Pioneer bdr 209 and Pioneer bdr 209m
Re: Pioneer bdr 209 and Pioneer bdr 209m
BlamWungus wrote: Sat Jun 06, 2026 6:34 pm Hi! I've been lurking for a while in the hopes I would eventually get a flashable drive. I snatched this one without really thinking. Hope it's flashable.
Manufacturer: PIONEER
Product: BD-RW BDR-209D
Revision: 1.20
Serial number:
Firmware date: 2014-04-08
Bus encryption flags: 13
Highest AACS version: 16
Drive platform: RS8600
Firmware version: 1.20/ID61
PM sent.
morbius
Post by morbius »
I too have a BDR-209D, interested to know if UHD functionality can be unlocked. Drive is currently in a linux box but can easily be moved to a Windows PC for flashing. Thanks in advance.
morbius wrote: Sat Jun 27, 2026 2:39 pm I too have a BDR-209D, interested to know if UHD functionality can be unlocked. Drive is currently in a linux box but can easily be moved to a Windows PC for flashing. Thanks in advance.
Sure email me that drive info section see below for email
PM sent.
sergeron
Post by sergeron »
Can't sent PM first, but this is my drive info. Is it flashable?
OS device name: F:
Revision: 1.33
Serial number:
Firmware date: 2015-12-09
Highest AACS version: 81
Firmware version: 1.33/ID81
sergeron wrote: Tue Jun 30, 2026 9:00 am Can't sent PM first, but this is my drive info. Is it flashable?
OS device name: F:
Revision: 1.33
Serial number:
Yes. PM sent.
OS device name: F:
Revision: 1.33
Serial number:
Email me that drive info section see below for email
Dragonnova
Post by Dragonnova »
I just bought an BDR 209 and Flash it to UHD compatible. But since i bought it the drive has an issue with the opening mechanism the flashing dont help. Sometimes it opens and sometimes it wouldnt. Closing with the button works most times. Opening with the manual eject hole works everytime. How could I fix this problem?
Dragonnova wrote: Thu Jul 09, 2026 4:00 pm I just bought an BDR 209 and Flash it to UHD compatible. But since i bought it the drive has an issue with the opening mechanism the flashing dont help. Sometimes it opens and sometimes it wouldnt. Closing with the button works most times. Opening with the manual eject hole works everytime. How could I fix this problem?
Probably needs a new belt
OneDay
Post by OneDay »
I just bought a 209D with the same problem. It ended up being the the seal around the face plate. It get bent and the sticky stuff would hold the face plate to the drive so it could not open. Any way I removed all of it around the faceplate and have not had any issues since. I guess this seal was not made very good on the earlier drives. Hope this help.
Take a look. The top is with the seal removed and the bottom with the seal.
https://drive.google.com/file/d/1LV3ihw ... sp=sharing
inheavens
Post by inheavens »
Shinn2001 wrote: Fri Aug 15, 2025 7:18 pm NVM I just got the flasher and firmware from somebody else
Hello! I recently got my hands on a BDR-209DBK too. I was wondering if you could share your flasher and firmware with me? I'd really appreciate it!
inheavens
Post by inheavens »
Coopervid wrote: Sun Jun 28, 2026 6:35 pm
PM sent.
I recently picked up a BDR-209BK. The seller had already cross-flashed it to a BDR-211M, but I am looking to flash it to an S11. Would it be possible for you to share the flasher tool and the necessary firmware?
My optical drive information is as follows:
OS device name: L:
Product: BD-RW BDR-211M
Revision: 1.53
Serial number: MIDL001548WL
Firmware date: 2020-08-03
Drive platform: RS8800
Firmware name: PIONEER BDR-211
Firmware version: 1.53/ID60
inheavens wrote: Sun Jul 12, 2026 11:28 am
PM sent.
OS device name: L:
Revision: 1.53
PM sent.
inheavens wrote: Sun Jul 12, 2026 11:18 am
Sure email me your makemkv drive info section see below for email
MelonIon
Post by MelonIon »
hey, i got a bdr-209m on a tri-boot mac pro 5,1.
the drive works well and plays blu-rays (not uhds) efficiently on both
macos with the macgo bluray player and win10 with the makemkv+vlc workaround,
however, i havent managed to make it work on ubuntu.
was wondering of the functionalities gained by flashing the drive with your fw packages
and if it would retain full compatibility with the oses (id appreciate some help with the ubuntu situation)
and finally, your recommendations regarding bluray/uhd player/bdxl burner apps for all oses.
thanks!
_ :mrgreen: _
