Public KeyDB Disc Submissions
sergio31
Post by sergio31 » Fri Jun 05, 2026 9:37 am
Yes, I put the latest key into .MakeMKV directory.
And I still can not open disk :
Liersi
Post by Liersi » Fri Jun 05, 2026 10:58 am
Disc type: UHD
Disc dump filename: MKB20_v82_LE_DEUXIEME_SOUFFLE_9D2A
Drive: WH16NS60
Drive firmware: 1.03
LibreDrive status: Enabled
MKB_RO.inf link: https://mega.nz/file/FwsDRSbA#l4WdsAlpa ... cSaHJzhd4Q
Disc dump link: https://mega.nz/file/5hVQxKwT#TrFiIRRs6 ... 0GPFgdN6B0
keydb_helper
Post by keydb_helper » Fri Jun 05, 2026 1:11 pm
sergio31 wrote: Fri Jun 05, 2026 9:37 am Yes, I put the latest key into .MakeMKV directory.
The DB6C variant of Avatar: Fire and Ash has definitely been supported by the public keydb since May 31:
0x2D200C475AC62A53153F8E875203BB4E1D56725F = AVATAR_FIRE_AND_ASH (Avatar: Fire and Ash) | D | 0000-00-00 | M | 0x6D7C<Redacted> | I | 0xF59B<Redacted> | V | 0x4D0A<Redacted> | U | 1-0x6EC7<Redacted> ; MKBv82/BEE (UHD)
Once you place the keydb.cfg file in the correct location you'll be good to go.
It is important to remember the ".MakeMKV directory" is the default path to place the extracted keydb.cfg file. But if you have changed the location of the MakeMKV data directory you should be placing the extracted keydb.cfg file in whichever directory MakeMKV initially stored your local "MKB20_v82_Avatar-_Fire_and_Ash_DB6C.tgz" file.
Liersi wrote: Fri Jun 05, 2026 10:58 am Disc type: UHD
Thanks Liersi, your disc has been added to the public keydb.
chrominance
Post by chrominance » Fri Jun 05, 2026 2:01 pm
Second disc in as many weeks that seems like not a recent release and yet isn't in the public keydb, which makes me worried that the problem is actually on my end, but just in case:
Disc type: UHD
Disc ID: 4CCA81B810DED14859573AB43F6CCA67C3DECD7E
Disc dump filename: MKB20_v77_DECISION_TO_LEAVE_DF15.tgz
Drive: HL-DT-ST BD-RE BU40N
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://drive.google.com/file/d/1BymkC2 ... drive_link
Disc dump link: https://drive.google.com/file/d/1Mw4USY ... sp=sharing
keydb_helper
Post by keydb_helper » Fri Jun 05, 2026 4:15 pm
chrominance wrote: Fri Jun 05, 2026 2:01 pm Second disc in as many weeks that seems like not a recent release and yet isn't in the public keydb, which makes me worried that the problem is actually on my end, but just in case:
Disc type: UHD
There is no configuration issue on your end. Your disc was just not in the keydb. The public keydb is a community effort and there are thousands of UHD discs going back more than a decade which do not yet have complete keydb records.
Your disc has now been added, so that is one less unsupported title...
HutchLee42
Post by HutchLee42 » Fri Jun 05, 2026 5:14 pm
Disc type: UHD
Disc ID: 0xAA06F221144F4D29668BA4A3C19C604E0916174D
Disc dump filename: MKB20_v82_Leprechaun_1E58
Drive: BD-RW BDR-S12JX
Drive firmware: 1.01
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://drive.google.com/file/d/1I6hbyb ... drive_link
Disc dump link: https://drive.google.com/file/d/1DsWaUv ... drive_link
Talamera
Post by Talamera » Fri Jun 05, 2026 5:24 pm
Hi here is another dump file.
Thank you for adding the public keydb.
