Dump submitted- Bridesmaids UHD
Re: Dump submitted- Bridesmaids UHD
Do you mean you emailed the dump to svq@makemkv.com for processing so a HK can be added to MakeMKV's database?? If not, please do so.
The public KeyDB already has a record for this disc.
It wasn't working for me earlier Monday afternoon (US Central TZ) after I had downloaded the most recent copy of the keydb.cfg. When it updated later Monday it finally worked. I also sent the link to the makemkv email address at the same time I posted the link.MartyMcNuts wrote: Tue May 12, 2026 8:08 amDo you mean you emailed the dump to svq@makemkv.com for processing so a HK can be added to MakeMKV's database?? If not, please do so.
When did the key get added? I've been having trouble the keydb.zip to download through Chrome but I'm certain it looked like I had the most recent at the time.
If you are on Windows, it is best to use SamuraiHL's KeyDB helper tool. It will automatically download the latest KeyDB and put it in the MakeMKV data directory for you. See the first post of the Public KeyDB Disc Submission thread.Tok72 wrote: Tue May 12, 2026 8:55 amIt wasn't working for me earlier Monday afternoon (US Central TZ) after I had downloaded the most recent copy of the keydb.cfg. When it updated later Monday it finally worked. I also sent the link to the makemkv email address at the same time I posted the link.MartyMcNuts wrote: Tue May 12, 2026 8:08 amDo you mean you emailed the dump to svq@makemkv.com for processing so a HK can be added to MakeMKV's database?? If not, please do so.
Also, that thread is where you should be posting your dump files. Just use the template. It is better to have everything in one thread rather than lots of individual threads everywhere.
