PM sent. You must activate that function to receive emails.plattfot wrote: Fri May 22, 2026 10:49 pmA thousand apologizes! I was expecting to get a notification via email if anyone responded, so I didn't login to check... Then life happened, one thing being my server I store my rips on died. Finally got everything sorted so I can start again. Do you mind sending another PM?Coopervid wrote: Thu May 29, 2025 2:37 amPM sent.plattfot wrote: Sat May 24, 2025 4:53 pm Hi,
I just started collecting UHD but sadly my drive BDR-UD03 drive cannot read them. Any help would be appreciated.
Drive Information OS device name: /dev/sr0 Current profile: BD-ROM Manufacturer: PIONEER Product: BD-RW BDR-UD03 Revision: 1.11 Serial number: SE********** Firmware date: 2018-11-28 Bus encryption flags: 1B Highest AACS version: 81 LibreDrive Information Status: Enabled Drive platform: RS8511 Firmware name: PIONEER BDR-US03 Firmware type: Original (unpatched) Firmware version: 1.11 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
(This time I'll make sure to periodically login to check my notifications...)
Pioneer BDR-UD03 UHD possibility
Re: Pioneer BDR-UD03 UHD possibility
koza3000
I've got the same problem with my Pioneer BDR-UD03. I really want it to read UHD. Could You help me?
Revision: 1.14
Serial number: ALDL438721WL
Firmware date: 2020-06-15
Firmware version: 1.14
Thank You in advance
Revision: 1.14
sure email me that infokoza3000 wrote: Sun May 24, 2026 9:33 am Hi,
Revision: 1.14
and all others email me no need to post your info here publicly just reach out to me directly
see below for email
PM sent.koza3000 wrote: Sun May 24, 2026 9:33 am Hi,
Revision: 1.14
brianforever
Hi Coopervid,
Saw everyone posting, thought I join in the fun too, Thanks very much
Revision: 1.11
Serial number: SJDL269515WL
Revision: 1.11
tolerable
I also find myself in possession of one of these drives, and would really like to be able to rip my UHDs with it.
Revision: 1.03
Serial number: RHDL515399WL
Firmware date: 2015-05-14
Highest AACS version: 77
Drive platform: RS8510
Firmware version: 1.03/ID19
sure email me that infotolerable wrote: Mon Jun 01, 2026 6:42 pm I also find myself in possession of one of these drives, and would really like to be able to rip my UHDs with it.
Revision: 1.03
see below for email
PM sent.brianforever wrote: Tue May 26, 2026 4:20 am Hi Coopervid,
Revision: 1.11
PM sent.tolerable wrote: Mon Jun 01, 2026 6:42 pm I also find myself in possession of one of these drives, and would really like to be able to rip my UHDs with it.
Revision: 1.03
brianforever
Thank you very much Kind Sir
Coopervid wrote: Tue Jun 02, 2026 10:19 amPM sent.brianforever wrote: Tue May 26, 2026 4:20 am Hi Coopervid,
Revision: 1.11
You are welcome. Enjoy!brianforever wrote: Tue Jun 02, 2026 2:39 pm Thank you very much Kind Sir
Revision: 1.11
mattblack67
Hello all,
I thought I would throw mine into the mix:
OS device name: E:
Revision: 1.14
Serial number: BGDL494862WL
Highest AACS version: 68
Thanks in advance
OS device name: E:
Revision: 1.14
Thanks in advance
kakademona
Hello good Sir!
Would be fantastic to unlock my Verbatim drive too! Just bought my first UHD and realized that it is wrong model and I cant do anything unless i patch the firmware...
Revision: 1.14
Serial number: AFDL414165WL
Thanks a lot in advance!
Kind regards KD
Revision: 1.14
Kind regards KD
theoneperson
Same issue for me? any help with a PM on the file needed?
kakademona wrote: Wed Jun 03, 2026 10:27 am Hello good Sir!
Revision: 1.14
Kind regards KD
theoneperson wrote: Sat Jun 06, 2026 12:02 am Same issue for me? any help with a PM on the file needed?
sure email me that infomattblack67 wrote: Wed Jun 03, 2026 12:20 am Hello all,
OS device name: E:
Revision: 1.14
Thanks in advance
see below for email
