MrMegadeth99
Re: SDFtool Flasher
My drive is actually WP50NB40 but the instructions say for WP/BP. It shouldn't matter right?
Mr_Orange
Re: SDFtool Flasher
You should be doing this:MrMegadeth99 wrote: Wed Apr 22, 2026 5:02 pm My drive is actually WP50NB40 but the instructions say for WP/BP. It shouldn't matter right?
WP/BP50NB40 to > BP50NB40-NB50-1.03MK then to > BP60NB10 1.02MK or 1.00MK
MrMegadeth99
Re: SDFtool Flasher
I did that but when I flashed to 1.00 my drive wouldn't even read blu ray or 4K. I got it to read blu ray again when flashed back to 1.01. You think I should try flashing to 1.02?
Dexeltin
Re: SDFtool Flasher
Hi everyone! I ran into the same issue as Lazarus. The solution is straightforward—just download the latest version of MakeMKV and install it with administrator permissions. That fixed the problem for me.Lazarus wrote: Thu Sep 21, 2023 11:57 pm Hello
I have an LG WH16NS40 drive (rev 1.05), version 1.17.4 of MakeMKV installed. I am trying to run SFDtool Flasher and I get a Microsoft .NET error of Unhandled exception. If I continue past the error the app loads but the select drive box is blank. MakeMKV sees the drive correctly as a MT1959 platform. I am running Windows 11. Is the error because of Win11?
I spent almost two hours getting it to work, and I can confirm the issue (and the fix) applies to both Windows 10 and Windows 11.
Comet19
Re: SDFtool Flasher_ MT1959 cannot be flashed
Hello Goodmorning,
I have tried to flash by LG Internal BD Re writer WH16NS40 1.00 K9F21131409
but getting error message "the drive you have selected does not have the correct platform (MT1959) and cannot be flashed
i have tried with stand alone file "DE_LG_WH16NS40_1.01.bin.zip" but still getting same error messsage
i have attached screenshot Pl check is there any way to make it workable for my drive
thanks
selvam
thanks
selvam
Sayaka
Re: SDFtool Flasher
From the flashing guide :
Next time you attempt to flash an LG drive, please be sure to read *all* of Billycar11's guide, not just the first post in the SDFtool Flasher thread
: viewtopic.php?f=16&t=19634
The screenshot you posted shows that your drive platform is MT1939. I believe you most certainly shouldn't attempt to flash it.1. Make sure your Drive was built after 2016 on label or late 2015 if you want to risk it.
2. Drive Platform MT1959<Most important in makemkv
3. SVC NS50+ LG only on label for NB drives NB50+
4. Just because your drive is the same model number does not mean it will work, if you are unsure ask me i offer remote flashing and check everything before i flash.
5. Dont flash your dive if it does not meet these requirements if you do you will be unable to read all disks and unable to restore without dosflash that does not work on most modern computers
If someday you should get another LG WH16NS40, one that's actually "flashable" (because seriously, do *not* attempt to flash your current drive), I should point out that this wasn't even the correct firmware file, as far as I know. Again, please see Billy's guide above.i have tried with stand alone file "DE_LG_WH16NS40_1.01.bin.zip" but still getting same error messsage
This drive is too old (pre 2016) and has the old, incompatible MT1939 drive platform. It can never be flashed nor be made UHD capable. Don't even try, you WILL brick it!!Comet19 wrote: Sun May 17, 2026 7:57 am Hello Goodmorning,
i have attached screenshotScreenshot 2026-05-17 131239.pngScreenshot 2026-05-17 131222.pngimage_2026-05-17_132605158.png
thanks
selvam
SDFtool flasher did it's job and advised you that it is the wrong drive platform and cannot be flashed.
nostalgicdave
Re: SDFtool Flasher
Thank you Marty for all your help here! I have downloaded the SDFtool Flasher v1.3.6, but it isn't displaying correctly, so I'm not sure if I should try to proceed with flashing my BH16NS58 (inside Buffalo enclosure). Here's what I see... I can't see the green checkmarks. Hopefully it's OK? I previously had text scaling at 150% in Windows 11, but I put it back to default after seeing this problem, but it didn't make a difference. Sorry, I would have sent this to you in a private message, but I'm a new member and I don't see any link/button.
EDIT: I found the answer after I re-read the instructions in the first post. Sorry, my bad!
"NOTE: If the GUI looks a bit deformed (happens on a 4k monitor), you can right click the exe and select properties. In the compatibility tab, click "Change high DPI settings" then under "High DPI scaling override" tick the box and select "System (Enhanced)" in the dropbox."
