Hamlet (2009) - DBG ASSERT error
captain
Post by captain »
DBG ASSERT: FccRAeGj'a+RkQW,Ly{a?]Ay}Vhrmxr]We56Q at y+\%!'z)J<ki#1;?]6iI:213130835
repeat about 100 times... then ripping commences. Last try, I came back 20hrs later to find it hung. 2nd try is 900mb into it.
Re: Hamlet (2009) - DBG ASSERT error
Post by mike admin »
Does it happen with the latest version, 1.7.4 ? Any other errors? Can you please post ( or send to support@makemkv.com ) the full log file?
captain
Post by captain »
Last night, I did a second try with 1.7.3. I powercycled the blu-ray drive, and ensured that makemkvcon was killed, before: powering up the drive, restarting MakeMKV, and inserting the disc. (I'm not entirely convinced that the order has any bearing, but that's what I do to try to be sure MakeMKV gets full access to the drive before OSX can do anything weird)
Previous tests were done with 1.7.3. I discovered a 500mb log file this morning, along with a notice that MakeMKV was crashing and terminating. How can I send you a 500mb giant logfile?** I also used Activity Monitor to take a process sample, taken during the bog-down, (last night before the crash). Let me know if you still want those files, and/or the logfile from this current rip with 1.7.4.
This morning, I am getting the same DBG messages with 1.7.4 now, but it is getting farther into the rip before changing the error messages to:
DEBUG: Code 1269 at Tj*%dI&b88P/HY9z)Iayk:121261796
DEBUG: Code 1270 at Tj*%dI&b88P/HY9z)Iayk:121261796
DEBUG: Code 1271 at Tj*%dI&b88P/HY9z)Iayk:121261796
DEBUG: Code 1272 at Tj*%dI&b88P/HY9z)Iayk:121261796
and then bogging down; halfway through the rip rather than 1/10 though. Progress! But it took 25 minutes to get halfway through, and now the estimate to complete is just climbing... now past 3 hours. I'm pretty sure this is another failed rip. Interestingly, the "output size" is still growing, and the rip speed showing 0.8x, but the progress bars are not moving, and the time to complete is just growing growing growing...
PS: The disc is about as clean as a disc gets. No visible errors, and only extremely minor dust/scratches. It's all but clean-room clean. I rubbed it on my shirt to at least move around any noseeum dust bits. I'll probably return this disc for another one, to see if it is just a bad disc.
** I can probably set up a temporary web/ftp/file server here, so you can download the data. If I can figure out how to password protect such a thing, I'll send you access instructions.
PPS: Epic fail! :-( Report bars haven't moved in a half-hour. I need to reboot the POS CRAPple now.
captain
Post by captain »
Brand new disc today, using MakeMKV 1.7.4. SSDD. DBG ASSERT errors, and then sloooooooow ripping with time to finish estimate constantly climbing. It seems insane that BBC would be the ones to develop a DRM to stump the Great Mike! What shall I do to help here?
captain
Post by captain »
Well, it's killing MakeMKV. "MakeMKV (Not Responding)", i.e. crashed. Spinning Gay Beachball of death. :-( ... or is it? I see that it's using 95% CPU, 95, 94, 96... So, it isn't totally crashed.... I have no idea what is going on here.
captain
Post by captain »
I think I managed to get a full-disc backup by leaving it running for about a day. I wonder how much life I just took out of my bluray drive...! :-o
I'm trying a single title rip again. Will put the half-gig logfile up somewhere....
Ravik
Post by Ravik »
Encountered this issue with MakeMKV v1.9.00 (x64). The disc is brand new and the surface is flawless (My Cousin Vinny, 1992). Any chance its a newer type of encryption?
Debug log would sure be helpful.... MakeMKV outputs a lot of debug messages when it encounters weird stuff on disks, and the SPECIFIC messages tell Mike what work-arounds are being tried.
Ravik
Post by Ravik »
Here's a DEBUG log for a more recent attempt at Ghostbusters. The following asserts occur immediately at the beginning of the MT2S verification process. It also doesn't seem to affect the ability to open the INDEX file in MakeMKV after the fact...so I'm not sure really how much of an issue it is except that MakeMKV isn't expecting it:
Debug log started at Thu Dec 04 00:35:16 2014 , written by MakeMKV v1.9.0 win(x64-release)
001005:0000 MakeMKV v1.9.0 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\_____/MakeMKV_log.txt
005072:0000 Backing up disc into folder "C:\My Movies/backup/GHOSTBUSTERS"
DAFD=PAAAADAAAAEABDQkEFwECAQ==
DCE=LPZO6NfzSWK9F7AnpxbF5QO7eFgMbirZTu+YXNga/nHWY32x3jkWF/WsxHacD9TlEHlwjOp9zE7RKj8jw6AZFT8bGphKXD/Yf89vTezZL7HyFsBHuZmHp9XMJHSY9pSOg/wMe92W51jqlKRmQmxJiZowAGrQtKcWmA==
DCE=64aeRJg7pSXFnMWybDE3jVgmjMb+MELy3gphmT/MHllbKBleJAuTRJ3WcJTQMSN6RujCHJ4tAXjDLVFie/gmV/XtN3scD1euulPB+HnFlHSCYlvde3A0Mlf/LQLForjJv6Y2TrY5OtwKx08HRVY7KRo/MUG7TFGrAA==
001001:0020 DBG ASSERT: ]E'~JE[oBX.D7v0qK:(zdP+C;VY7;Pk|64tiEE69<xk{wSghffP'rViY48p;Y8x at g9KkLj:W1OIu}L;~oRr:121263866
005070:0080 Backup done
005081:0104 Backup done.
Application exited at Thu Dec 04 01:13:09 2014
