Public KeyDB Disc Submissions
truebeliever61
Post by truebeliever61 »
Disc type:UHD
Disc ID:0x99155CF8658656B18BD077FF860235C0564B8EE8
Disc dump filename:MKB20_v82_Return_To_Silent_Hill_0810
Drive:BD-RE WH16NS60
Drive firmware:1.02
LibreDrive status:Enabled
Did you sync the public keydb within the last 15 minutes?Yes
Have you verified that all submission links are accessible in incognito/private browsing?yes
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://drive.google.com/file/d/14fPIXn ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1Ea0qvf ... sp=sharing
keydb_helper
Post by keydb_helper »
FootFungus07 wrote: Wed Jun 03, 2026 3:04 pm The Patriot US 4K UHD Theatrical & Unrated TGZ Dump Files
Theatrical:
MKB20_v82_Patriot,_The_-_Theatrical Version_0C54.tgz
Extended:
MKB20_v82_Patriot,_The_-_Extended_Version_5104.tgz
Thanks for passing those along FootFungus07. Both have been added to the public keydb.
truebeliever61 wrote: Thu Jun 04, 2026 2:28 am Disc type:UHD
Hey truebeliever61, it seems that both of your Google Drive links point to empty files. Could you please verify those links in incognito/private browsing mode and reupload the files if they remain empty?
mattmak464
Post by mattmak464 »
Disc type: UHD
Disc ID: 0x66C386F2F1CE117E77904C1544F845A8FD8E5284
Disc dump filename: MKB20_v82_Bridesmaids_DA42.tgz
Drive: BD-RE BU40N
Drive firmware: 1.00
LibreDrive status: Enabled
MKB_RO.inf link: https://drive.google.com/file/d/1b52spy ... share_link
Disc dump link: https://drive.google.com/file/d/1qAb3Lh ... share_link
ng1988
Post by ng1988 »
I wanted to rip the movie Scarlet in 4K UHD, but it won't open in MKVmaker.
Drive information
OS-Device name: E:
Produzent: HL-DT-ST
Produkt: BD-RE BU40N
Revision: 1.03
Serial number: MOFP7J83721
Firmware-Date: 2118-10-24 19:34
Bus encryption markings: 17
Highest AACS version: 82
Firmware version: 1.03
Disk-Informationen
Label: SCARLET
Timestamp: 2026-03-26 13:02:05
Protection: AACS2.0/C v82
Data capacity: 72.42 Gb
Disk-Typ: BD-ROM UHD
Number of layers: 3
Bus encryption markings: 80
Link to the file:
https://drive.google.com/file/d/1lRR0o4 ... sfKHP/view
Thank you for help =)
yeaho798
Post by yeaho798 »
OS device name: F:
Product: BD-RE BP60NB10
Revision: 1.02
Serial number: SIK01N4KD0653
Firmware date: 2120-05-07 09:35
Highest AACS version: 78
Firmware version: 1.02
Disc Information
Label: LOTR_FELLOWSHIP_OF_THE_RING_P1
Timestamp: 2020-10-29 19:40:43
Protection: AACS2.0/C v76
Data capacity: 75.72 Gb
Disc type: BD-ROM UHD
Number of layers: 3
Bus encryption flags: 80
https://drive.google.com/file/d/1JvzqGJ ... drive_link
MrPenguin
Post by MrPenguin »
ng1988 wrote: Thu Jun 04, 2026 11:32 am Disk-Informationen
Label: SCARLET
Number of layers: 3
The latest KEYDB.cfg file already contains this disk. Have you tried downloading this file, copying it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV?
MKVDUDE
Post by MKVDUDE »
Another one please - All files are in the same link - https://we.tl/t-MinyTWbywSjmPLiK
Disc type: BD
Disc ID: 0aa47d9916e6345bf875e94e99934acd1967b274
Disc dump filename: MKB_v82_Monty_Python's_Fliegender_Zirkus_F3D6.tgz
Drive: MT1959
Drive firmware: 1.03
MKB_RO.inf link: https://we.tl/t-MinyTWbywSjmPLiK
Disc dump link: https://we.tl/t-MinyTWbywSjmPLiK
Many thanks!
