Bluray Stuck Parsing BDMV
JimJames63
Post by JimJames63 » Wed May 20, 2026 1:11 am
New Bluray disc The Children's Hour
disc loads then parsing appears stuck on endless retry of a surprisingly large 1GB file
/BDMV/JAR/08267/08267.pdt
while decoding contents
Using Java runtime from C:\Program Files\Java\jre1.8.0_441\bin\java.exe
parsing file /BDMV/JAR/08267/08267.pdt
same file name flashes intermittently like its being parsed over and over
stuck in a loop?
never ends in 15 mins
Manufacturer: PIONEER
Product: BD-RW BDR-S13U
Revision: 1.02
Serial number: CLDL003828WL
Firmware date: 2022-02-16
Highest AACS version: 82
Drive platform: RS9201
Firmware name: PIONEER BDR-213T
Firmware version: 1.02/ID43
Disc Information
Label: THE CHILDRENS HOUR
Timestamp: 2018-05-14 17:30:44
Protection: AACS v64
Data capacity: 27.99 Gb
Disc type: BD-ROM
Number of layers: 2
Ezatoka
Re: Bluray Stuck Parsing BDMV
Post by Ezatoka » Thu May 21, 2026 1:51 pm
You could try using another Java version. For example download a current LTS release from Adoptium and point MakeMKV in the settings to the path where the java.exe of that installation lies.
