A-Team extended cut fails "Error while reading input"
foobar
#1 Post by foobar » Fri Apr 06, 2012 11:45 am
Trying to convert A-Team extended cut, but it fails with:
001003:0020 DEBUG: Code 0 at \O)d]cUwNU2iM saX!L:213130467
001003:0020 DEBUG: Code 0 at <W&1Ft-]kXBrh_iK@`\T^:121266097
001003:0020 DEBUG: Code 0 at 2CI+Q%bS[PIdIVdB;P/:213130329
001003:0020 DEBUG: Code 0 at 2CI+Q%bS[PIdIVdB;P/:213132146
001003:0020 DEBUG: Code 0 at 2CI+Q%bS[PIdIVdB;P/:213136355
001003:0020 DEBUG: Code 0 at 2CI+Q%bS[PIdIVdB;P/:29398001
005003:0000 Failed to save title 3 to file /mnt/laager/Filmer/The A-Team.mkv
There's a ton of base64(?)-encoded stuff before that in the log. I have the BD+ dump and the complete debug log, but forum only allows 1MB attachments. Let me know how to send you the files if you need them (dump is 13MB, log is 5MB gzipped).
Re: A-Team extended cut fails "Error while reading input"
#2 Post by mike admin » Fri Apr 13, 2012 3:41 pm
Please send BD+ dumps per instructions at http://www.makemkv.com/svq/
#3 Post by mike admin » Mon Apr 16, 2012 9:51 am
This is not a BD+ issue, please send compressed log file to the same email as well.
foobar
#4 Post by foobar » Mon Apr 16, 2012 11:44 am
mike admin wrote:This is not a BD+ issue, please send compressed log file to the same email as well.
Done!
foobar
#5 Post by foobar » Mon Apr 16, 2012 2:00 pm
The backup trick seems to have worked here. I.e. backing up the entire disc does not produce the above errors. I can then convert the decrypted files to a MKV without any issues.
