Request for help with copying a BD disc
George_b
Post by George_b »
Hello everyone in the Community,
I’m new to this forum and to using the software.
After having had a quick look through the prerequisite documents, I’ve come across a problem I’m struggling with.
I can’t seem to copy a database, so I’m here to ask for your help.
I’d like some advice on my questions.
With version 1.18.3, is it necessary to make some changes and install libmmbd, AACS 2.0 and BD+, which I don’t have? If so, how should I go about it? I haven’t been able to find any instructions for beginners.
Is the problem with not being able to copy a BD down to my player?
Here are the hardware details below.
Thank you in advance for your replies.
(translated from French using Deepl)
Manufacturer: TSSTcorp
Product: BDDVDW SE-506CB
Revision: TS02
Serial number: S1BU6YKGA008HD
Bus encryption flags: 1F
Highest AACS version: 19
Drive platform: MT1939
Harware support: Yes
Firmware support: No
Firmware version: 01.07
DVD all regions: Possible, not yet enabled
BD raw data read: Possible, not yet enabled
BD raw metadata read: Possible, not yet enabled
Disc Information
Label: TIMER
Timestamp: 2010-12-22 03:47:39
Protection: AACS v19
Data capacity: 18.43 Gb
Disc type: BD-ROM
Number of layers: 1
Re: Request for help with copying a BD disc
George_b wrote:
Wed May 20, 2026 5:20 am
Revision: TS02
Disc Information
Label: TIMER
Disc type: BD-ROM
Number of layers: 1
No, nothing else is required with v1.18.3. Why/what database are you trying to copy? and to where are you trying to copy this so called database?
You didn't paste the info from the log when attempting to rip the disc so we have zero idea what your issue is....
George_b
Post by George_b »
Hello Mark,
thank you for your reply.
I don't know how to find the Log.
I read on the forum that for BD discs, you need the VLC AACS database. That’s what I tried to install.
My issue is that BDs take forever to load—it says “Disc being loaded.”
It can take up to 10 minutes.
And it can take up to 15 minutes.
The movie I’m testing also gives me this message in the information:
MakeMKV v1.18.3 win(x64-release) started
Error ‘Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR’ occurred while reading ‘BD-RE TSSTcorp BDDVDW SE-506CB TS02 S1BU6YKGA008HD’ at offset '19796852736'
Error ‘Scsi error - HARDWARE ERROR:LOGICAL UNIT HAS NOT SELF-CONFIGURED YET’ occurred while reading ‘BD-RE TSSTcorp BDDVDW SE-506CB TS02 S1BU6YKGA008HD’ at offset ‘19796869120’
udf: node fe/efe failed!.
I have read that “SCSI Error” messages are normal. This should not be a blocking error for the process.
Capture d’écran 2026-05-22 162953.png (164.67 KiB) Viewed 775 times
After waiting about 8 minutes for the BD to start up, the additional analysis process began.
The “Opening Blu-ray disc” process takes forever. I'm attaching another screenshot
The “Opening Blu-ray disc” process takes forever. I'm attaching another screenshot (time= 06:14:00 ?)
And I'm getting lots of “SCSI Error” messages
Capture d’écran 2026-05-22 163835.png (231.71 KiB) Viewed 775 times
And now: 10:16:20?
Capture d’écran 2026-05-22 165211.png (273.36 KiB) Viewed 775 times
I think I need some help installing MakeMKV on a computer running Windows 11 Pro and Ubuntu 26 in a dual-boot setup.
This test and copy are on the Windows boot drive.
This happens with two other Blu-rays.
But I have no issues with DVDs.
Thank you for your help
(translate deepl)
George_b
Post by George_b »
In addition to my previous reply to your message, here is the complete log.