German Version of Marty Supreme
yeaho798
Post by yeaho798 » Fri Jun 05, 2026 11:22 pm
OS device name: F:
Product: BD-RE BP60NB10
Revision: 1.02
Serial number: SIK01N4KD0653
Firmware date: 2120-05-07 09:35
Highest AACS version: 78
Firmware version: 1.02
Disc Information
Label: LOTR_FELLOWSHIP_OF_THE_RING_P2
Timestamp: 2020-10-19 17:23:55
Protection: AACS2.0/C v76
Data capacity: 83.21 Gb
Disc type: BD-ROM UHD
Number of layers: 3
Bus encryption flags: 80
https://drive.google.com/file/d/1rZsiQc ... sp=sharing
keydb_helper
Post by keydb_helper » Sat Jun 06, 2026 1:07 am
Thanks to everyone who followed the template and provided new disc dump files. The following UHD discs have been added to the public keydb (new media keys are indicated with an asterisk):
MKB20_v76_The_Lord_of_the_Rings-_The_Fellowship_of_the_Ring_(EXT_)_PT_2_FAAD
MKB20_v82_DESPERATE_LIVING_4B93
*MKB20_v82_HAIRSPRAY_2B24
*MKB20_v82_HAMILTON_1604
*MKB20_v82_Leprechaun_1E58
Talamera wrote: Fri Jun 05, 2026 5:24 pm Hi here is another dump file.
Your disc was added to the public keydb on May 28. Please check the latest keydb before posting to this thread.
truebeliever61
Post by truebeliever61 » Sat Jun 06, 2026 4:12 am
Return To Silent Hill (2026) (Umbrella)
Disc type:UHD
Disc ID: 0x99155CF8658656B18BD077FF860235C0564B8EE8
Disc dump filename: MKB20_v82_Return_To_Silent_Hill_0810
Drive: BD-RE WH16NS60
Drive firmware: 1.02
MKB_RO.inf link: https://drive.google.com/file/d/1pbHOdv ... sp=sharing
Disc dump link: https://drive.google.com/file/d/13hVAAi ... sp=sharing
keydb_helper
Post by keydb_helper » Sat Jun 06, 2026 6:56 am
truebeliever61 wrote: Sat Jun 06, 2026 4:12 am Return To Silent Hill (2026) (Umbrella)
Disc type:UHD
Thanks for following up on your earlier submission. Your disc has been added to the public keydb.
Talamera
Post by Talamera » Sat Jun 06, 2026 10:13 am
Sorry, but Marty Supreme UHD in German doesn‘t work for me.
I have the newest keydb.cfg from today.
MakeMKV says: „Der Volumenschlüssel für die DVD/Blu-ray ist unbekannt - das Video kann nicht entschlüsselt werden“
„Das Öffnen der Disk schlug fehl“
Chisum04
Post by Chisum04 » Sat Jun 06, 2026 12:26 pm
Disc type: UHD
Disc dump filename: MKB20_v82_UHD_Killing_Faith_B4AD
Drive: WH16NS60
MKB_RO.inf link: https://1drv.ms/f/c/29aa5f2d1ffacbe9/Ig ... o?e=sZczqf
Disc Dump link: https://1drv.ms/f/c/29aa5f2d1ffacbe9/Ig ... o?e=sZczqf
keydb_helper
Post by keydb_helper » Sat Jun 06, 2026 3:29 pm
*MKB20_v82_EatenAlive-UHD-UNCUT_D010
*MKB20_v82_Nuremberg_56B4
Talamera wrote: Sat Jun 06, 2026 10:13 am Sorry, but Marty Supreme UHD in German doesn‘t work for me.
As I said, your disc was added to the public keydb on May 28:
0x50930D7A61608F64B394711C12925C0070D48528 = MARTY SUPREME UHD (Marty Supreme - UHD Blu-ray™) | M | 0x1F56<Redacted> | I | 0xF0FF<Redacted> | V | 0x7AE9<Redacted> | U | 1-0xAA48<Redacted> ; MKBv82/BEE (UHD)
If you still can't process your disc it means you have placed the keydb.cfg in the wrong location. Looking at your log file, it seems that you have manually changed your MakeMKV data folder to the path F:/Bluray/. That is where you'll need to place the extracted keydb.cfg file.
I've clarified this point quite a few times lately. I'm going to revise the opening post of this thread and any linked posts of mine to make this point more explicit. I'd appreciate it if this thread could be reserved for disc submissions only.
Tacocat707
Post by Tacocat707 » Sat Jun 06, 2026 5:04 pm
Zootopia 2 (2025) Japanese UHD
Disc Type: UHD
Disc ID: 342973036cbe98ff2a4369fce39222c82be61353
Disc Dump File Name: MKB20_v77_Zootopia_2_0570
Drive: BD-RE BU40N
Drive Firmware: 1.03
LibreDrive Status: Enabled
Did you sync the public keyDB within the last 15 minutes? Yes
MKB_RO.inf link: https://drive.google.com/drive/folders/ ... o61_i1Nzkl_
Disc dump link: https://drive.google.com/drive/folders/ ... YHSeDS66tL
