Pioneer BDR-S13UBK Stopped Working
creator
Re: Pioneer BDR-S13UBK Stopped Working
#16 Post by creator » Tue Apr 21, 2026 2:41 am
I've updated to 1.18.3 and the issue persists, unfortunately. Always hung up on /AACS/ContentHash001.tbl. I tried OWC and NeStar enclosures, but neither worked.
#17 Post by Billycar11 » Tue Apr 21, 2026 2:54 am
hk download issue?
creator
#18 Post by creator » Tue Apr 21, 2026 4:11 am
Billycar11 wrote: Tue Apr 21, 2026 2:54 am hk download issue?
Among other messages, this goes on forever until I click cancel:
Error 'Scsi error - HARDWARE ERROR:INTERNAL TARGET FAILURE' occurred while issuing SCSI command A30..00200740100720..081D282F875DD2F118FC3972CE985605F88 to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom0'
Here is the output after canceling, with an hk download issue (my username replaced with *****):
Downloading latest HK to C:\Users\*****/.MakeMKV ...
#19 Post by Billycar11 » Tue Apr 21, 2026 4:27 am
creator wrote: Tue Apr 21, 2026 4:11 am
thats your issue
figure out why your internet can connect to russia or use the keydb viewtopic.php?f=12&t=38293
creator
#20 Post by creator » Wed Apr 22, 2026 12:09 am
Billycar11 wrote: Tue Apr 21, 2026 4:27 am thats your issue
Would this be drive dependent? I have an LG drive that works without any issues.
#21 Post by Billycar11 » Wed Apr 22, 2026 12:21 am
creator wrote: Wed Apr 22, 2026 12:09 am
Not sure maybe your not so UHD on you LG
Only UHD requires th HK or keydb
Go download them and you will be done maybe you need sdf file too that can be found in guide
VECT0R
#22 Post by VECT0R » Wed May 20, 2026 3:41 am
Good evening,
I found some time and am taking another crack at this. I downloaded the keydb.cfg and placed it in my users/[user]/Library/MakeMKV folder. I am still seeing identical errors with the new keydb.cfg. I confirmed my MakeMKV install is looking at the correct file. The file was not zipped when I downloaded it. I did rename it to KEYBD.cfg just in case.
Any additional help is appreciated!
#23 Post by Billycar11 » Wed May 20, 2026 11:40 am
VECT0R wrote: Wed May 20, 2026 3:41 am Good evening,
did makemkv move it into the tar file?
VECT0R
#24 Post by VECT0R » Wed May 20, 2026 9:08 pm
I am not seeing a keybd.cfg file in the _private_data.tar file. I *am* seeing many hkd_[xxx].bin files in the .tar file.
#25 Post by Billycar11 » Wed May 20, 2026 11:16 pm
VECT0R wrote: Wed May 20, 2026 9:08 pm I am not seeing a keybd.cfg file in the _private_data.tar file. I *am* seeing many hkd_[xxx].bin files in the .tar file.
Did the keydb file disappear? From that directory
VECT0R
#26 Post by VECT0R » Fri May 22, 2026 8:30 pm
Billycar11 wrote: Wed May 20, 2026 11:16 pm
Attached is a screen cap of my MakeMKV data file. All of the files above the ones shown in the _private_data.tar folder are also hkd_.[xxx].bin files and two index.bin files at the very top.
Let me know what I should be looking for. Thanks!
Screenshot 2026-05-22 at 11.47.55 AM.png (209.17 KiB) Viewed 10893 times
#27 Post by Billycar11 » Sat May 23, 2026 12:26 am
VECT0R wrote: Fri May 22, 2026 8:30 pm
pretty sure if key db was working makemkv would merge it in to its hk files and remove the keydb.cfg i will have to double check
how is this drive connected could be a adapter that does not pass through libredrive commands
did it ever work for UHD?
VECT0R
#28 Post by VECT0R » Mon May 25, 2026 4:00 am
Billycar11 wrote: Sat May 23, 2026 12:26 am
Billycar11 wrote: Wed May 20, 2026 11:16 pm Did the keydb file disappear? From that directory
I've been able to open Blu-Rays in the past no problem. My first post in this thread is about the time it stopped working with the aforementioned errors. It can currently open DVDs (but so can my crappy LG). The connection chain is BDR->OWC Mercury External Housing->OWC TB3 Dock->Laptop. It worked in this configuration for years before it suddenly stopped. I have also tried directly connecting the housing to my Linux machine and received the same errors. I have a new housing on order as part of my next test steps.
I really appreciate the help!
Kevin_542
#29 Post by Kevin_542 » Sat Aug 29, 2026 1:11 pm
Wanted to add my experiences and solution to a similar situation regarding the Pioneer BDR-S13EBK 1.05 as this thread helped me on the path getting past the issue I encountered.
FYI my drive information:
OS device name: /dev/sr9
Manufacturer: PIONEER
Product: BD-RW BDR-S13U
Revision: 1.05
Serial number:
Firmware date: 2023-08-01
Highest AACS version: 82
Drive platform: RS9201
Firmware name: PIONEER BDR-213T
Firmware version: 1.05/ID43
I had a configuration with the drive in an OWC Mercury Pro, plugged into a powered USB 3 hub, that was giving me errors like this on attempts to rip Blurays and UHDs right from the start:
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A30..0020..03F to device 'SG:dev_21:10'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SG:dev_21:10'
The AACS dump file "MKB20_v72_Beetlejuice_833D.tgz" was successfully sent for analysis
The solution I had was to remove the drive from OWC Mercury Pro enclosure entirely, and use a different SATA to USB3 adapter. (In my case A Benfei USB 3.0 to SATA III Hard Drive Adapter with a SATA extension cable + a separate disc duplicator based SATA power source)
#30 Post by Billycar11 » Sat Aug 29, 2026 3:25 pm
Kevin_542 wrote: Sat Aug 29, 2026 1:11 pm Wanted to add my experiences and solution to a similar situation regarding the Pioneer BDR-S13EBK 1.05 as this thread helped me on the path getting past the issue I encountered.
Revision: 1.05
Serial number:
this is sad news
as the owc works on old pioneer fw
the new exploit must not get passed through on the owc for 12/22+ fw on pioneers
my recommendation for sata drives is to just use them sata from now on then
