BU50N Firmware Help
Abby1680
BU50N Firmware Help
Post by Abby1680 »
Hi, recently I purchased what I thought was BU50N from amazon with the hope of using sdftool to flash BU40N firmware onto it for 4K ripping but ran into an issue when I opened makemkv and noticed the drive info. Is there any way to make this drive work or should I just return the drive.
Screenshot 2026-05-19 180159.png (24.46 KiB) Viewed 2586 times
Screenshot 2026-05-19 180145.png (99.91 KiB) Viewed 2586 times
OneDay
Re: BU50N Firmware Help
Post by OneDay »
How do you have the drive hooked up?
The Info in Makemkv is incomplete.
I would return it.
Abby1680
Post by Abby1680 »
I am using a Slimline Sata to USB 3.0 adapter
That is what I thought as well so I already started the return.
Thank you for the reply
Issue is the adapter
Get an approved one from the guide below
Abby1680
Post by Abby1680 »
Will do Billy.
I will update once the new adapter arrives.
Abby1680
Post by Abby1680 »
Update. I have received the new adapter and it works like a charm.
Thank you Billy.
Screenshot 2026-05-21 192841.png (123.01 KiB) Viewed 2366 times
