PM sent. Forum is slow. So be patient.Retail.fu wrote: Sun May 03, 2026 3:59 am Hi Coopervid (and everyone),
I own a Verbatim External Slimline Blu-ray Writer and would greatly appreciate any help with the UHD cross-flash to BDR-UD04 firmware.
Coopervid, will you assist me in my efforts for a UHD cross-flash?
Specifically, I own a Verbatim External Slimline Blu-ray Writer (model code LPUBAA, P/N 70102).
Below is the drive Information:
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.10
Serial number: RBDL137986WL
Firmware date: 2017-04-18
Drive platform: RS8511
Firmware version: 1.10
(No disc inserted)
I am happy to provide any additional info if needed.
Thank you.
Retail Fu
Pioneer BDR-UD03 UHD possibility
Re: Pioneer BDR-UD03 UHD possibility
sure email me that info and all others email me no need to post your info here just reach out to me directlyRetail.fu wrote: Sun May 03, 2026 3:59 am
Revision: 1.10
(No disc inserted)
Thank you.
Retail Fu
see below for email
I just got a Pioneer BDR-UD03 - Is there a way I can get help to flash it to UHD cross-flash to BDR-UD04 firmware ?
Here is the information.
Informations lecteur
Nom du lecteur SE : D:
Fabricant : PIONEER
Produit : BD-RW BDR-UD03
Révision : 1.11
Numéro de série : SIDL265458WL
Date micrologiciel : 2018-11-28
Marqueurs d'encryptage bus : 1B
Firmware version: 1.11
Fabricant : PIONEER
Révision : 1.11
sure email me that info and all others email me no need to post your info here Publicly just reach out to me directlyelahaie wrote: Mon May 04, 2026 12:09 am Hi,
Fabricant : PIONEER
Révision : 1.11
see below for email
PM sent.elahaie wrote: Mon May 04, 2026 12:09 am Hi,
Fabricant : PIONEER
Révision : 1.11
I also have this one if it's possible to crossflash it. Thanks for your support.
Thanks,
Eric
OS device name: I:
Current profile: CD-ROM
Product: BD-RW BDR-209M
Revision: 1.55
Serial number: OBDL010526WL
Firmware date: 2023-02-16
Bus encryption flags: 13
Drive platform: RS8600
Firmware version: 1.55/ID60
Thanks,
Eric
OS device name: I:
Revision: 1.55
Southy1978
Hi, made an account as I have this drive and want to rip all my dvd's & blu-ray discs. Is it possible with this drive?
Thanks in advance!
Current profile: DVD-ROM
Revision: 1.10
Serial number: RLDL191242WL
Thanks in advance!
Revision: 1.10
sure email me that infoSouthy1978 wrote: Sat May 16, 2026 12:03 pm Hi, made an account as I have this drive and want to rip all my dvd's & blu-ray discs. Is it possible with this drive?
Thanks in advance!
Revision: 1.10
and all others email me no need to post your info here publicly just reach out to me directly
see below for email
sure email me that infoelahaie wrote: Thu May 14, 2026 3:17 am I also have this one if it's possible to crossflash it. Thanks for your support.
Thanks,
Eric
OS device name: I:
Revision: 1.55
see below for email
Hi @CooperVid / BillyCar. I just picked up three identical (except SN) BDR-UD03's. Can one of you please help me with the cross-flash to BDR-UD04? Thanks!
OS device name: E:
Revision: 1.03
Serial number: PLDL331309WL
Firmware date: 2015-05-14
Highest AACS version: 76
Drive platform: RS8510
Firmware version: 1.03/ID19
OS device name: E:
Revision: 1.03
PM sent.Southy1978 wrote: Sat May 16, 2026 12:03 pm Hi, made an account as I have this drive and want to rip all my dvd's & blu-ray discs. Is it possible with this drive?
Thanks in advance!
Revision: 1.10
PM sent.E5Rod wrote: Fri May 22, 2026 8:53 pm Hi @CooperVid / BillyCar. I just picked up three identical (except SN) BDR-UD03's. Can one of you please help me with the cross-flash to BDR-UD04? Thanks!
OS device name: E:
Revision: 1.03
A thousand apologizes! I was expecting to get a notification via email if anyone responded, so I didn't login to check... Then life happened, one thing being my server I store my rips on died. Finally got everything sorted so I can start again. Do you mind sending another PM?Coopervid wrote: Thu May 29, 2025 2:37 amPM sent.plattfot wrote: Sat May 24, 2025 4:53 pm Hi,
I just started collecting UHD but sadly my drive BDR-UD03 drive cannot read them. Any help would be appreciated.
Drive Information OS device name: /dev/sr0 Current profile: BD-ROM Manufacturer: PIONEER Product: BD-RW BDR-UD03 Revision: 1.11 Serial number: SE********** Firmware date: 2018-11-28 Bus encryption flags: 1B Highest AACS version: 81 LibreDrive Information Status: Enabled Drive platform: RS8511 Firmware name: PIONEER BDR-US03 Firmware type: Original (unpatched) Firmware version: 1.11 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
(This time I'll make sure to periodically login to check my notifications...)
sure email me that infoplattfot wrote: Fri May 22, 2026 10:49 pmA thousand apologizes! I was expecting to get a notification via email if anyone responded, so I didn't login to check... Then life happened, one thing being my server I store my rips on died. Finally got everything sorted so I can start again. Do you mind sending another PM?Coopervid wrote: Thu May 29, 2025 2:37 amPM sent.plattfot wrote: Sat May 24, 2025 4:53 pm Hi,
see below for email
Thank you Coopervid! You guys are awesome.Coopervid wrote: Fri May 22, 2026 9:38 pmPM sent.E5Rod wrote: Fri May 22, 2026 8:53 pm Hi @CooperVid / BillyCar. I just picked up three identical (except SN) BDR-UD03's. Can one of you please help me with the cross-flash to BDR-UD04? Thanks!
OS device name: E:
Revision: 1.03
