Hey Guys
New to Makemkv. I have ripped about 20 blu rays and had no problem. After I ripped Nation Treasure I started to receive a error message. Now even movies that ripped fine don't work.
Here is the log:
debug log started at Wed Dec 2 21:47:59 2009 , written by MakeMKV v1.4.9 beta darwin(x86-release)
001014:000000:0000 MakeMKV v1.4.9 beta darwin(x86-release) started
001013:000000:0000 Debug logging enabled, log will be saved as /Users/tomeckert/MakeMKV_log.txt
001012:000000:0020 FAILURE: Code 0 at fSxrS|A(s^T&@zxxNi2'W7V$14E:121264878
003010:000000:0000 Using direct disc access mode
001012:000000:0020 FAILURE: Code 2 at My/g>GiZ!RMU}"FdHgmP:213130582
001012:000000:0020 FAILURE: Code 0 at :Q8'ls\JRL\{9d+yfe:121261727
001012:000000:0020 FAILURE: Code 1 at :Q8'ls\JRL\{9d+yfe:121261727
001012:000000:0020 FAILURE: Code 2 at :Q8'ls\JRL\{9d+yfe:121261727
001012:000000:0020 FAILURE: Code 3 at :Q8'ls\JRL\{9d+yfe:121261727
001012:000000:0020 FAILURE: Code 4 at :Q8'ls\JRL\{9d+yfe:121261727
001012:000000:0020 FAILURE: Code 2 at My/g>GiZ!RMU}"FdHgmP:29393907
003311:000000:0000 Can't read AACS VID from disc - most likely current AACS host certificate is revoked by your drive
003302:000000:0000 The volume key is unknown for this disc - video can't be decrypted
001012:000000:0020 FAILURE: Code 0 at !Uud`<Q?DpwZ?V*RF*v:121263015
001012:000000:0020 FAILURE: Code 0 at !Uud`<Q?DpwZ?V*RF*v:213132652
005010:000000:0000 Failed to open disc
Application exited at Wed Dec 2 21:49:30 2009
Tom
EDIT: I am thinking my problem starting happening after I tried to rip Terminator Salvation. I was able to rip National Treasure but upon checking it the sound was all messed up. I have just downloaded Makemkv onto my windows machine and I end up with the same result.
Is it the Drives fault I could return it and get another one.
Please Advise
UPDATE: I exchanged my drive for a new unit and everything works again. So the question is how do you know what movies to rip and what to avoid?
