Possible Bug Report: MakeMKV 1.18.3 for Windows
LESchwartz
#1 Post by LESchwartz » Fri May 15, 2026 12:15 am
I downloaded MakeMKV 1.18.3 (beta) for Windows and been happily ripping my DVDs on an older Dell XPS 8930 until last Tuesday. I knew things were really fouled up when I couldn't even re-rip previously ripped DVDs! Since Tuesday, I've been getting errors, lockups, failures, etc. while trying to rip DVDs. I tried various things to investigate, including: Trying other software, running diagnostics, reinstalling software and drivers, etc. Then I checked the Windows 11 update list. The list contained three updates since last Tuesday. I uninstalled all three of them and am happily ripping along again.
I'm not sure which of the updates was the culprit. If one of the support staff would like me to further investigate, please reply here. On the other hand, it's entirely possible that I'm late to the party and this is already a known issue . . .
Larry
tomty89
Re: Possible Bug Report: MakeMKV 1.18.3 for Windows
#2 Post by tomty89 » Fri May 15, 2026 10:55 am
Interesting. What exactly are the three updates? (Not a staff member or anything. Just an intrigued nobody.)
Btw is the drive connected to a SATA port or a USB bridge? (Or is it a portable drive?)
LESchwartz
#3 Post by LESchwartz » Fri May 15, 2026 1:20 pm
Dunno. I uninstalled all three w/o recording the numbers. However, today MakeMKV is again having trouble ripping. I see that I have also have "Security Update for Microsoft Windows (KB5089549)" auto installed. I don't know if that's on of the original three or not.
I will note that I was able to get ripping again on some DVDs by just running MakeMKV as administrator, rather than uninstalling the update.
Larry
PS: The drive is an internal SATA.
LESchwartz
#4 Post by LESchwartz » Sun May 17, 2026 8:29 pm
Still having issues . . . after successfully ripping a few DVDs, I started having issues again. When I checked, I see that KB5089549 is back again.
It looks like Windows 11 tries to install updates whenever the computer is idle for more than a short period . . .
Larry
grumpyx
#5 Post by grumpyx » Sun May 17, 2026 8:32 pm
Same here, since the Security KB5089549 update to Windows 11 I can no longer rip with MKV.
tomty89
#6 Post by tomty89 » Mon May 18, 2026 5:42 am
Being curious again: what's the exact errors in the log? Does it fail like it cannot begin the ripping process at all, or does it fail like errors show up at some point in the middle of the process? And does running as admin help this time?
Btw, does playback with VLC fail as well?
LESchwartz
#7 Post by LESchwartz » Tue May 19, 2026 12:29 am
1) Some ancient DVDs still rip. Most DVDs newer than about 20 years do not.
2) Running as administrator appears mandatory.
3) Problem disks often fail to open. Sometimes they open if I try a second time.
4) If the disk opens, sometimes it will rip -- sometimes it takes multiple tries.
5) KB5089549 seems to be the culprit. I can uninstall it, but it seems to reinstall next time the computer goes to sleep.
6) Log posted below.
Larry
DVD did not open, even though I tried twice:
MakeMKV v1.18.3 win(x64-release) started
Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading 'DVD+R-DL HL-DT-ST DVD+-RW GU90N A1C3 KYLJ7TJ0315' at offset '1048576'
Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading 'DVD+R-DL HL-DT-ST DVD+-RW GU90N A1C3 KYLJ7TJ0315' at offset '32768'
Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading 'DVD+R-DL HL-DT-ST DVD+-RW GU90N A1C3 KYLJ7TJ0315' at offset '589824'
udf: node fe/efe failed!
Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading 'DVD+R-DL HL-DT-ST DVD+-RW GU90N A1C3 KYLJ7TJ0315' at offset '524288'
Title #1 was added (12 cell(s), 1:11:32)
Title #2 has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading '/VIDEO_TS/VTS_01_1.VOB' at offset '2048'
Encountered 1 errors of type 'Read Error' - see http://www.makemkv.com/errors/dvdread/
LESchwartz
#8 Post by LESchwartz » Tue May 19, 2026 11:53 pm
7) Sometimes the DVD looks like it rips, but MakeMKV says it can't save the file.
Larry
