Problematic HD-DVDs
fganter
Re: Problematic HD-DVDs
#151 Post by fganter » Thu Mar 29, 2012 10:05 pm
paulster wrote:Yes, I noticed that the subtitle selection was missing.
Also, unless it was just the two titles I tried with last night, it doesn't seem to be bringing the titles for each of the tracks into MakeMKV any longer. These, in my opinion, should continue to pre-populate the 'name' field in MakeMKV.
It's not just your two titles. :)
dissident
#152 Post by dissident » Fri Mar 30, 2012 4:22 am
registered to say that The Interpreter does the same thing at the same spot as the previous post. That's the only problem disc I've had so far and I'm 60% of the way through doing about 80 movies before they rot or no software is left to read them. :) Sticking with 1.72 since it works and I want subtitles.
I know HD-DVD support is not a priority, and i'm just glad there's anything left at all to salvage all these sub three dollar purchases. :)
#153 Post by mike admin » Sat Mar 31, 2012 12:47 pm
The HD-DVD support was supposed to be improved in 1.7.3 by adding full support for profiles and metadata edit, but there are 3 confirmed bugs:
1. Subtitles are no longer available for selection/deselection
2. Minimum File Length is ignored
3. Track title is no longer read.
These should be fixed in the next version.
dissident
#154 Post by dissident » Sun Apr 01, 2012 2:05 am
well, I finished the last one. Very impressed that they all worked except the above aforementioned. I'd be willing to donate some to support development, but 50 Euros is a bit steep.
noeikujoo
#155 Post by noeikujoo » Mon Apr 16, 2012 1:19 pm
I have been using MakeMKV for ripping my HD-DVD movies for a couple of months and now I have a question about it. Why MakeMKV always sets HD-DVD movies wrong 29.97 fps frame? When I play MakeMKV-ripped mkv videos, my videoplayer (XBMC) changes refresh rate every time to 60Hz instead of 24Hz. XBMC plays other 23,976 fps mkv videos fine at 24Hz. Only MakeMKV ripped mkv videos are played at wrong 60 Hz refresh rate. I have to use mkvmerge to change frame rate to 23.976 fps, which is correct frame rate for movies.
Here is MKVinfo results from ripped file "The Matrix Reloaded.mkv":
(MKVInfo) + EBML head at 0
(MKVInfo) |+ EBML version: 1 at 5
(MKVInfo) |+ EBML read version: 1 at 9
(MKVInfo) |+ EBML maximum ID length: 4 at 13
(MKVInfo) |+ (Unknown element: EBMLMaxSizeLength; ID: 0x42f3 size: 4) at 17
(MKVInfo) |+ Doc type: matroska at 21
(MKVInfo) |+ Doc type version: 2 at 32
(MKVInfo) |+ Doc type read version: 2 at 36
(MKVInfo) + Segment, size 17224681702 at 40
(MKVInfo) |+ Seek head at 52
(MKVInfo) | + Seek entry at 57
(MKVInfo) |  + Seek ID: 0x15 0x49 0xa9 0x66 (KaxInfo) at 60
(MKVInfo) |  + Seek position: 1113 at 67
(MKVInfo) | + Seek entry at 78
(MKVInfo) |  + Seek ID: 0x16 0x54 0xae 0x6b (KaxTracks) at 81
(MKVInfo) |  + Seek position: 1256 at 88
(MKVInfo) | + Seek entry at 99
(MKVInfo) |  + Seek ID: 0x1c 0x53 0xbb 0x6b (KaxCues) at 102
(MKVInfo) |  + Seek position: 17224415568 at 109
(MKVInfo) | + Seek entry at 120
(MKVInfo) |  + Seek ID: 0x10 0x43 0xa7 0x70 (KaxChapters) at 123
(MKVInfo) |  + Seek position: 7009 at 130
(MKVInfo) |+ EbmlVoid (size: 1021) at 141
(MKVInfo) |+ Segment information at 1165
(MKVInfo) | + Timecode scale: 1000000 at 1171
(MKVInfo) | + Muxing application: libmakemkv v1.7.4 (1.2.0/1.1.0) i686-linux-gnu at 1178
(MKVInfo) | + Writing application: MakeMKV v1.7.4 linux(x86-release) at 1227
(MKVInfo) | + Duration: 8295.487s (02:18:15.487) at 1263
(MKVInfo) | + Title: PEVOB at 1270
