DTS to AC3
fe123
Re: DTS to AC3
Post by fe123 »
im trying to encode DTS -> AC3 with the fist posted profile from ant75.
Unfortunately makemkv stops durring the process. Here is my debug-output:
Debug log started at Sat Mar 21 11:44:37 2015 , written by MakeMKV v1.9.1 win(x64-release)
001005:0000 MakeMKV v1.9.1 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\Flo/MakeMKV_log.txt
005015:0000 Saving 1 titles into directory E:/Video/Test using profile 'AC3' from file 'C:\Program Files (x86)\MakeMKV/dts-ac3.mmcp.xml'
FFDEC001: [dca @ 00000000260d2ae0] Warning: not compiled with thread support, using thread emulation
FFDEC001: [dca @ 00000000260d2ae0] Stream with high frequencies VQ coding
FFENC002: [ac3 @ 0000000023b78c20] Warning: not compiled with thread support, using thread emulation
FFDEC001: [dca @ 00000000260d2ae0] Overread auxiliary data by 32 bits
FFDEC001: [dca @ 00000000260d2ae0] error decoding block
001003:0020 DEBUG: Code 3199971767 at (<F(Sq:ef)-nA,Y~nDrk|:29393654
004054:2000 FFMPEG_ERROR: FFDEC001: [dca @ 00000000260d2ae0] Overread auxiliary data by 32 bits
004054:2000 FFMPEG_ERROR: FFDEC001: [dca @ 00000000260d2ae0] error decoding block
001003:0020 DEBUG: Code 2 at Y1/D5V42><,Q*Hbv:121264717
001003:0020 DEBUG: Code 0 at y6*vfE*%I]?KB[pfW2x&:29393286
001003:0020 DEBUG: Code 0 at HP+;miP)fe8t]hBOd\=l:121263337
001003:0020 DEBUG: Code 0 at {Sd%j8Wv.P@.V@bGTwF]7:29399013
001003:0020 DEBUG: Code 20 at Y1/D5V42><,Q*Hbv:213131571
001003:0020 DEBUG: Code 0 at Y1/D5V42><,Q*Hbv:121264924
005003:0000 Failed to save title 0 to file E:/Video/Test/Test_t00.mkv
005004:0080 0 titles saved, 1 failed
Application exited at Sat Mar 21 11:45:04 2015
Does anybody know how i can fix this?
Thanks in advance!
laaank
Re: DTS to AC3
Post by laaank »
Hi, I am a newbe with makemkv - I found the advanced settings, but where do I need to place these described longer scripts and to which files (to convert DTS to AC3) instead of the default settings ? Thank you
Larrikin
Re: DTS to AC3
Post by Larrikin »
Hi All. Thanks very much for all the valuable info in this thread. I managed to get it to work. I have two questions:
1. It fails on DTS:X and cannot convert to AC3. Anyone else have this issue?
2. Any chance we can convert to E-AC3 instead of AC3? I tried by simply renaming AC3 to E-AC3 but it won't even load as a valid profile.
Thanks in advance.
sfuma
Re: DTS to AC3
Post by sfuma »
After converting DTS to AC3, the sound becomes quieter. How to register in the profile metadata dialnorm: -27dB?
serpi
Re: DTS to AC3
Post by serpi »
Is this still possible with recent builds (1.18.3)?
I don't know where to find (and edit) the profiles and I see no option for the dts dll in the settings.
I would like to have a profile, that allows me to convert DTS to AC3 while ripping with no need of using extra tools.
At the moment there are only "Default", "AAC-Stereo", "FLAC" and "WDTV" profiles and I have no clue, where these are stored or how to create a new one with AC3 (if still possible).
Thanks & Ciao, Alfred
Sayaka
Re: DTS to AC3
Post by Sayaka »
Apologies for being late. Please download this file and place it inside your MakeMKV config folder : https://drive.google.com/file/d/1fgpDK4 ... sp=sharing
This is a basic DTS to AC3 profile. I tested it on the Blu-ray menu video of Kaamelott Volet 2 Partie 1 and it worked. Note that this is purely for converting DTS audio to AC3, it's not a full AC3 profile. I did as mike admin recommended and just "patched" the AAC profile. If anyone would like me to create a full AC3 profile, please let me know, just please be aware that I will likely be unable to fully test it myself before releasing it.
