Public KeyDB Disc Submissions
robf2112
#2491 Post by robf2112 » Mon Jun 01, 2026 7:55 pm
Disc type: UHD
Disc ID: 0xa4a210d6257eb714200175ebbf520d7931cd4d1c
Disc dump filename: MKB20_v82_THE_WARNING_LIVE_FROM_AUDITORIO_NACIONAL_6E7A.tgz
Drive: BW-16D1HT
Drive firmware: 3.01
LibreDrive status: Enabled
MKB_RO.inf link: https://drive.usercontent.google.com/do ... 0343050383
Disc dump link: https://drive.usercontent.google.com/do ... 0343196738
More information in case I got any of the above wrong:
MakeMKV v1.18.3 linux(x64-release) started
BD-RE ASUS BW-16D1HT 3.01 KLJL75G4002
Using LibreDrive mode (v06.3 id=E064BA3E3F81)
koberulz
#2492 Post by koberulz » Tue Jun 02, 2026 4:44 am
I have a UHD I can't rip and a Pioneer BD-RW BDR-S12U. My understanding is there's nothing I can do about this except submit the dump to svq and wait?
#2493 Post by MartyMcNuts » Tue Jun 02, 2026 7:05 am
koberulz wrote: Tue Jun 02, 2026 4:44 am I have a UHD I can't rip and a Pioneer BD-RW BDR-S12U. My understanding is there's nothing I can do about this except submit the dump to svq and wait?
Yes, email the dump to svq@makemkv.com. You can also make a post for the dump here in this thread as Pioneer drives can be used for dumps now. Just follow the template from the first post.
Also, if you are using Windows, try SamuraiHL's KeyDB tool as there may already be a media key available for your disc. His tool might be able to add a key record for your disc and update the KeyDB without you having to post the dump here. It's worth trying this first.
koberulz
#2494 Post by koberulz » Tue Jun 02, 2026 7:56 am
MartyMcNuts wrote: Tue Jun 02, 2026 7:05 am Yes, email the dump to svq@makemkv.com.
Did that over a week ago.
Disc type: UHD
Disc ID: 0x76B03A1AAFB3ED94F1B3F050242D1949342587E9
Disc dump filename: MKB20_v82_Sirat_32EC
Drive: Pioneer
Drive firmware: BD-RW BDR-S12U
LibreDrive status:
Did you sync the public keydb within the last 15 minutes? Yes.
Have you verified that all submission links are accessible in incognito/private browsing? Yes.
Disc dump link: https://drive.google.com/drive/folders/ ... Y1-XdWjFAf
I've been checking in on that one periodically as well, with no success. Not sure how to use it to add a key record though.
Monkeylord
#2495 Post by Monkeylord » Tue Jun 02, 2026 9:34 am
Disc type: UHD
Disc ID: 0x4FC5253A5722EC741DAB5725A41FA3E34DE0863F
Disc dump filename: MKB20_v82_Good_Luck_Have_Fun_Don't_Die_89D2.tgz
Drive: BW-16D1HT
Drive firmware: 3.10
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): N/A (included in disk dump)
Disc dump link: https://drive.google.com/file/d/1MS6Z8I ... sp=sharing
#2496 Post by MartyMcNuts » Tue Jun 02, 2026 10:24 am
koberulz wrote: Tue Jun 02, 2026 7:56 am
Disc type: UHD
Drive: Pioneer
LibreDrive status:
In SamuriHL's tool, put the disc the in the drive and click the Validate button.
koberulz
#2497 Post by koberulz » Tue Jun 02, 2026 11:19 am
MartyMcNuts wrote: Tue Jun 02, 2026 10:24 am In SamuriHL's tool, put the disc the in the drive and click the Validate button.