(MKVInfo) | + Date: Sun Apr 15 05:55:51 2012 UTC at 1278
(MKVInfo) | + Segment UID: 0x33 0x06 0xc0 0xc7 0xbf 0x1d 0xce 0xcf 0xd4 0x21 0x3d 0xe7 0x64 0xff 0x31 0x01 at 1289
(MKVInfo) |+ Segment tracks at 1308
(MKVInfo) | + A track at 1314
(MKVInfo) |  + Track number: 1 at 1317
(MKVInfo) |  + Track UID: 1 at 1320
(MKVInfo) |  + Track type: video at 1324
(MKVInfo) |  + Default flag: 0 at 1327
(MKVInfo) |  + Lacing flag: 0 at 1330
(MKVInfo) |  + MinCache: 1 at 1333
(MKVInfo) |  + Codec ID: V_MS/VFW/FOURCC at 1337
(MKVInfo) |  + CodecPrivate, length 74 (FourCC: WVC1, 0x31435657) at 1354
(MKVInfo) |  + Default duration: 33.367ms (29.970 fps for a video track) at 1431
(MKVInfo) |  + Video track at 1439
(MKVInfo) |   + Pixel width: 1920 at 1441
(MKVInfo) |   + Pixel height: 1080 at 1445
(MKVInfo) |   + Display width: 1920 at 1449
(MKVInfo) |   + Display height: 1080 at 1454
(MKVInfo) | + A track at 1459
(MKVInfo) |  + Track number: 2 at 1461
(MKVInfo) |  + Track UID: 2 at 1464
(MKVInfo) |  + Track type: audio at 1468
(MKVInfo) |  + Codec ID: A_EAC3 at 1471
(MKVInfo) |  + Default duration: 16.000ms (62.500 fps for a video track) at 1479
(MKVInfo) |  + Name: 3/2+1 at 1486
(MKVInfo) |  + Audio track at 1494
(MKVInfo) |   + Sampling frequency: 48000 at 1496
(MKVInfo) |   + Channels: 6 at 1502
(MKVInfo) | + A track at 1505
(MKVInfo) |  + Track number: 3 at 1507
(MKVInfo) |  + Track UID: 3 at 1510
(MKVInfo) |  + Track type: audio at 1514
(MKVInfo) |  + Default flag: 0 at 1517
(MKVInfo) |  + Codec ID: A_TRUEHD at 1520
(MKVInfo) |  + Default duration: 0.833ms (1200.000 fps for a video track) at 1530
(MKVInfo) |  + Name: 5.1 at 1537
(MKVInfo) |  + Audio track at 1543
(MKVInfo) |   + Sampling frequency: 48000 at 1545
(MKVInfo) |   + Channels: 6 at 1551
(MKVInfo) |   + Bit depth: 24 at 1554
(MKVInfo) | + A track at 1558
(MKVInfo) |  + Track number: 4 at 1561
(MKVInfo) |  + Track UID: 4 at 1564
(MKVInfo) |  + Track type: subtitles at 1568
(MKVInfo) |  + Lacing flag: 0 at 1571
(MKVInfo) |  + Codec ID: S_VOBSUB at 1574
(MKVInfo) |  + CodecPrivate, length 512 at 1584
(MKVInfo) | + A track at 2100
(MKVInfo) |  + Track number: 5 at 2103
(MKVInfo) |  + Track UID: 5 at 2106
(MKVInfo) |  + Track type: subtitles at 2110
(MKVInfo) |  + Default flag: 0 at 2113
(MKVInfo) |  + Lacing flag: 0 at 2116
(MKVInfo) |  + Codec ID: S_VOBSUB at 2119
(MKVInfo) |  + Language: dan at 2129
(MKVInfo) |  + CodecPrivate, length 512 at 2136
(MKVInfo) | + A track at 2652
(MKVInfo) |  + Track number: 6 at 2655
(MKVInfo) |  + Track UID: 6 at 2658
(MKVInfo) |  + Track type: subtitles at 2662
(MKVInfo) |  + Default flag: 0 at 2665
(MKVInfo) |  + Lacing flag: 0 at 2668
(MKVInfo) |  + Codec ID: S_VOBSUB at 2671
(MKVInfo) |  + Language: fin at 2681
(MKVInfo) |  + CodecPrivate, length 512 at 2688
(MKVInfo) | + A track at 3204
(MKVInfo) |  + Track number: 7 at 3207
(MKVInfo) |  + Track UID: 7 at 3210
(MKVInfo) |  + Track type: subtitles at 3214
(MKVInfo) |  + Default flag: 0 at 3217
(MKVInfo) |  + Lacing flag: 0 at 3220
(MKVInfo) |  + Codec ID: S_VOBSUB at 3223
(MKVInfo) |  + Language: nor at 3233
(MKVInfo) |  + CodecPrivate, length 512 at 3240
(MKVInfo) | + A track at 3756
(MKVInfo) |  + Track number: 8 at 3759
(MKVInfo) |  + Track UID: 8 at 3762
(MKVInfo) |  + Track type: subtitles at 3766
(MKVInfo) |  + Default flag: 0 at 3769
(MKVInfo) |  + Lacing flag: 0 at 3772
(MKVInfo) |  + Codec ID: S_VOBSUB at 3775
(MKVInfo) |  + Language: swe at 3785
(MKVInfo) |  + CodecPrivate, length 512 at 3792
(MKVInfo) | + A track at 4308
(MKVInfo) |  + Track number: 9 at 4311
(MKVInfo) |  + Track UID: 9 at 4314
