I recently have been trying to rip some DVDs for probably the first time in over a decade, so please forgive my ignorance. These are old DVDs of local events, not studio releases or something.
Several of them have ripped just fine, but a few of them seem to stall at some point and start throwing errors. I've tried cleaning the discs with a moist microfiber. They generally appear in good condition to the eye. Despite being probably 10-15 years old, they've probably only been taken out of their case a small handful of times.
I've attached two debug logs: the first was something I've noticed a few times where after trying and failing to rip the DVD, it will then throw an error when I try to reopen it. That's probably less helpful—the second attachment is the full debug log from just trying to rip one of the discs. I've tried increasing the read retry count and have tried two different drives.
Would greatly appreciate any help.
Read Errors
stature107
Read Errors
- MakeMKV_log_2_redacted.txt
- (32.23 KiB) Downloaded 241 times
- MakeMKV_log_1_redacted.txt
- (2.2 KiB) Downloaded 234 times
Re: Read Errors
What happens if you try to make a decrypted backup of the disc? On the first screen of MakeMKV click the icon of the green arrow and the yellow folder and make sure the decrypt checkbox is checked.
Doing a backup of a disc will read the entire disc and in the case of a DVD output the contents to an .iso file. You can then open that .iso file with MakeMKV and attempt to create .mkv files from it.
You can think of MakeMKV as trying to do two things. One is read a disc and the other is interpret the contents to be able to discern individual titles on a disc. By doing the backup step, MakeMKV is only trying to read the disc and not trying to interpret the contents. That'll happen when you open the resulting .iso file in MakeMKV.
stature107
Re: Read Errors
Thanks for your help! Just tried this. Like before, it ran normally for a while before slowing down to a crawl without any errors for some time. Now this is what it looks like after "crawling" for about an hour or so.
tomty89
Re: Read Errors
If by "old DVD of local events" you really mean some DVD+/-R, it's probably not very surprising that disc rot has occured to it. In that case you might want to use ddrescue or alike to salvage what can possibly be from the disc.
Re: Read Errors
Those errors mean there's a spot on that the disc that was unable to be read correctly.
As tomty89 suggests, ddrescue might help.
stature107
Re: Read Errors
That's very possible. I don't know much about them, but these were probably made by a fairly small business that filmed local theater productions and such. Will look into ddrescue, thanks alltomty89 wrote: Mon Jun 08, 2026 2:09 am If by "old DVD of local events" you really mean some DVD+/-R, it's probably not very surprising that disc rot has occured to it. In that case you might want to use ddrescue or alike to salvage what can possibly be from the disc.
