How to make Java work with MakeMKV?
mike_mgoblue
Post by mike_mgoblue » Sat Mar 13, 2021 9:20 pm
In the past, on a different computer, I was able to get Java to work with MKV so the names of files on the Blu-ray were titled properly from Java. Unfortunately, on a new computer, that no longer happens. It seems to be as if Java no longer works at all on this computer.
Please tell me what needs to be done - what settings need to be used - in order to make Java compatible with MakeMKV.
Thank you.
Re: How to make Java work with MakeMKV?
Post by dcoke22 » Sun Mar 14, 2021 5:33 pm
mike_mgoblue wrote: Sat Mar 13, 2021 9:20 pm In the past, on a different computer, I was able to get Java to work with MKV so the names of files on the Blu-ray were titled properly from Java.
As far as I'm aware, MakeMKV will use Java to try to pick the right playlist when a movie has a bunch of 'fake playlists'. viewtopic.php?f=8&t=14330 While this does append MakeMKV's guess to the filename, I would not describe that as being 'titled properly'.
There are ways to change the file name template MakeMKV uses. viewtopic.php?f=10&t=18313 There are several discussions around the forum of people modifying their templates to suite their tastes and needs.
ImCoKeMaN
Post by ImCoKeMaN » Sun Mar 14, 2021 7:21 pm
In preferences, Protection tab there is a Custom Java executable location path you can edit. Make sure that's pointing to the right place.
Post by Woodstock » Thu Mar 18, 2021 12:39 pm
If you are installing Java for the first time on a computer, you do NOT want to install the "browser integration". That's the component that caused the majority of the security problems in the past. Install it only for local use.
If the official Oracle JRE is installed, MakeMKV can usually find it, and you do not need to set the custom Java path. If, at a command prompt, you can get a "help screen" by entering the command "java", the install should be good enough for MakeMKV to find it (i.e., Java is in your execution path).
C:\>java -version
java version "1.8.0_121"
Java(TM) SE Runtime Environment (build 1.8.0_121-b13)
Java HotSpot(TM) Client VM (build 25.121-b13, mixed mode, sharing)
Other Java-compatible runtime environments exist; some of them require the custom path, and there are a few that are rather hard to make work, based on messages posted here.
KENSAI
Post by KENSAI » Tue May 12, 2026 10:15 pm
I figure I'd share a good source for Java instead of doing what I used to do, which is go to Sun and install the full version of Java.
Go here: https://adoptium.net/temurin/releases/
You can download the TAR.GZ version and put it on your local drive without having to run an installer and risk getting Java sprayed all over your system, then you just point make_mkv to the java.exe file inside the /bin folder. Nice and clean, works like a charm with MakeMKV.
icerunner
Post by icerunner » Mon Sep 21, 2026 2:29 pm
KENSAI wrote: Tue May 12, 2026 10:15 pm I figure I'd share a good source for Java instead of doing what I used to do, which is go to Sun and install the full version of Java.
I can confirm this fixed it for me. Downloaded the latest JRE for Linux, put it in an appropriate place and then pointed MakeMKV to it. Job done.
Thanks for the pointer.
