I buy a pioneer drive in shopee ,can i read UHD disc in the drive,and can i need flash my drive frimware?
sorry,i'm taiwanese,english is so poor.....sorry
drive info:
OS device name: E:
Manufacturer: PIONEER
Product: BD-RW BDR-XD05
Revision: 3.10
Serial number:
Firmware date: 2017-06-22
Highest AACS version: 64
Drive platform: RS8232
Firmware name: PIONEER BDR-XD05
Firmware version: 3.10/ID34
can i read UHD disc in my Pioneer BDR-XD05S?
HatsuneRain
Re: can i read UHD disc in my Pioneer BDR-XD05S?
sure email me that infoHatsuneRain wrote: Wed May 13, 2026 2:46 pm I buy a pioneer drive in shopee ,can i read UHD disc in the drive,and can i need flash my drive frimware?
drive info:
OS device name: E:
Revision: 3.10
Serial number:
and all others email me no need to post your info here publicly just reach out to me directly
see below for email
PM sent.HatsuneRain wrote: Wed May 13, 2026 2:46 pm I buy a pioneer drive in shopee ,can i read UHD disc in the drive,and can i need flash my drive frimware?
drive info:
OS device name: E:
Revision: 3.10
Serial number:
little.tea1575
I also have a BDR-XD05S that I would like to use to read UHD discs. I don't have access to a Windows machine but I'm comfortable using the sdftool CLI so I'm hoping someone can help me identify which firmware is safe and possible to cross-flash. Thanks!
Drive information:
Drive information:
Revision: 3.10
Unrestricted read speed: Yes-
sdf tool can not be used for pioneers currentlylittle.tea1575 wrote: Sun Jun 07, 2026 4:40 pm Hello,
Drive information:
Manufacturer: PIONEER Product: BD-RW BDR-XD05 Revision: 3.10 Firmware date: 2017-06-22 Bus encryption flags: 1B LibreDrive Information Status: Enabled Drive platform: RS8232 Firmware name: PIONEER BDR-XD05 Firmware type: Original (unpatched) Firmware version: 3.10/ID34 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
the pioneer auto flasher is windows only but you can use a vm for it
email me that info
see below for email
tomty89
Btw BDRFlash (NOT Billy's auto flasher; although if it also uses nothing more than SPTI it should work as well) can be used on Linux through wine. It's just that instead of using the "dosdevice" / "drive letter" automatically created by wine (which points to /dev/sr*), you need to create one that points to the corresponding /dev/sg* dev node (which can be find out using e.g. lsscsi -g) yourself and use that instead.