(MKVInfo) |  + Track type: subtitles at 4318
(MKVInfo) |  + Default flag: 0 at 4321
(MKVInfo) |  + Lacing flag: 0 at 4324
(MKVInfo) |  + Codec ID: S_VOBSUB at 4327
(MKVInfo) |  + CodecPrivate, length 512 at 4337
(MKVInfo) | + A track at 4853
(MKVInfo) |  + Track number: 10 at 4856
(MKVInfo) |  + Track UID: 10 at 4859
(MKVInfo) |  + Track type: subtitles at 4863
(MKVInfo) |  + Default flag: 0 at 4866
(MKVInfo) |  + Lacing flag: 0 at 4869
(MKVInfo) |  + Codec ID: S_VOBSUB at 4872
(MKVInfo) |  + Language: dan at 4882
(MKVInfo) |  + CodecPrivate, length 512 at 4889
(MKVInfo) | + A track at 5405
(MKVInfo) |  + Track number: 11 at 5408
(MKVInfo) |  + Track UID: 11 at 5411
(MKVInfo) |  + Track type: subtitles at 5415
(MKVInfo) |  + Default flag: 0 at 5418
(MKVInfo) |  + Lacing flag: 0 at 5421
(MKVInfo) |  + Codec ID: S_VOBSUB at 5424
(MKVInfo) |  + Language: fin at 5434
(MKVInfo) |  + CodecPrivate, length 512 at 5441
(MKVInfo) | + A track at 5957
(MKVInfo) |  + Track number: 12 at 5960
(MKVInfo) |  + Track UID: 12 at 5963
(MKVInfo) |  + Track type: subtitles at 5967
(MKVInfo) |  + Default flag: 0 at 5970
(MKVInfo) |  + Lacing flag: 0 at 5973
(MKVInfo) |  + Codec ID: S_VOBSUB at 5976
(MKVInfo) |  + Language: nor at 5986
(MKVInfo) |  + CodecPrivate, length 512 at 5993
(MKVInfo) | + A track at 6509
(MKVInfo) |  + Track number: 13 at 6512
(MKVInfo) |  + Track UID: 13 at 6515
(MKVInfo) |  + Track type: subtitles at 6519
(MKVInfo) |  + Default flag: 0 at 6522
(MKVInfo) |  + Lacing flag: 0 at 6525
(MKVInfo) |  + Codec ID: S_VOBSUB at 6528
(MKVInfo) |  + Language: swe at 6538
(MKVInfo) |  + CodecPrivate, length 512 at 6545
(MKVInfo) |+ Chapters at 7061
(MKVInfo) | + EditionEntry at 7067
(MKVInfo) |  + EditionFlagHidden: 0 at 7071
(MKVInfo) |  + EditionFlagDefault: 1 at 7075
(MKVInfo) |  + EditionUID: 2734008508614296590 at 7079
(MKVInfo) |  + ChapterAtom at 7090
(MKVInfo) |   + ChapterUID: 14042951966455494775 at 7092
(MKVInfo) |   + ChapterTimeStart: 00:00:00.000000000 at 7103
(MKVInfo) |   + ChapterFlagHidden: 0 at 7106
(MKVInfo) |   + ChapterFlagEnabled: 1 at 7109
(MKVInfo) |   + ChapterDisplay at 7113
(MKVInfo) |    + ChapterString: Chapter 00 at 7115
(MKVInfo) |    + ChapterLanguage: eng at 7127
(MKVInfo) |  + ChapterAtom at 7133
(MKVInfo) |   + ChapterUID: 10047965603978032645 at 7135
(MKVInfo) |   + ChapterTimeStart: 00:03:50.000000000 at 7146
(MKVInfo) |   + ChapterFlagHidden: 0 at 7153
(MKVInfo) |   + ChapterFlagEnabled: 1 at 7156
(MKVInfo) |   + ChapterDisplay at 7160
(MKVInfo) |    + ChapterString: Chapter 01 at 7162
(MKVInfo) |    + ChapterLanguage: eng at 7174
(MKVInfo) |  + ChapterAtom at 7180
(MKVInfo) |   + ChapterUID: 4811616872270117833 at 7182
(MKVInfo) |   + ChapterTimeStart: 00:08:54.833000000 at 7193
(MKVInfo) |   + ChapterFlagHidden: 0 at 7200
(MKVInfo) |   + ChapterFlagEnabled: 1 at 7203
(MKVInfo) |   + ChapterDisplay at 7207
(MKVInfo) |    + ChapterString: Chapter 02 at 7209
(MKVInfo) |    + ChapterLanguage: eng at 7221
(MKVInfo) |  + ChapterAtom at 7227
(MKVInfo) |   + ChapterUID: 10751288291989759942 at 7229
(MKVInfo) |   + ChapterTimeStart: 00:12:16.166000000 at 7240
(MKVInfo) |   + ChapterFlagHidden: 0 at 7247
(MKVInfo) |   + ChapterFlagEnabled: 1 at 7250
(MKVInfo) |   + ChapterDisplay at 7254
(MKVInfo) |    + ChapterString: Chapter 03 at 7256
(MKVInfo) |    + ChapterLanguage: eng at 7268
(MKVInfo) |  + ChapterAtom at 7274
(MKVInfo) |   + ChapterUID: 5758133538924275685 at 7276
(MKVInfo) |   + ChapterTimeStart: 00:16:23.333000000 at 7287
(MKVInfo) |   + ChapterFlagHidden: 0 at 7294
