Is anyone else getting #522 errors, trying to get through to the forums?
Lots of timed out connections, and suchlike?
It’s VERY frustrating!
Error 522
Re: Error 522
yes everyone is running into this
ai scraper bots are likely causing it
and yet the ai still helps people brick their drives everyday i get so many emails about this
Jack_The_Ripper
Re: Error 522
Yes, it's awful. Make it stop.
Took me 15mins just to get to the page where I could type this reply (and the page is still not finished loading). Who knows how long before I can successfully post it.
Cuddy2977
Re: Error 522
Have we heard anything more about this?
harborless-accept5
Re: Error 522
Many forums now have a Cloudflare "Verify you are human" check before you can access them now because of the AI crawlers.
Cuddy2977
Re: Error 522
The problem there … ?harborless-accept5 wrote: Tue Jun 02, 2026 12:29 pm Many forums now have a Cloudflare "Verify you are human" check before you can access them now because of the AI crawlers.
Is that I’m seeing no sign of a verify page
And the Connection Time Out pages I’m getting, are saying the issue is with the forum, not with Cloudflare …
Jack_The_Ripper
Re: Error 522
There is no such check with a 522 error, which is what appears. A 522 error by definition is mostly about origin server overload, which is almost entirely the site's problem to fix, and the "verify you are human" check is a different mechanism that doesn't apply here.harborless-accept5 wrote: Tue Jun 02, 2026 12:29 pm Many forums now have a Cloudflare "Verify you are human" check before you can access them now because of the AI crawlers.
The diagnostic tell is in my own observation: I'm seeing a Cloudflare-branded error page. That can only happen if my connection to Cloudflare succeeded. So the break is downstream of me — between Cloudflare and the origin — not between myself and Cloudflare.
There is essentially nothing frontend users can do to resolve a genuine 522, because the failure point isn't anything we control.
The one cheap thing worth doing is falsifying the alternative, i.e. confirm the break really is origin-side and not a local artifact. Try a different network or device (I have), or check whether others report the same (they obviously have lo). It fails identically everywhere, which confirms origin, and we're now just waiting on the admin.
Cuddy2977
Re: Error 522
That’s one of the first things I did, @Jack_The_RipperJack_The_Ripper wrote: Tue Jun 02, 2026 4:29 pmThere is no such check with a 522 error, which is what appears. A 522 error by definition is mostly about origin server overload, which is almost entirely the site's problem to fix, and the "verify you are human" check is a different mechanism that doesn't apply here.harborless-accept5 wrote: Tue Jun 02, 2026 12:29 pm Many forums now have a Cloudflare "Verify you are human" check before you can access them now because of the AI crawlers.
The first thing I did was check if I could get through on the other browsers I use: I couldn’t.
I also checked with other accounts on my machine, AND on my phone and tablet: again, I got a 522 error, or a connection timed out message
