MakeMKV can't read disks anymore and behaves weird
xesegik
Post by xesegik »
Yesterday I was trying to handle a disc, which caused some problems. MakeMKV said it can't decrypt, it looked like an unknown-key problem or something. I was on v1.18.2.
So I upgraded the AACS database in ~/.config/aacs and upgraded to MakeMKV v1.18.3, because the release notes said something about AACS (so I thought it might help).
Since then nothing works anymore. MakeMKV can't even read disks now, even those I successfully handled a couple days ago. It just hangs and shows the spinning-disk animation forever. After a while the disk drive goes silent. I can even remove the disk. MakeMKV is still pretending to read a disk. The Problem remains, even after I downgraded to 1.18.2 again and restored the previous AACS database. I also have 2 processes which eating up a full CPU core each:
[...]        7095 77.9  0.0 731372 44996 ?        Sl   09:36   1:12 /usr/bin/makemkvcon guiserver A0001+shm
[...]        7146 99.2  0.0 461592 44696 ?        Sl   09:36   1:03 /bin/makemkvcon guiserver A0001+std
Even when I close MakeMKV, those processes are still there.
When I kill them by force I have this:
[...]        7146 98.4  0.0      0     0 ?        Z    09:36   6:38 [makemkvcon] <defunct>
... which is unkillable. I have to restart the computer to get rid of that one.
Something is fundamentally broken, and I don't know how to fix that. I could need some help.
science-nerd
Re: MakeMKV can't read disks anymore and behaves weird
Post by science-nerd »
You should try to isolate the cause.
First backup your configs, then wipe makemkv and do a fresh install, see if old known working discs are readable again.
Then you would know if newest makemkv works.
After that you can try the AACS update again to not run into problems with both at the same time
xesegik
Post by xesegik »
Is there a list somewhere, about where MakeMKV puts its files? I only know about this one: ~/.MakeMKV
It would also help if I knew where to find log files or something. MakeMKV going crazy and hugging the CPU ... I would like to know what kind of trouble it has.
Aside from that, I already tried reinstalling. No luck so far. I assume, this problem must be driven by a configuration/data state.
I also read, that MakeMKV isn't using the ~/.config/aacs database. Is that true?
16442496
Post by 16442496 »
Backup your ./MakeMKV just in case and then delete the .MakeMKV derectory from you /home.
Open MakeMKV to see if that help.
"I also read, that MakeMKV isn't using the ~/.config/aacs database. Is that true?"
I think that AACS file (KEYDB.cfg) should be in .MakeMKV directory.
angrod
Post by angrod »
I had similar (but less severe) problems today after a while of not using MakeMKV. The specific symptom was that the program would do the initial read / index of the discs fine, but when I started the rip, it would sit there a while on each title (1-2 minutes) and then fail with an ambiguous message (in the UI) and a slightly less ambiguous but still not very useful message in the robot mode of makemkvcon. The backup mode worked fine, but if I then loaded the generated ISO, the same errors would crop up, albeit a bit faster since there was no optical I/O delay. The most specific error message I saw was:
MSG:1002,32,1,"LIBMKV_TRACE: Exception: Error in p->FetchFrames(1,false)","LIBMKV_TRACE: %1","Exception: Error in p->FetchFrames(1,false)"
I also tried this with an ISO I generated (with the backup function) many months ago that previously worked and it had the same problem.
Since it had been a while since I had last rebuilt MakeMKV and I've done several OS updates in the interim, I tried rebuilding as a first troubleshooting step, but got the same result.
I then moved ~/.MakeMKV to a different path, which solved the problem. Afterward, I moved the only file in the old directory that I cared about, a profile xml file, back into the newly-generated ~/.MakeMKV, and happily that didn't reintroduce the problem. Given what I experienced, I can only conclude that something related to some change that happened along the way, corrupted one of the files in there. Whether that's an OS-level change or strictly confined to MakeMKV or some combination thereof, I couldn't say.
I only tried any of this with DVDs, but if I discover any similar problems with Blus, I may update this post to add more info. For now, I consider the problem resolved for me.