(MKVInfo) |   + ChapterFlagEnabled: 1 at 7297
(MKVInfo) |   + ChapterDisplay at 7301
(MKVInfo) |    + ChapterString: Chapter 04 at 7303
(MKVInfo) |    + ChapterLanguage: eng at 7315
(MKVInfo) |  + ChapterAtom at 7321
(MKVInfo) |   + ChapterUID: 15168338885121920968 at 7323
(MKVInfo) |   + ChapterTimeStart: 00:19:42.000000000 at 7334
(MKVInfo) |   + ChapterFlagHidden: 0 at 7342
(MKVInfo) |   + ChapterFlagEnabled: 1 at 7345
(MKVInfo) |   + ChapterDisplay at 7349
(MKVInfo) |    + ChapterString: Chapter 05 at 7351
(MKVInfo) |    + ChapterLanguage: eng at 7363
(MKVInfo) |  + ChapterAtom at 7369
(MKVInfo) |   + ChapterUID: 11216947536253788417 at 7371
(MKVInfo) |   + ChapterTimeStart: 00:23:28.000000000 at 7382
(MKVInfo) |   + ChapterFlagHidden: 0 at 7390
(MKVInfo) |   + ChapterFlagEnabled: 1 at 7393
(MKVInfo) |   + ChapterDisplay at 7397
(MKVInfo) |    + ChapterString: Chapter 06 at 7399
(MKVInfo) |    + ChapterLanguage: eng at 7411
(MKVInfo) |  + ChapterAtom at 7417
(MKVInfo) |   + ChapterUID: 3151597594336581595 at 7419
(MKVInfo) |   + ChapterTimeStart: 00:27:25.166000000 at 7430
(MKVInfo) |   + ChapterFlagHidden: 0 at 7438
(MKVInfo) |   + ChapterFlagEnabled: 1 at 7441
(MKVInfo) |   + ChapterDisplay at 7445
(MKVInfo) |    + ChapterString: Chapter 07 at 7447
(MKVInfo) |    + ChapterLanguage: eng at 7459
(MKVInfo) |  + ChapterAtom at 7465
(MKVInfo) |   + ChapterUID: 5296028095150824351 at 7467
(MKVInfo) |   + ChapterTimeStart: 00:31:59.333000000 at 7478
(MKVInfo) |   + ChapterFlagHidden: 0 at 7486
(MKVInfo) |   + ChapterFlagEnabled: 1 at 7489
(MKVInfo) |   + ChapterDisplay at 7493
(MKVInfo) |    + ChapterString: Chapter 08 at 7495
(MKVInfo) |    + ChapterLanguage: eng at 7507
(MKVInfo) |  + ChapterAtom at 7513
(MKVInfo) |   + ChapterUID: 12825836861636900835 at 7515
(MKVInfo) |   + ChapterTimeStart: 00:33:41.166000000 at 7526
(MKVInfo) |   + ChapterFlagHidden: 0 at 7534
(MKVInfo) |   + ChapterFlagEnabled: 1 at 7537
(MKVInfo) |   + ChapterDisplay at 7541
(MKVInfo) |    + ChapterString: Chapter 09 at 7543
(MKVInfo) |    + ChapterLanguage: eng at 7555
(MKVInfo) |  + ChapterAtom at 7561
(MKVInfo) |   + ChapterUID: 30792127867481615 at 7563
(MKVInfo) |   + ChapterTimeStart: 00:37:55.166000000 at 7573
(MKVInfo) |   + ChapterFlagHidden: 0 at 7581
(MKVInfo) |   + ChapterFlagEnabled: 1 at 7584
(MKVInfo) |   + ChapterDisplay at 7588
(MKVInfo) |    + ChapterString: Chapter 10 at 7590
(MKVInfo) |    + ChapterLanguage: eng at 7602
(MKVInfo) |  + ChapterAtom at 7608
(MKVInfo) |   + ChapterUID: 1301384572001288382 at 7610
(MKVInfo) |   + ChapterTimeStart: 00:40:53.166000000 at 7621
(MKVInfo) |   + ChapterFlagHidden: 0 at 7629
(MKVInfo) |   + ChapterFlagEnabled: 1 at 7632
(MKVInfo) |   + ChapterDisplay at 7636
(MKVInfo) |    + ChapterString: Chapter 11 at 7638
(MKVInfo) |    + ChapterLanguage: eng at 7650
(MKVInfo) |  + ChapterAtom at 7656
(MKVInfo) |   + ChapterUID: 6866335850755571054 at 7658
(MKVInfo) |   + ChapterTimeStart: 00:43:42.333000000 at 7669
(MKVInfo) |   + ChapterFlagHidden: 0 at 7677
(MKVInfo) |   + ChapterFlagEnabled: 1 at 7680
(MKVInfo) |   + ChapterDisplay at 7684
(MKVInfo) |    + ChapterString: Chapter 12 at 7686
(MKVInfo) |    + ChapterLanguage: eng at 7698
(MKVInfo) |  + ChapterAtom at 7704
(MKVInfo) |   + ChapterUID: 15637793627673473218 at 7706
(MKVInfo) |   + ChapterTimeStart: 00:50:39.666000000 at 7717
(MKVInfo) |   + ChapterFlagHidden: 0 at 7725
(MKVInfo) |   + ChapterFlagEnabled: 1 at 7728
(MKVInfo) |   + ChapterDisplay at 7732
(MKVInfo) |    + ChapterString: Chapter 13 at 7734
(MKVInfo) |    + ChapterLanguage: eng at 7746
