error trying to use makMKV on a dvdFAB disc
miltk
#1 Post by miltk » Sun May 24, 2026 4:27 am
hi guys
im getting an alert thst im trying to use makeMKV of a dvdfab disc and i might encounter errors.
well,,,i have
it's a dvd of an old tv series.....phil silvers
so i let makeMKV run anyway and of the 8 episodes, 2 were completed and the other 6 were not.
so how do i,,,can i, bypass this dvdfab error
milt,,,and thx
tomty89
Re: error trying to use makMKV on a dvdFAB disc
#2 Post by tomty89 » Sun May 24, 2026 7:50 pm
What's even a "dvdFAB disc"? You mean like a DVD (you) burnt with decrypted content obtained with some dvdfab software? (In that case the chance that the disc is dead may be significantly higher, especially if it was burnt long time ago.)
Either way, what exactly are the errors?
miltk
#3 Post by miltk » Mon May 25, 2026 6:48 am
i thought it was maybe a common enuf error message that someone would no.
i'll have to recreate it,,,sorry,
but the dvd set is an sgt bilko series boxed complete set that i bought from amazon. normally no probs but a particular disc generated this message and makmkv encountered problems and could not compete the job.
it's the only disc of the 20 that generated this message
"it appears you are opening the disc processed by dvdfab/macthe ripper which is known to produce damaged vob files please use original disc instead" - this message is generated when makemkv initially quick scans the dvd
tomty89
#4 Post by tomty89 » Mon May 25, 2026 1:29 pm
Well I have no idea if MakeMKV could give false alarms in some cases but obviously you can't rule out that the disc is simply "broken" (due to "manufacturing error"), and that's what MakeMKV is telling you.
And according to what you have mentioned (2 were completed and the other 6 were not), it doesn't sound to me that MakeMKV is "forbidding" you from backing up / remuxing its content, rather it appears that it just couldn't because the files are "damaged".
Doesn't mean that you cannot try remuxing it mkvtoolnix or ffmpeg though. (Not sure if the disc is encrypted in that case. If so you'll need to make decrypted backup first -- with either makemkv or libdvdcss frontends, such as dvdbackup.)
miltk
#5 Post by miltk » Mon May 25, 2026 6:11 pm
tomty89 wrote: Mon May 25, 2026 1:29 pm
i retried and got different results. the first time makemkv gave me 4 of the 8 episodes, the second time i salvaged 5. i'll try mkvtoolnix and ffmpeg
tomty89
#6 Post by tomty89 » Mon May 25, 2026 8:24 pm
miltk wrote: Mon May 25, 2026 6:11 pm i retried and got different results. the first time makemkv gave me 4 of the 8 episodes, the second time i salvaged 5. i'll try mkvtoolnix and ffmpeg
Well in that case maybe the "dvdfab heads-up" is somewhat a "red herring" and really just means that the disc is in poor state / of poor quality, in which case you might want to make an (encrypted) image of the disc with e.g. ddrescue before decrypting and/or remuxing the content from the image.
Note that if the disc is encrypted (as usual), with at least some drives you might need to open the disc with a libdvdcss frontend (such as VLC) once before you can "raw read" / ddrescue it. (Maybe opening it once with MakeMKV would do as well. Don't really remember.)
