In SamuriHL's tool, put the disc the in the drive and click the Validate button.koberulz wrote: Tue Jun 02, 2026 7:56 amDid that over a week ago.
Disc type: UHDYou can also make a post for the dump here in this thread as Pioneer drives can be used for dumps now. Just follow the template from the first post.
Disc ID: 0x76B03A1AAFB3ED94F1B3F050242D1949342587E9
Disc dump filename: MKB20_v82_Sirat_32EC
Drive: Pioneer
Drive firmware: BD-RW BDR-S12U
LibreDrive status:
Did you sync the public keydb within the last 15 minutes? Yes.
Have you verified that all submission links are accessible in incognito/private browsing? Yes.
Disc dump link: https://drive.google.com/drive/folders/ ... Y1-XdWjFAf
I've been checking in on that one periodically as well, with no success. Not sure how to use it to add a key record though.Also, if you are using Windows, try SamuraiHL's KeyDB tool as there may already be a media key available for your disc. His tool might be able to add a key record for your disc and update the KeyDB without you having to post the dump here. It's worth trying this first.
Public KeyDB Disc Submissions
koberulz
That fails, then spits the disc out.MartyMcNuts wrote: Tue Jun 02, 2026 10:24 am In SamuriHL's tool, put the disc the in the drive and click the Validate button.
keydb_helper
Thanks to everyone who followed the template and provided new disc dump files. The following UHD discs have been added to the public keydb (new media keys are indicated with an asterisk):
*MKB20_v82_BODY_HEAT_192C
MKB20_v82_BRUTE_CORPS_UHD_3EF9
MKB20_v82_Chaos_8693
*MKB20_v82_Good_Luck_Have_Fun_Don't_Die_89D2
*MKB20_v82_PATRIOT_THE_EXTENDED_VERSION_5F40
*MKB20_v82_PATRIOT_THE_THEATRICAL_VERSION_AAD6
*MKB20_v82_Sirat_32EC
*MKB20_v82_THE_WARNING_LIVE_FROM_AUDITORIO_NACIONAL_6E7A
MKB20_v82_UHD_GLHF_673B
- The MKB_RO.inf file from the original disc is required
- Do not submit Stranger Things
ubiq168
Disc type: UHD
Disc ID: 0x8A1FB6743BA057D3CA66CD92B8C0973B9FA4CB33
Disc dump filename: MKB20_v66_The_Predator_6029
Drive: BU40N
Drive firmware: 1.03MK
LibreDrive status: Enabled
MKB_RO.inf link: <Link>
Disc dump link: <Link>
https://drive.google.com/file/d/1xs22dl ... p=drivesdk
Drive: BU40N
ubiq168
Disc type: UHD
Disc ID: 0x641CEFBFE4E6864946EAF55FD3C4B5988EBD8988
Disc dump filename: MKB20_v68_Shazam!_DD29
Drive: BU40N
https://drive.google.com/file/d/15bzNuC ... p=drivesdk
Drive: BU40N
In the KeyDB Assistant do the following:koberulz wrote: Tue Jun 02, 2026 11:19 amThat fails, then spits the disc out.MartyMcNuts wrote: Tue Jun 02, 2026 10:24 am In SamuriHL's tool, put the disc the in the drive and click the Validate button.
Synchronize when opening the tool
Disc Info <-- that is what you want
Disc Info pulls some info off the disc and checks it against the keydb.cfg that FindVUK downloaded for you during the Synchronize function. It will tell you the status of the disc. It'll also check the keydb.cfg for usable media keys for your title. If a usable key is found then FindVUK validate is used to upload the key for you automatically. No need to use validate function most of the time.