(MKVInfo) |  + ChapterAtom at 7752
(MKVInfo) |   + ChapterUID: 9015604279760650918 at 7754
(MKVInfo) |   + ChapterTimeStart: 00:55:05.166000000 at 7765
(MKVInfo) |   + ChapterFlagHidden: 0 at 7773
(MKVInfo) |   + ChapterFlagEnabled: 1 at 7776
(MKVInfo) |   + ChapterDisplay at 7780
(MKVInfo) |    + ChapterString: Chapter 14 at 7782
(MKVInfo) |    + ChapterLanguage: eng at 7794
(MKVInfo) |  + ChapterAtom at 7800
(MKVInfo) |   + ChapterUID: 16275944815424920040 at 7802
(MKVInfo) |   + ChapterTimeStart: 00:59:59.500000000 at 7813
(MKVInfo) |   + ChapterFlagHidden: 0 at 7821
(MKVInfo) |   + ChapterFlagEnabled: 1 at 7824
(MKVInfo) |   + ChapterDisplay at 7828
(MKVInfo) |    + ChapterString: Chapter 15 at 7830
(MKVInfo) |    + ChapterLanguage: eng at 7842
(MKVInfo) |  + ChapterAtom at 7848
(MKVInfo) |   + ChapterUID: 8888401751872927289 at 7850
(MKVInfo) |   + ChapterTimeStart: 01:02:46.000000000 at 7861
(MKVInfo) |   + ChapterFlagHidden: 0 at 7869
(MKVInfo) |   + ChapterFlagEnabled: 1 at 7872
(MKVInfo) |   + ChapterDisplay at 7876
(MKVInfo) |    + ChapterString: Chapter 16 at 7878
(MKVInfo) |    + ChapterLanguage: eng at 7890
(MKVInfo) |  + ChapterAtom at 7896
(MKVInfo) |   + ChapterUID: 13521550763333855753 at 7898
(MKVInfo) |   + ChapterTimeStart: 01:08:48.166000000 at 7909
(MKVInfo) |   + ChapterFlagHidden: 0 at 7917
(MKVInfo) |   + ChapterFlagEnabled: 1 at 7920
(MKVInfo) |   + ChapterDisplay at 7924
(MKVInfo) |    + ChapterString: Chapter 17 at 7926
(MKVInfo) |    + ChapterLanguage: eng at 7938
(MKVInfo) |  + ChapterAtom at 7944
(MKVInfo) |   + ChapterUID: 189290283883805996 at 7946
(MKVInfo) |   + ChapterTimeStart: 01:13:02.500000000 at 7957
(MKVInfo) |   + ChapterFlagHidden: 0 at 7965
(MKVInfo) |   + ChapterFlagEnabled: 1 at 7968
(MKVInfo) |   + ChapterDisplay at 7972
(MKVInfo) |    + ChapterString: Chapter 18 at 7974
(MKVInfo) |    + ChapterLanguage: eng at 7986
(MKVInfo) |  + ChapterAtom at 7992
(MKVInfo) |   + ChapterUID: 7027007859705760729 at 7994
(MKVInfo) |   + ChapterTimeStart: 01:16:16.833000000 at 8005
(MKVInfo) |   + ChapterFlagHidden: 0 at 8013
(MKVInfo) |   + ChapterFlagEnabled: 1 at 8016
(MKVInfo) |   + ChapterDisplay at 8020
(MKVInfo) |    + ChapterString: Chapter 19 at 8022
(MKVInfo) |    + ChapterLanguage: eng at 8034
(MKVInfo) |  + ChapterAtom at 8040
(MKVInfo) |   + ChapterUID: 239693921763236281 at 8042
(MKVInfo) |   + ChapterTimeStart: 01:20:27.000000000 at 8053
(MKVInfo) |   + ChapterFlagHidden: 0 at 8061
(MKVInfo) |   + ChapterFlagEnabled: 1 at 8064
(MKVInfo) |   + ChapterDisplay at 8068
(MKVInfo) |    + ChapterString: Chapter 20 at 8070
(MKVInfo) |    + ChapterLanguage: eng at 8082
(MKVInfo) |  + ChapterAtom at 8088
(MKVInfo) |   + ChapterUID: 8632500780163740978 at 8090
(MKVInfo) |   + ChapterTimeStart: 01:22:42.166000000 at 8101
(MKVInfo) |   + ChapterFlagHidden: 0 at 8109
(MKVInfo) |   + ChapterFlagEnabled: 1 at 8112
(MKVInfo) |   + ChapterDisplay at 8116
(MKVInfo) |    + ChapterString: Chapter 21 at 8118
(MKVInfo) |    + ChapterLanguage: eng at 8130
(MKVInfo) |  + ChapterAtom at 8136
(MKVInfo) |   + ChapterUID: 5824827289947676886 at 8138
(MKVInfo) |   + ChapterTimeStart: 01:26:07.333000000 at 8149
(MKVInfo) |   + ChapterFlagHidden: 0 at 8157
(MKVInfo) |   + ChapterFlagEnabled: 1 at 8160
(MKVInfo) |   + ChapterDisplay at 8164
(MKVInfo) |    + ChapterString: Chapter 22 at 8166
(MKVInfo) |    + ChapterLanguage: eng at 8178
(MKVInfo) |  + ChapterAtom at 8184
(MKVInfo) |   + ChapterUID: 10705614973847891723 at 8186
(MKVInfo) |   + ChapterTimeStart: 01:29:47.500000000 at 8197