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading 'BD-RE TSSTcorp BDDVDW SE-506CB TS02 S1BU6YKGA008HD' at offset '19796852736'
Error 'Scsi error - HARDWARE ERROR:LOGICAL UNIT HAS NOT SELF-CONFIGURED YET' occurred while reading 'BD-RE TSSTcorp BDDVDW SE-506CB TS02 S1BU6YKGA008HD' at offset '19796869120'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading 'BD-RE TSSTcorp BDDVDW SE-506CB TS02 S1BU6YKGA008HD' at offset '19796869120'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while issuing SCSI command 28080..001 to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - MEDIUM ERROR:NO SEEK COMPLETE' occurred while issuing SCSI command 28080..001 to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - HARDWARE ERROR:LOGICAL UNIT HAS NOT SELF-CONFIGURED YET' occurred while reading 'BD-RE TSSTcorp BDDVDW SE-506CB TS02 S1BU6YKGA008HD' at offset '19761659904'
Error 'Scsi error - MEDIUM ERROR:NO SEEK COMPLETE' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '0'
Error 'Scsi error - HARDWARE ERROR:LOGICAL UNIT HAS NOT SELF-CONFIGURED YET' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '0'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '0'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '61440'
Error 'Scsi error - MEDIUM ERROR:NO SEEK COMPLETE' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '61440'
Error 'Scsi error - HARDWARE ERROR:LOGICAL UNIT HAS NOT SELF-CONFIGURED YET' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '61440'
Failed to decode audio/video data for title #0 - invalid mux or internal error, title skipped.
Title #00001.mpls was skipped
Error 'Scsi error - HARDWARE ERROR:LOGICAL UNIT HAS NOT SELF-CONFIGURED YET' occurred while reading '/BDMV/STREAM/00002.m2ts' at offset '0'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00002.m2ts' at offset '0'
Title #00002.mpls was skipped
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00003.m2ts' at offset '282624'
Error 'Scsi error - HARDWARE ERROR:LOGICAL UNIT HAS NOT SELF-CONFIGURED YET' occurred while reading '/BDMV/STREAM/00003.m2ts' at offset '282624'
Error 'Scsi error - MEDIUM ERROR:NO SEEK COMPLETE' occurred while reading '/BDMV/STREAM/00003.m2ts' at offset '282624'
Title #00003.mpls was skipped
Title #01001.mpls was skipped
Error 'Scsi error - MEDIUM ERROR:NO SEEK COMPLETE' occurred while reading '/BDMV/STREAM/00002.m2ts' at offset '0'
Title #01002.mpls was skipped
Error 'Scsi error - HARDWARE ERROR:LOGICAL UNIT HAS NOT SELF-CONFIGURED YET' occurred while reading '/BDMV/STREAM/00003.m2ts' at offset '0'
Error 'Scsi error - MEDIUM ERROR:NO SEEK COMPLETE' occurred while reading '/BDMV/STREAM/00003.m2ts' at offset '18432'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00003.m2ts' at offset '18432'
Error 'Scsi error - HARDWARE ERROR:LOGICAL UNIT HAS NOT SELF-CONFIGURED YET' occurred while reading '/BDMV/STREAM/00003.m2ts' at offset '18432'
Title #01003.mpls was skipped
Title #00000.m2ts has length of 18 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00001.m2ts was skipped
Title #00002.m2ts was skipped
Error 'Scsi error - MEDIUM ERROR:NO SEEK COMPLETE' occurred while reading '/BDMV/STREAM/00003.m2ts' at offset '0'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00003.m2ts' at offset '0'
Title #00003.m2ts was skipped
Title #00004.m2ts has length of 115 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Encountered 110 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
George_b wrote:
Fri May 22, 2026 5:02 pm
The drive is really struggling to read the blu-ray discs and times out, likely as it is running out of power while trying to read the disc. You can start by cleaning those discs. This model drive is not very good. Try giving it more power.
Also, ensure you let the OS initialise the disc and you can see it in explorer before you open up the MakeMKV application.
You really should not be trying to play the blu-ray disc. Direct disc playback is not recommended as you will wear out your drive lasers a lot faster. Better to just rip and play the rip instead. You shouldn't need to install anything to use VLC as once you integrate VLC in MakeMKV, the latter will act as the on-the-fly decrypter.
George_b
Post by George_b »
Hello Marty
Thanks for the reply.
The conclusion is clear: I need to replace the drive.
Is there an updated list of compatible drives? The list I saw on the forum probably hasn’t been updated in a while. Unless, of course, manufacturers stopped developing this type of product a few years ago.
Have a great weekend, and thanks for the clarification.
George_b wrote:
Sun May 24, 2026 7:32 am
Hello Marty
The Ultimate UHD Drive Guide 2026 is kept up to date. Please note that as there are currently no optical drives being manufactured at all, what is left in the world is existing stock. You would be very hard pressed finding any internal drives and all that appears to be available are the external slim drives such as Verbatim 43888 and 43887, LG BP50NB40, LG BP60NB10.
