Force Flash optical drive BP50NB40 to BU40N
Novation12
#1 Post by Novation12 » Fri May 22, 2026 3:05 pm
I'm hoping someone can give me some advice to force flash my BU50N optical drive to the correct firmware.
The drive has the wrong firmware. I know the drive is a BU50N and that one of the admins on this site said to treat the drive as BU40N, so I have tried flashing via the SDFtool Flasher & Makemkv built in flasher. The both completed sucseesfully but the drive info is still the same (BD-RE BP50NB40).
Product: BD-RE BP50NB40
Revision: 1.03
Serial number: *********
Highest AACS version: 57
The firmware I have attempted to flash to is HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934
I would appreciate some advice please,
Thanks in advance.
Re: Force Flash optical drive BP50NB40 to BU40N
#2 Post by Billycar11 » Fri May 22, 2026 4:06 pm
see guide below you may need to follow nb52 steps and there is a new boot code section you can use for nb52 drives
or email me or marty for an auto flasher
Novation12
#3 Post by Novation12 » Fri May 22, 2026 5:56 pm
Hi Billycar11,
Thank you for your reply.
I managed to use the crossflash method to get the correct firmware on the drive.
makemkvcon64.exe f --all-yes -d D: rawflash "main,nowait,nocheck,boot=MT1959 Boot BUP3"
All good now :D
Product: BD-RE BU40N
Revision: 1.03
Serial number: **************
Firmware version: 1.03