(MKVInfo) |   + ChapterFlagHidden: 0 at 8205
(MKVInfo) |   + ChapterFlagEnabled: 1 at 8208
(MKVInfo) |   + ChapterDisplay at 8212
(MKVInfo) |    + ChapterString: Chapter 23 at 8214
(MKVInfo) |    + ChapterLanguage: eng at 8226
(MKVInfo) |  + ChapterAtom at 8232
(MKVInfo) |   + ChapterUID: 11535056193635970415 at 8234
(MKVInfo) |   + ChapterTimeStart: 01:32:45.333000000 at 8245
(MKVInfo) |   + ChapterFlagHidden: 0 at 8253
(MKVInfo) |   + ChapterFlagEnabled: 1 at 8256
(MKVInfo) |   + ChapterDisplay at 8260
(MKVInfo) |    + ChapterString: Chapter 24 at 8262
(MKVInfo) |    + ChapterLanguage: eng at 8274
(MKVInfo) |  + ChapterAtom at 8280
(MKVInfo) |   + ChapterUID: 3705698266267178977 at 8282
(MKVInfo) |   + ChapterTimeStart: 01:37:05.000000000 at 8293
(MKVInfo) |   + ChapterFlagHidden: 0 at 8301
(MKVInfo) |   + ChapterFlagEnabled: 1 at 8304
(MKVInfo) |   + ChapterDisplay at 8308
(MKVInfo) |    + ChapterString: Chapter 25 at 8310
(MKVInfo) |    + ChapterLanguage: eng at 8322
(MKVInfo) |  + ChapterAtom at 8328
(MKVInfo) |   + ChapterUID: 16361154696095236334 at 8330
(MKVInfo) |   + ChapterTimeStart: 01:40:45.333000000 at 8341
(MKVInfo) |   + ChapterFlagHidden: 0 at 8349
(MKVInfo) |   + ChapterFlagEnabled: 1 at 8352
(MKVInfo) |   + ChapterDisplay at 8356
(MKVInfo) |    + ChapterString: Chapter 26 at 8358
(MKVInfo) |    + ChapterLanguage: eng at 8370
(MKVInfo) |  + ChapterAtom at 8376
(MKVInfo) |   + ChapterUID: 17257297987229683940 at 8378
(MKVInfo) |   + ChapterTimeStart: 01:44:51.500000000 at 8389
(MKVInfo) |   + ChapterFlagHidden: 0 at 8397
(MKVInfo) |   + ChapterFlagEnabled: 1 at 8400
(MKVInfo) |   + ChapterDisplay at 8404
(MKVInfo) |    + ChapterString: Chapter 27 at 8406
(MKVInfo) |    + ChapterLanguage: eng at 8418
(MKVInfo) |  + ChapterAtom at 8424
(MKVInfo) |   + ChapterUID: 7484217022660400689 at 8426
(MKVInfo) |   + ChapterTimeStart: 01:48:05.666000000 at 8437
(MKVInfo) |   + ChapterFlagHidden: 0 at 8445
(MKVInfo) |   + ChapterFlagEnabled: 1 at 8448
(MKVInfo) |   + ChapterDisplay at 8452
(MKVInfo) |    + ChapterString: Chapter 28 at 8454
(MKVInfo) |    + ChapterLanguage: eng at 8466
(MKVInfo) |  + ChapterAtom at 8472
(MKVInfo) |   + ChapterUID: 17290513780153790334 at 8474
(MKVInfo) |   + ChapterTimeStart: 01:52:18.833000000 at 8485
(MKVInfo) |   + ChapterFlagHidden: 0 at 8493
(MKVInfo) |   + ChapterFlagEnabled: 1 at 8496
(MKVInfo) |   + ChapterDisplay at 8500
(MKVInfo) |    + ChapterString: Chapter 29 at 8502
(MKVInfo) |    + ChapterLanguage: eng at 8514
(MKVInfo) |  + ChapterAtom at 8520
(MKVInfo) |   + ChapterUID: 14263932603574402240 at 8522
(MKVInfo) |   + ChapterTimeStart: 01:55:36.000000000 at 8533
(MKVInfo) |   + ChapterFlagHidden: 0 at 8541
(MKVInfo) |   + ChapterFlagEnabled: 1 at 8544
(MKVInfo) |   + ChapterDisplay at 8548
(MKVInfo) |    + ChapterString: Chapter 30 at 8550
(MKVInfo) |    + ChapterLanguage: eng at 8562
(MKVInfo) |  + ChapterAtom at 8568
(MKVInfo) |   + ChapterUID: 11877675377025954070 at 8570
(MKVInfo) |   + ChapterTimeStart: 01:57:30.500000000 at 8581
(MKVInfo) |   + ChapterFlagHidden: 0 at 8589
(MKVInfo) |   + ChapterFlagEnabled: 1 at 8592
(MKVInfo) |   + ChapterDisplay at 8596
(MKVInfo) |    + ChapterString: Chapter 31 at 8598
(MKVInfo) |    + ChapterLanguage: eng at 8610
(MKVInfo) |  + ChapterAtom at 8616
(MKVInfo) |   + ChapterUID: 15219382242482490238 at 8618
(MKVInfo) |   + ChapterTimeStart: 02:01:44.166000000 at 8629
(MKVInfo) |   + ChapterFlagHidden: 0 at 8637
(MKVInfo) |   + ChapterFlagEnabled: 1 at 8640
(MKVInfo) |   + ChapterDisplay at 8644
(MKVInfo) |    + ChapterString: Chapter 32 at 8646