Mythbuster
Post by Mythbuster »
here is my dump file, hope you can help to decrypt.
Disc type: UHD
Disc dump filename: MKB20_v82_Spaceballs_UHD_378D
Drive: Asus BW-16D1HT
Drive firmware: 3.10MK
Disc dump link: https://drive.google.com/file/d/189KXhr ... share_link
Thank You
keydb_helper
Thanks to everyone who followed the template and provided new disc dump files. The following UHD discs have been added to the public keydb (new media keys are indicated with an asterisk):
MKB20_v76_The_Lord_of_the_Rings-_The_Fellowship_of_the_Ring_(EXT_)_PT_1_E853
*MKB20_v82_HOW_TO_MAKE_A_KILLING_0D8E
*MKB20_v82_LE_MAGE_DU_KREMLIN_9DA0
*MKB20_v82_NottingHill_UPK1_4186
ng1988
Post by ng1988 »
MrPenguin wrote: Thu Jun 04, 2026 2:08 pm
Label: SCARLET
Number of layers: 3
Wonderful, it worked perfectly. Thank you so much! =)
Stryker412
Post by Stryker412 »
Dump for Hoppers
Disc Information
Label: HOPPERS
Timestamp: 2026-04-10 18:36:38
Data capacity: 93.5 Gb
Number of layers: 3
https://drive.google.com/file/d/1sb-RCo ... sp=sharing
keydb_helper
Stryker412 wrote: Fri Jun 05, 2026 1:23 am Dump for Hoppers
Disc Information
Label: HOPPERS
Hey Stryker412, your disc was added to the public keydb on May 25. Please read the first post of this thread for info on how to configure MakeMKV to utilise the public keydb and the actual submission template.
Twistedsheep
Post by Twistedsheep »
I bombed this last time I tried, but I feel like I've crossed all my Ts. Thank you makemkv crew who helped me previously, and perhaps I discovered a spicy disk and drive combo.
The Abyss
Disc type: UHD
Disc ID: 9e8e1ce30d47315834d8a6d8721c3846d07d017c
Disc dump filename: MKB20_v77_THE_ABYSS_E1C1.tgz
Drive: BD-RE BP60NB10
Drive firmware: 1.02
MKB_RO.inf link: [https://drive.google.com/file/d/18ZyiIH ... drive_link](https://drive.google.com/file/d/18ZyiIH ... drive_link)
Disc dump link: [https://drive.google.com/file/d/1Qwbp3K ... drive_link](https://drive.google.com/file/d/1Qwbp3K ... drive_link)
keydb_helper
Twistedsheep wrote: Fri Jun 05, 2026 2:41 am I bombed this last time I tried, but I feel like I've crossed all my Ts. Thank you makemkv crew who helped me previously, and perhaps I discovered a spicy disk and drive combo.
The Abyss
Disc type: UHD
Thanks for following the submission template Twistedsheep. Your disc has been added to the public keydb.
sergio31
Post by sergio31 »
keydb_helper wrote: Sun May 31, 2026 1:49 pm Thanks to everyone who followed the template and provided new disc dump files. The following UHD discs have been added to the public keydb (new media keys are indicated with an asterisk):
MKB20_v61_Philadelphia_FB27
*MKB20_v77_RATATOUILLE (0x2EEFB114195DCEDCCB06E0A552EC97DE6D9F6B93)
*MKB20_v82_Avatar-_Fire_and_Ash_DB6C
*mkb20_v82_bdrom_0ece (Gourou)
MKB20_v82_Bugonia_0F35
*MKB20_v82_Hell_Or_High_Water_3132
*MKB20_v82_LEAVING_LAS_VEGAS_BB10
*MKB20_v82_NottingHill_UPK75_2E12
*MKB20_v82_Slither_UHD_3996
MKB20_v82_Speed_Racer_D1F2
*MKB20_v82_TheBurbs_UHD_22BE
*MKB20_v82_The_Cars_That_Ate_Paris_UHD_22C2
*MKB20_v82_The_Flintstones_74EE
Key does not still work on MKB20_v82_Avatar-_Fire_and_Ash_DB6C.