DemLep
Re: SDFtool Flasher
EDIT: Nevermind. After doing testing and some research, I found even though my drive is marked with a new date it has the MT1939 drive platform. Also, it has the original firmware. So I'm going to return it and hope I can get a drive that is actually newer.
So I bought a ASUS BW-16D1HT about a week ago after seeing it recommended for its price to performance and being able to read 4K UHD disc. It is dated on the drive to 2026 March 09. However, it does not recognize my 4K disc of Ghost in the Shell (I have not test other UHDs) and when I run the flasher it says it is not MT1959 platform. The drive should have version 3.0 of the firmware.
Just posting hear if there is anything I can do before I return the drive. I know this is an issue with older drives, has anyone had this problem with newer drives? The product page didn't say anything about the chipset that is used (not surprising), but does mention that the drive should play UHDs and is suppose to come with some UHD software that I don't seam to have gotten the code for.
DemLep
Re: SDFtool Flasher
I keep getting cloudflare timeouts when trying to edit my post so trying to just put another post.
I had some more time to do some further testing and get more information and it contradicts some of the stuff in my last post.
Also, no idea what is up with the firmware date.
So it looks like the seller lied about updating the drives to firmware version 3.0. But more confusingly this says it is drive platform MT1959 even though the flasher says it is not.Drive Information
OS device name: A:
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 1.01
Serial number: 309HF000565
Firmware date: 2113-02-05 19:30
Bus encryption flags: 1F
Highest AACS version: 78
Drive platform: MT1939
Firmware version: 1.01
BD raw metadata read: Partial
tomty89
Re: SDFtool Flasher
It doesn't matter. If you want UHD support you need MT1959 (although AFAIK there's no 3.xx firmware for MT1939 either).DemLep wrote: Sat May 30, 2026 2:14 am So it looks like the seller lied about updating the drives to firmware version 3.0.
What are you referring to by "this"? Coz the LibreDrive Information you quoted has "Drive platform: MT1939".
It's normal. Most if not all firmware of "LG drives" does not bear a real date. (Maybe it can be derived to a real date in some way but at least not real in its literal form.)
Btw if you want to avoid more failed attempts in getting an MT1959 one, you may want to try confirming whether what you get would have "flat top with four dimples" instead of a "circular top". The latter is at least much less likely to be one.
Comet19
Re: SDFtool Flasher
Thanks All for your replies
i remember that i bought in 2011 or 2013 this BD drive
i will not try any more this bd drive for flashing
and i look forward for your help with the model number of LG BD drive the latest, that can work with flashing
so that i can try to rip my old BD s to file
thanks again for your replies
Selvam
Selvam
75th Trombone
Re: SDFtool Flasher
A few weeks ago, I successfully flashed an LG BP50NB40 with service code NB52. I just got another BP50NB40 with service code NB50 that came from overseas. (I plan to donate one of these when I'm done dumping my personal collection.) But this time, SDFtool Flasher produces an error when I select the drive from the dropdown:
No other optical drive is plugged in currently. One thing possibly of note is that the sticker says "ROM ver: LB20", whereas the one I flashed successfully says "ROM ver: 1.03"; If SDFtool is expecting that ROM version to be strictly numeric that might explain the error. Hopefully this doesn't mean I'm entirely out of luck with this drive. Thanks in advance for your time.System.FormatException: Input string was not in a correct format.
at System.Number.ThrowOverflowOrFormatException(ParsingStatus status, TypeCode type)
at System.Int32.Parse(String s)
at SDFtool_Flasher_Updated.Form1.comboBox_DriveList_SelectedIndexChanged(Object sender, EventArgs e)
at System.Windows.Forms.ComboBox.OnSelectedIndexChanged(EventArgs e)
75th Trombone
Re: SDFtool Flasher
Disregard the above. The device I received (from a Newegg seller) is counterfeit.
sushi714
Re: SDFtool Flasher
Glad I came across this post -- I have a feeling I ordered from the same 3rd party seller that shipped out of China (RIGX). Thought I was going crazy encountering the error with SDFtool and tried flashing via Powershell and even via Mac terminal since MakeMKV kept showing LibreDrive status enabled, but I encountered the same issue trying to use SDFtool and, regardless of how many times or what firmware I flashed, all the info in MakeMKV looked the same after each attempt.75th Trombone wrote: Thu Jun 11, 2026 9:23 pm Disregard the above. The device I received (from a Newegg seller) is counterfeit.
Luckily I snagged the same model drive from Best Buy that's arriving soon -- showed as being a sold/shipped by them and not a 3rd party seller, so fingers crossed that one works, since I bought a few used UHD titles that apparently are 100GB UHDs that my Series X isn't able to read and just need to confirm they're actually UHDs and not counterfit lol