(MKVInfo) |    + ChapterLanguage: eng at 8658
(MKVInfo) |  + ChapterAtom at 8664
(MKVInfo) |   + ChapterUID: 7936160652985236707 at 8666
(MKVInfo) |   + ChapterTimeStart: 02:04:11.000000000 at 8677
(MKVInfo) |   + ChapterFlagHidden: 0 at 8685
(MKVInfo) |   + ChapterFlagEnabled: 1 at 8688
(MKVInfo) |   + ChapterDisplay at 8692
(MKVInfo) |    + ChapterString: Chapter 33 at 8694
(MKVInfo) |    + ChapterLanguage: eng at 8706
(MKVInfo) |  + ChapterAtom at 8712
(MKVInfo) |   + ChapterUID: 10261319478995504908 at 8714
(MKVInfo) |   + ChapterTimeStart: 02:06:56.500000000 at 8725
(MKVInfo) |   + ChapterFlagHidden: 0 at 8733
(MKVInfo) |   + ChapterFlagEnabled: 1 at 8736
(MKVInfo) |   + ChapterDisplay at 8740
(MKVInfo) |    + ChapterString: Chapter 34 at 8742
(MKVInfo) |    + ChapterLanguage: eng at 8754
(MKVInfo) |  + ChapterAtom at 8760
(MKVInfo) |   + ChapterUID: 9044935852061366099 at 8762
(MKVInfo) |   + ChapterTimeStart: 02:16:21.500000000 at 8773
(MKVInfo) |   + ChapterFlagHidden: 0 at 8781
(MKVInfo) |   + ChapterFlagEnabled: 1 at 8784
(MKVInfo) |   + ChapterDisplay at 8788
(MKVInfo) |    + ChapterString: Chapter 35 at 8790
(MKVInfo) |    + ChapterLanguage: eng at 8802
(MKVInfo) |+ EbmlVoid (size: 1021) at 8808
(MKVInfo) |+ Cluster at 9832
#156 Post by SamuriHL » Mon Apr 16, 2012 1:24 pm
It's not "setting" anything. It's simply not removing pulldown flags.
paulster
#157 Post by paulster » Mon Apr 16, 2012 5:17 pm
It's doing exactly what it does with DVDs too, which is leaving the pulldown flags intact.
The easiest way I've found to deal with this is to let MakeMKV create the MKV, then use eac3to to extract the video track which, by default, will remove the pulldown.
The command will be something like this for a VC1 video track:
eac3to filename.mkv 1:video.vc1
which will give you a file called video.vc1.
Then remux it back into your original MKV in place of the existing video track.
noeikujoo
#158 Post by noeikujoo » Tue Apr 17, 2012 6:25 am
I fixed frame rate problem using mkvpropedit without a complete remux. I only set the default duration of one frame again in nanoseconds:
mkvpropedit The.Matrix.Reloaded.mkv --edit track:v1 --set default-duration=41708333
After this change, XBMC plays The.Matrix.Reloaded.mkv file correctly in 1920x1080@24 Hz mode. Maybe mvkpropedit removes pulldown flags?
Smithcraft
#159 Post by Smithcraft » Thu Apr 19, 2012 8:15 am
I just change the frame rate in mkvtoolnix...
SC
paulster
#160 Post by paulster » Wed May 02, 2012 7:53 pm
Just discovered the same type of problem with The Fast and the Furious.
UK release, Universal, VC1, DD+
MakeMKV v1.7.4 win(x86-release) started
DEBUG: Code 89 at N_k>K3P8-cW<p:213132261
DEBUG: Code 0 at N_k>K3P8-cW<p:121261773
This happens on the original disc and also on an ISO version of the same disc created with AnyDVD HD.
richdmoore
#161 Post by richdmoore » Wed May 02, 2012 10:10 pm
This is a weird one. I am trying to rip the main movie from U-571 HD-DVD. I previously ripped the file a couple of years ago (1.6 version of MakeMKV I think.) Anyway, I was in the process of finally converting those files to an apple TV format, when I suffered a hard drive failure, losing the MKV rip.
I am trying to rerip this disc, using the latest version, but for some reason it is not finding the main movie, instead it just shows all the other bonus features. I am using the exact same drive and disc. Other rips are working fine, it just is this disc is is not finding the main feature.
Here is the log when it reads the disc (I did not rip as it didn't have the main movie I need.)
