ASUS BW-16D1X-U
OneDay
Re: ASUS BW-16D1X-U
Post by OneDay » Tue May 12, 2026 10:40 pm
skyrider wrote: Tue May 12, 2026 9:02 pm
OneDay wrote: Tue May 12, 2026 3:43 am
skyrider wrote: Mon May 11, 2026 11:32 pm Have you ever come across an Asus BW‑16D1H‑U Pro with a serial number starting with M4…?
I'm wondering what's inside that unit.
Looks like manufacturing date of April 2021.
If the BW-16D1H-U follows the same pattern as the BW-1601X-U then it should have a Pioneer inside.
Thanks for the information. So, would a serial number starting with K6… indicate a drive manufactured in June 2019?
Do you happen to know whether LG or Pioneer drives were being installed in 2019?
K=2019
6=June
Pioneer or LG? Maybe a LG BH50N
Usually if the Month code is 1-4 it's a Pioneer and anything after that its a LG. I've also read someone had a Pioneer drive with month December.
Honestly all drives i bought have been from 2024 to now.
If we could get members to post their manufacture date with what type of drive they have it could help eliminate the guessing.
Just wanted to add if your buying from someone on ebay you could ask them to show the sled ejected and if it has Asus on the sled front panel it is a LG.
Makar
Re: ASUS BW-16D1X-U
Post by Makar » Tue May 19, 2026 8:22 pm
I'm looking at a drive from October 2023.
Does anyone have any insight on that month?
Thanks.
Re: ASUS BW-16D1X-U
Post by Billycar11 » Tue May 19, 2026 10:16 pm
Makar wrote: Tue May 19, 2026 8:22 pm I'm looking at a drive from October 2023.
Thanks.
All should be flashable now
Makar
Re: ASUS BW-16D1X-U
Post by Makar » Wed May 20, 2026 2:04 am
Flashable sure, but is it likely to be a Pioneer 212?
Re: ASUS BW-16D1X-U
Post by Billycar11 » Wed May 20, 2026 11:52 am
Makar wrote: Wed May 20, 2026 2:04 am Flashable sure, but is it likely to be a Pioneer 212?
no one knows
OneDay
Re: ASUS BW-16D1X-U
Post by OneDay » Wed May 20, 2026 8:30 pm
Thanks.
Have the seller send you picture of the drive ejected and showing the front face plate. If you see Asus on the tray front face plate it is a BH50N a LG 16NS40 drive. If you see a plan looking front face plate it a Pioneer BDR-209DBK(212T) drive.
skyrider
Re: ASUS BW-16D1X-U
Post by skyrider » Thu Jun 11, 2026 10:09 pm
Does anyone happen to have the original firmware for the Asus BW‑16D1X‑U (LG) version A105?
Looking for a Pioneer 4K UHD drive?
Click here
