ASUS SBW-06D2X-U not working
VivaciousVole
Post by VivaciousVole » Wed May 13, 2026 9:27 am
Hi I recently bought an ASUS SBW-06D2X-U from here.
I am running Ubuntu 26.04 and MakeMKV 1.18.3.
When I put a Blu-Ray in MakeMKV gets stuck on "scanning device". I have attached a screenshot.
I don't need to read 4K discs - just ordinary Blu-Ray.
Could anyone help me with the next debugging step?
This is the debug log:
Debug log started at Wed May 13 09:17:52 2026 , written by MakeMKV v1.18.3 linux(x64-release)
001005:0000 MakeMKV v1.18.3 linux(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file:///home/martin/MakeMKV_log.txt
Network access is ENABLED, CURL version 8.18.0/OpenSSL/3.5.5/1.68.0 (x86_64-pc-linux-gnu) , proxy server not set.
001003:0020 DEBUG: Code 0 at `BLLaJX7%0; ?J)zOB:`KC:29393631
No SDF v0a5: ASUS_SBW-06D2X-U_A102_212106281341_MO3O68G4321
SDF auto v0a5: ASUS_SBW-06D2X-U_A102_212106281341_MO3O68G4321
Screenshot From 2026-05-13 10-26-11.png (44.44 KiB) Viewed 12041 times
tomty89
Re: ASUS SBW-06D2X-U not working
Post by tomty89 » Wed May 13, 2026 5:35 pm
Recent version(s) seems to have regression for non-LibreDrive. You can try adding:
sdf_Stop = "ASUS_SBW-06D2X-U_A102_212106281341_MO3O68G4321"
to ~/.MakeMKV/settings.conf (create the file if it doesn't exist).
Can also try to downgrade to 1.17.7 or 1.17.6.
Or crossflash the drive with a LibreDrive / MK firmware. It seems that this drive can be crossflashed into a LG BU40N -- do your own research to confirm whether that's the case and what are the steps. (Search the forum with the model and A102 and read the ultimate uhd drive flashing guide, etc.)
VivaciousVole
Post by VivaciousVole » Wed May 13, 2026 7:28 pm
Brilliant that's fixed it! At least, I was able to scan titles and start ripping the first one. I'll know in an hour whether it can rip the whole Blu-ray.
Thank you so much @tomty89.
