Makemkv don't find my drive
Mitsukho
#1 Post by Mitsukho » Sun May 24, 2026 5:24 pm
Hello every body !
I'm under Linux (Nixos) and i install Makemkv with package pkgs ! ( if i install with flatpack i have the same problem )
Makemkv don't find my drive , it's a Pioneer BD-RW BDR-UD04(1.14)
I don't know what to do, I'm not an expert !
tomty89
Re: Makemkv don't find my drive
#2 Post by tomty89 » Sun May 24, 2026 6:45 pm
load the kernel module sg with modprobe
Mitsukho
#3 Post by Mitsukho » Sun May 24, 2026 6:49 pm
sudo modprobe sg ?
tomty89
#4 Post by tomty89 » Sun May 24, 2026 7:46 pm
Yes and it's volatile (which means the "effect" would be gone after a reboot).
If you want to make it "persistent" you need a "modules-load.d" conf but I suppose in NixOS you don't just create it manually but do it "the Nix way".