HZone
MKB20_v82_Avatar-_Fire_and_Ash_334A
Disc type: UHD
Disc ID: 0xD20FF28C324C29A76DA9C40F41119DCC5746E8D5
Disc dump filename: MKB20_v82_Avatar-_Fire_and_Ash_334A
Drive: BD-RW BDR-XS07U
Drive firmware: 1.02/ID05
MKB_RO.inf link: https://drive.google.com/file/d/1OpkODV ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1P2Ftx3 ... sp=sharing
fankayii
Here are the two dump files for Tokyo Taxi(2025) Blu-ray: MKB_v82_BDROM_5206 & MKB_v82_BDROM_BB3C (movie & bonus discs)
keydb_helper
*MKB20_v66_The_Predator_6029
*MKB20_v68_Shazam!_DD29
*MKB20_v82_Avatar-_Fire_and_Ash_334A
*MKB20_v82_null_FE6A (Day of the Dead)
FootFungus07
The Patriot US 4K UHD Theatrical & Unrated TGZ Dump Files
Theatrical:
MKB20_v82_Patriot,_The_-_Theatrical Version_0C54.tgz
Label: PATRIOT_THE_EXTENDED_VERSION
Timestamp: 2026-04-09 17:06:00
Protection: AACS2.0/C v82
Data capacity: 86.93 Gb
Disc type: BD-ROM UHD
Number of layers: 3
Bus encryption flags: 80
Extended:
MKB20_v82_Patriot,_The_-_Extended_Version_5104.tgz
Timestamp: 2026-04-09 20:17:27
Data capacity: 86.48 Gb
Number of layers: 3
Product: BD-RE BP60NB10
Revision: 1.02
Serial number: SIM03NB8C0638
Firmware date: 2120-05-07 09:35
Highest AACS version: 82
Theatrical Cut Dump File Link: https://drive.google.com/file/d/1SPCdsy ... drive_link
Extended Cut Dump File Link: https://drive.google.com/file/d/1QDGhlF ... drive_link
Theatrical:
Number of layers: 3
Extended:
Number of layers: 3
Revision: 1.02
truebeliever61
Disc type:UHD
Disc ID:0x99155CF8658656B18BD077FF860235C0564B8EE8
Disc dump filename:MKB20_v82_Return_To_Silent_Hill_0810
Drive:BD-RE WH16NS60
Drive firmware:1.02
LibreDrive status:Enabled
Did you sync the public keydb within the last 15 minutes?Yes
Have you verified that all submission links are accessible in incognito/private browsing?yes
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://drive.google.com/file/d/14fPIXn ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1Ea0qvf ... sp=sharing
Drive firmware:1.02
keydb_helper
Thanks for passing those along FootFungus07. Both have been added to the public keydb.FootFungus07 wrote: Wed Jun 03, 2026 3:04 pm The Patriot US 4K UHD Theatrical & Unrated TGZ Dump Files
Theatrical:
Extended:
Hey truebeliever61, it seems that both of your Google Drive links point to empty files. Could you please verify those links in incognito/private browsing mode and reupload the files if they remain empty?truebeliever61 wrote: Thu Jun 04, 2026 2:28 am Disc type:UHD
mattmak464
Disc type: UHD
Disc ID: 0x66C386F2F1CE117E77904C1544F845A8FD8E5284
Disc dump filename: MKB20_v82_Bridesmaids_DA42.tgz
Drive: BD-RE BU40N
Drive firmware: 1.00
MKB_RO.inf link: https://drive.google.com/file/d/1b52spy ... share_link
Disc dump link: https://drive.google.com/file/d/1qAb3Lh ... share_link
Drive: BD-RE BU40N
ng1988
I wanted to rip the movie Scarlet in 4K UHD, but it won't open in MKVmaker.
Drive information
OS-Device name: E:
Produzent: HL-DT-ST
Produkt: BD-RE BU40N
Revision: 1.03
Serial number: MOFP7J83721
Firmware-Date: 2118-10-24 19:34
Bus encryption markings: 17
Firmware version: 1.03
Disk-Informationen
Label: SCARLET
Timestamp: 2026-03-26 13:02:05
Data capacity: 72.42 Gb
Disk-Typ: BD-ROM UHD
Number of layers: 3
Bus encryption markings: 80
Link to the file:
https://drive.google.com/file/d/1lRR0o4 ... sfKHP/view
Thank you for help =)
Drive information
OS-Device name: E:
Produzent: HL-DT-ST
Revision: 1.03
Disk-Informationen
Label: SCARLET
Number of layers: 3
Link to the file:
yeaho798
OS device name: F:
Revision: 1.02
Serial number: SIK01N4KD0653
Highest AACS version: 78
Firmware version: 1.02
Disc Information
Label: LOTR_FELLOWSHIP_OF_THE_RING_P1
Timestamp: 2020-10-29 19:40:43
Protection: AACS2.0/C v76
Data capacity: 75.72 Gb
Number of layers: 3
https://drive.google.com/file/d/1JvzqGJ ... drive_link
OS device name: F:
Revision: 1.02
Disc Information
Number of layers: 3
