Pioneer BDR-S13UBK Stopped Working
creator
Re: Pioneer BDR-S13UBK Stopped Working
Post by creator »
I've updated to 1.18.3 and the issue persists, unfortunately. Always hung up on /AACS/ContentHash001.tbl. I tried OWC and NeStar enclosures, but neither worked.
hk download issue?
creator
Post by creator »
Billycar11 wrote: Tue Apr 21, 2026 2:54 am hk download issue?
Among other messages, this goes on forever until I click cancel:
Error 'Scsi error - HARDWARE ERROR:INTERNAL TARGET FAILURE' occurred while issuing SCSI command A30..00200740100720..081D282F875DD2F118FC3972CE985605F88 to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom0'
Here is the output after canceling, with an hk download issue (my username replaced with *****):
Downloading latest HK to C:\Users\*****/.MakeMKV ...
creator wrote: Tue Apr 21, 2026 4:11 am
thats your issue
figure out why your internet can connect to russia or use the keydb viewtopic.php?f=12&t=38293
creator
Post by creator »
Billycar11 wrote: Tue Apr 21, 2026 4:27 am thats your issue
Would this be drive dependent? I have an LG drive that works without any issues.
creator wrote: Wed Apr 22, 2026 12:09 am
Not sure maybe your not so UHD on you LG
Only UHD requires th HK or keydb
Go download them and you will be done maybe you need sdf file too that can be found in guide
VECT0R
Post by VECT0R »
Good evening,
I found some time and am taking another crack at this. I downloaded the keydb.cfg and placed it in my users/[user]/Library/MakeMKV folder. I am still seeing identical errors with the new keydb.cfg. I confirmed my MakeMKV install is looking at the correct file. The file was not zipped when I downloaded it. I did rename it to KEYBD.cfg just in case.
Any additional help is appreciated!
VECT0R wrote: Wed May 20, 2026 3:41 am Good evening,
did makemkv move it into the tar file?
VECT0R
Post by VECT0R »
I am not seeing a keybd.cfg file in the _private_data.tar file. I *am* seeing many hkd_[xxx].bin files in the .tar file.
VECT0R wrote: Wed May 20, 2026 9:08 pm I am not seeing a keybd.cfg file in the _private_data.tar file. I *am* seeing many hkd_[xxx].bin files in the .tar file.
Did the keydb file disappear? From that directory
VECT0R
Post by VECT0R »
Billycar11 wrote: Wed May 20, 2026 11:16 pm
Attached is a screen cap of my MakeMKV data file. All of the files above the ones shown in the _private_data.tar folder are also hkd_.[xxx].bin files and two index.bin files at the very top.
Let me know what I should be looking for. Thanks!
Screenshot 2026-05-22 at 11.47.55 AM.png (209.17 KiB) Viewed 2554 times
VECT0R wrote: Fri May 22, 2026 8:30 pm
pretty sure if key db was working makemkv would merge it in to its hk files and remove the keydb.cfg i will have to double check
how is this drive connected could be a adapter that does not pass through libredrive commands
did it ever work for UHD?
VECT0R
Post by VECT0R »
Billycar11 wrote: Sat May 23, 2026 12:26 am
Billycar11 wrote: Wed May 20, 2026 11:16 pm Did the keydb file disappear? From that directory
I've been able to open Blu-Rays in the past no problem. My first post in this thread is about the time it stopped working with the aforementioned errors. It can currently open DVDs (but so can my crappy LG). The connection chain is BDR->OWC Mercury External Housing->OWC TB3 Dock->Laptop. It worked in this configuration for years before it suddenly stopped. I have also tried directly connecting the housing to my Linux machine and received the same errors. I have a new housing on order as part of my next test steps.
I really appreciate the help!