OS info in case it's helpful:
OS: Arch Linux x86_64
Kernel: 6.18.6-arch1-1
xesegik
Post by xesegik »
I did the following:
1. remove makemkv
2. remove the ~/.MakeMKV dir
3. reinstall MakeMKV 1.18.2 (the last version I knew was working)
Still, the problem remains.
Are there any log files I can look at? If yes, where?
science-nerd
xesegik wrote: Mon Feb 16, 2026 12:36 pm I did the following:
1. remove makemkv
Were any updates run between working and not working states? Perhaps some dependency update is causing the issues.
If all else fails, you still might have the option to set up containers with docker and / or distrobox to run makemkv with isolated dependencies should the root cause not be found to prevent a full reinstall.
Speaking of which, what happens if you run your distro with the newest ISO from a live USB session and install makemkv in that environment? If it does not work there, then it is some distro specific dependency issue.
Might want to try different Distros over live sessions. I recommend preparing a USB with Ventoy so you don't need to reformat it every time. Makemkv runs fine on bleeding edge Distros like CachyOS / Arch based ones with the newest of the new packages
xesegik
Post by xesegik »
When I cross-reference several things (e.g. system logs, bash history), the result matched pretty much my memory:
1. MakeMKV 1.18.2 is working but has AACS problems with a disk (first time I have ever seen something like this)
2. Upgrade to MakeMKV 1.18.3 ... which is now broken (as described)
3. Downgrade to MakeMKV 1.18.2 again ... still broken
4. System update ... includes linux kernel and java
5. MakeMKV is still broken
6. Upgrade to MakeMKV 1.18.3 again ... still broken
Basically, the first time system upgrades got involved, MakeMKV was already broken.
I like the idea of running MakeMKV in a container. Since this is a GUI application i don't know how to do that. Can you provide some more information how to run it this way, or what the container must have additionally, etc.
I will also try the live disk thing ... why haven't I thought of this?!
BTW: Does someone know, why the "makemkvcon guiserver" process is there twice? One time from "/usr/bin/" and one time from "/bin/".
science-nerd
xesegik wrote: Thu Feb 19, 2026 12:22 pm When I cross-reference several things (e.g. system logs, bash history), the result matched pretty much my memory:
To run the container it will need permissions for the drive via pass-through and it will need display permissions (if GUI by Xwayland, it needs Xauthority. Magic cookie can be generated with xorg-xhost if on a pure wayland Desktop Environment)
But before doing all this hassle you should verify if it works via live USB first, containers will just mirror the distro environments and dependencies anyway. Although you won't have the headache with device and display permissions.
Not sure why processes are duplicated, does this always happen? Will pay attention to it next time I open makemkv
xesegik
Post by xesegik »
It took me a while to take another look at this. I finally tried to run it from a life linux distro. Same result :(
Can some please check if they have the duplicated processes as well? I suspect the problem comes from there. I'm not sure why this happened suddenly.
I'm out of ideas and frustrated. I bought the license, and now I can't use it because of this problem :(
xesegik
Post by xesegik »
UPDATE
Out of desperation I built an older version (1.17.6, the newest non-1.18 version I have in my archive), and it works. So, now I'm pretty confident, that my system is good, and this is a MakeMKV-version problem.
Is there a way to get older versions (for Linux) from somewhere? I think there was a 1.17.7 or even 1.17.8 version at some point.
tomty89
Post by tomty89 »
xesegik wrote: Sun May 24, 2026 12:20 pm UPDATE
Is there a way to get order versions (for Linux) from somewhere? I think there was a 1.17.7 or even 1.17.8 version at some point.
1.17.6/7 (they are really just the same thing according to https://makemkv.com/download/history.html) happens to be the last version that works fine with non-LibreDrive (without the sdf_Stop workaround) though.
xesegik
Post by xesegik »
tomty89 wrote: Sun May 24, 2026 7:14 pm 1.17.6/7 (they are really just the same thing according to https://makemkv.com/download/history.html) happens to be the last version that works fine with non-LibreDrive (without the sdf_Stop workaround) though.
I got myself another drive. This one has Libre support. With 1.18.3 it works now.
So, yes. It has to come from the code changes made in 1.17.8+ related to reading discs.