MakeMKV v1.7.4 darwin(x86-release) started
Debug logging enabled, log will be saved as /Users/Rich/MakeMKV_log.txt
DEBUG: Code 3758097095 at )-Mqhyy_)SWO8\(`D^R:(0g_h8: :29394896
Optical drive "BD-ROM TOSHIBA DVD/HD X807616 MC08" opened in OS access mode.
It's highly recommended to install DASPI kernel extension to improve performance.
Optical drive "DVD+R-DL OPTIARC DVD RW AD-5680H 3AHF" opened in OS access mode.
DEBUG: Code 0 at p~w2<|Kvf:#w+R.k|:121262164
DEBUG: Code 8 at WoxGC4d>2OO0Su=`b<:121261980
Title #BLACK.EVO has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #UNILOGO.EVO has length of 29 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #MAININTRO.EVO has length of 61 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #MAINLOOP.EVO has length of 57 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #NAVY.EVO has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
DEBUG: Code 0 at ]2u)}$8IK91R8US|-8@:121264027
DEBUG: Code 0 at ]2u)}$8IK91R8US|-8@:213130674
DEBUG: Code 0 at 8}q6EMNDYKKjtE\Znw+F:29394045
DEBUG: Code 10 at 8}q6EMNDYKKjtE\Znw+F:29393332
DEBUG: Code 0 at rwSRAEneK ,w80J+ ;zah:29394091
DEBUG: Code 0 at rwSRAEneK ,w80J+ ;zah:213130996
DEBUG: Code 0 at 5-^?\c"L0aDh]*!hQ5}:121266902
DEBUG: Code 2 at QH;pV*/IL7W;Zk(p:121262233
DEBUG: Code 0 at fU-ZJm%$.JYxCa^:29399956
adydula
#162 Post by adydula » Mon May 07, 2012 12:30 pm
Any Ideas on if Troy, the very long 2+ hr HD DVD can be fixed etc...the reports seem to be that very long movies like this have 'overlay' errors when trying to make the mkv file....goes almost to the end and errors out.
Alex
jdastas
#163 Post by jdastas » Sat Jun 16, 2012 3:31 am
adydula wrote:Any Ideas on if Troy, the very long 2+ hr HD DVD can be fixed etc...the reports seem to be that very long movies like this have 'overlay' errors when trying to make the mkv file....goes almost to the end and errors out.
Alex
I'm having this same issue with "Chronicles of Reddick"... I get the option to rip all bonus features but not the main title...
sauron
#164 Post by sauron » Mon Sep 17, 2012 8:53 pm
I'm also having the same issue with Chronicals of Riddick
1) The Chronicals of Riddick (unrated directors cut)
2) Universal
5) Main Feature not listed in Titles.
6) Debug log
MakeMKV v1.7.71 darwin(x86-release) started
Debug logging enabled, log will be saved as /Users/markf/MakeMKV_log.txt
Optical drive "HD-DVD-ROM HL-DT-ST BD-RE GGW-H20L YL02" opened in DASPI v1.3 mode.
DEBUG: Code 0 at wJELx3Uz9yj9F$WJ7:121262164
Title #MAININTRO.EVO has length of 65 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #MAINLOOP.EVO has length of 61 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #INTRO.EVO has length of 45 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #VG_CONQUEST.EVO has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #GD_CONQUESTICON.EVO has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #GD_CREAMAKYRA.EVO has length of 27 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #GD_CREMTOOMBS.EVO has length of 27 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #GD_ELEMAEREON.EVO has length of 34 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #GD_ELEMDAMEV.EVO has length of 27 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #GD_HELIONPRIME.EVO has length of 35 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #GD_LORDMARSH.EVO has length of 49 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #GD_MECCAIMAM.EVO has length of 35 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #GD_MMINTRO.EVO has length of 42 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #GD_MMLOOP.EVO has length of 39 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #GD_NECROAEREON.EVO has length of 36 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #GD_NECRODAMEV.EVO has length of 39 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #GD_NECROLORD.EVO has length of 43 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #GD_PLANETUV.EVO has length of 28 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #GD_QUASIDEADS.EVO has length of 41 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #GD_SLCT_AERDAME.EVO has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #GD_SLCT_KRYTOOM.EVO has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
DEBUG: Code 0 at PtnpM|wARiGv4F6[@Mf:121264027
DEBUG: Code 0 at PtnpM|wARiGv4F6[@Mf:213130674
DEBUG: Code 0 at XF*/LI/0.b#Na4s&o6?f:213130743
DEBUG: Code 8 at XF*/LI/0.b#Na4s&o6?f:29393332
DEBUG: Code 0 at S,raz$zYb?;(x^5=Jo|uv:213130352
DEBUG: Code 0 at S,raz$zYb?;(x^5=Jo|uv:121262647
DEBUG: Code 0 at rcPG5y10}XguNfYh~,g:121266902
DEBUG: Code 2 at fh/wMPVIWX![Z@i::121262233
DEBUG: Code 0 at T|0;DA8coLp#Rc[:121268397
mrgstiffler
#165 Post by mrgstiffler » Sat Jan 12, 2013 10:07 am
I know this is old but I'm wondering if there's a solution to the Riddick problem. The main feature doesn't show up in the list of titles.