That fails, then spits the disc out.
keydb_helper
#2498 Post by keydb_helper » Tue Jun 02, 2026 2:08 pm
Thanks to everyone who followed the template and provided new disc dump files. The following UHD discs have been added to the public keydb (new media keys are indicated with an asterisk):
*MKB20_v82_BODY_HEAT_192C
MKB20_v82_BRUTE_CORPS_UHD_3EF9
MKB20_v82_Chaos_8693
*MKB20_v82_Good_Luck_Have_Fun_Don't_Die_89D2
*MKB20_v82_PATRIOT_THE_EXTENDED_VERSION_5F40
*MKB20_v82_PATRIOT_THE_THEATRICAL_VERSION_AAD6
*MKB20_v82_Sirat_32EC
*MKB20_v82_THE_WARNING_LIVE_FROM_AUDITORIO_NACIONAL_6E7A
MKB20_v82_UHD_GLHF_673B
ubiq168
#2499 Post by ubiq168 » Tue Jun 02, 2026 3:20 pm
Disc type: UHD
Disc ID: 0x8A1FB6743BA057D3CA66CD92B8C0973B9FA4CB33
Disc dump filename: MKB20_v66_The_Predator_6029
Drive: BU40N
Drive firmware: 1.03MK
MKB_RO.inf link: <Link>
Disc dump link: <Link>
https://drive.google.com/file/d/1xs22dl ... p=drivesdk
ubiq168
#2500 Post by ubiq168 » Tue Jun 02, 2026 3:24 pm
Disc type: UHD
Disc ID: 0x641CEFBFE4E6864946EAF55FD3C4B5988EBD8988
Disc dump filename: MKB20_v68_Shazam!_DD29
Drive: BU40N
https://drive.google.com/file/d/15bzNuC ... p=drivesdk
#2501 Post by SamuriHL » Tue Jun 02, 2026 5:42 pm
koberulz wrote: Tue Jun 02, 2026 11:19 am
In the KeyDB Assistant do the following:
Synchronize when opening the tool
Disc Info <-- that is what you want
Disc Info pulls some info off the disc and checks it against the keydb.cfg that FindVUK downloaded for you during the Synchronize function. It will tell you the status of the disc. It'll also check the keydb.cfg for usable media keys for your title. If a usable key is found then FindVUK validate is used to upload the key for you automatically. No need to use validate function most of the time.
HZone
MKB20_v82_Avatar-_Fire_and_Ash_334A
#2502 Post by HZone » Tue Jun 02, 2026 6:26 pm
Disc type: UHD
Disc ID: 0xD20FF28C324C29A76DA9C40F41119DCC5746E8D5
Disc dump filename: MKB20_v82_Avatar-_Fire_and_Ash_334A
Drive: BD-RW BDR-XS07U
Drive firmware: 1.02/ID05
MKB_RO.inf link: https://drive.google.com/file/d/1OpkODV ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1P2Ftx3 ... sp=sharing
fankayii
#2503 Post by fankayii » Wed Jun 03, 2026 5:37 am
Here are the two dump files for Tokyo Taxi(2025) Blu-ray: MKB_v82_BDROM_5206 & MKB_v82_BDROM_BB3C (movie & bonus discs)
keydb_helper
#2504 Post by keydb_helper » Wed Jun 03, 2026 2:01 pm
*MKB20_v66_The_Predator_6029
*MKB20_v68_Shazam!_DD29
*MKB20_v82_Avatar-_Fire_and_Ash_334A
*MKB20_v82_null_FE6A (Day of the Dead)
FootFungus07
#2505 Post by FootFungus07 » Wed Jun 03, 2026 3:04 pm
The Patriot US 4K UHD Theatrical & Unrated TGZ Dump Files
Theatrical:
MKB20_v82_Patriot,_The_-_Theatrical Version_0C54.tgz
Label: PATRIOT_THE_EXTENDED_VERSION
Timestamp: 2026-04-09 17:06:00
Protection: AACS2.0/C v82
Data capacity: 86.93 Gb
Disc type: BD-ROM UHD
Number of layers: 3
Bus encryption flags: 80
Extended:
MKB20_v82_Patriot,_The_-_Extended_Version_5104.tgz
Timestamp: 2026-04-09 20:17:27
Data capacity: 86.48 Gb
Number of layers: 3
Product: BD-RE BP60NB10
Revision: 1.02
Serial number: SIM03NB8C0638
Firmware date: 2120-05-07 09:35
Highest AACS version: 82
Theatrical Cut Dump File Link: https://drive.google.com/file/d/1SPCdsy ... drive_link
Extended Cut Dump File Link: https://drive.google.com/file/d/1QDGhlF ... drive_link
