HD-DVD to Blu-ray
ottawaxblade
HD-DVD to Blu-ray
Post by ottawaxblade » Sat Apr 14, 2012 10:59 pm
I know that some of you are probably rolling your eyes at this one and I apologize.
Before my HD-DVD drive dies, I would like to possibly convert some of my HD-DVD discs to Blu-ray.
Does anyone have a simple, up-to-date tutorial with the latest / newest tools to convert an HD-DVD disc to Blu-ray?
In particular, i'm looking to convert my Heroes Season 1 HD-DVD series to blu-ray as I have the rest of the seasons on blu-ray
setarip_old
Re: HD-DVD to Blu-ray
Post by setarip_old » Sun Apr 15, 2012 4:15 am
Hi!
There's certainly nothing about your need that should make anyone roll their eyes, as many of us (myself included) have or have had that very same need. Try the following in order to convert your ripped/decrypted HD-DVDs to BluRay:
1) Open tsMuxeR GUI
2) Click on the "Join" radiobutton and select the first "Feature".EVO. Repeat for each consecutive "Feature".EVO (usually just one more. Almost all HD-DVDs have the main movie comprised of two "Feature" .EVOs
3) Select "BluRay" at the bottom of the window.
4) Click the "Start Muxing" radiobutton
ottawaxblade
Post by ottawaxblade » Sun Apr 15, 2012 3:19 pm
setarip_old wrote:Hi!
1) Open tsMuxeR GUI
Thanks for the reply and the quick guide.
I was wondering, some HD-DVDs have web features (similar to bd-live), is it possible to convert an entire HD-DVD with all it's web functionality and get it to work on blu-ray?
Post by SamuriHL » Sun Apr 15, 2012 3:46 pm
ottawaxblade wrote: Thanks for the reply and the quick guide.
No, the formats used are completely different. There's nothing that will give you menus, special features, web content, etc. The best you can do is the main movie (or I guess special features if you know what file(s) they're stored in). Personally I don't bother with converting to blu-ray. I convert everything to MKV, including my HD DVD's. Much easier. :)
setarip_old
Post by setarip_old » Sun Apr 15, 2012 5:17 pm
As always, my pleasure ;>}
