-16D1HT was discontinued about 2-3 years ago and is just a rebadged LG WH16NS40 anyway. If you see any, they are likely the fake versions from China.first_name wrote: Tue Sep 22, 2026 9:42 pm Hi all,
About the only drives available are the BU40N (Verbatim, Buffalo and ASUS SBW-06D5H-U) and the Buffalo media station (5.25" drive in an enclosure).
You could also check the seller threads here and see if they can ship a drive to you.
