Now You See Me (2013) UK UHD
Mr_Orange
#1 Post by Mr_Orange » Wed May 27, 2026 1:09 am
I recently bought the Now You See Me trilogy box set. It's the UK release, if that matters.
The Now You See Me disc has two versions of the film on disk which MakeMKV identifies (using Java) as 'main feature' and 'main feature_HDR'.
Versions on disc
Versions on disc
ZoomIt 2026-05-27 110512.png (8.88 KiB) Viewed 2078 times
Both are the same length, with the same segment map (1 segment) but different playlists. I've ripped both and MediaInfo doesn't show any differences between the files. Both have HDR10 present.
HDR details
HDR details
ZoomIt 2026-05-27 110542.png (5.68 KiB) Viewed 2078 times
non-HDR details
non-HDR details
ZoomIt 2026-05-27 110559.png (5.68 KiB) Viewed 2078 times
Does anyone know which is the correct?
Re: Now You See Me (2013) UK UHD
#2 Post by dcoke22 » Wed May 27, 2026 8:41 pm
Are there any differences in the audio choices between the two?
Since they have the same segment map, they're the same video. The different playlists might only show a subset of the audio choices available however.
Mr_Orange
#3 Post by Mr_Orange » Thu May 28, 2026 8:17 am
dcoke22 wrote: Wed May 27, 2026 8:41 pm Are there any differences in the audio choices between the two?
I only ripped the English audio but I don't remember seeing any differences.
If the same segment map means the same video, I guess it doesn't matter. Thanks for your reply.
