The Darkest Hour cant backup
ToXIc
#1 Post by ToXIc » Sun Apr 15, 2012 1:01 am
hey guys i'm having trouble backing up The Darkest Hour blueray. it states "failed to open disc"
failed with ver. 1.7.3 and 1.7.4
thanks..
crowfax
Re: The Darkest Hour cant backup
#2 Post by crowfax » Sun Apr 15, 2012 1:34 am
Turn on logging and post the log.
ToXIc
#3 Post by ToXIc » Sun Apr 15, 2012 1:45 am
here you go
Debug log started at Sun Apr 15 01:42:56 2012 , written by MakeMKV v1.7.4 win(x64-release)
001005:0000 MakeMKV v1.7.4 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\HTPC/MakeMKV_log.txt
DAFD=PAAAADAAAAEABDQEEAQEBAQ==
DCE=mc2xHi3dMU3T4gYzFTHpMEz02CGe5FXCrnMcyb5jchen3CISDHhoq1jklx9V8Kax2P01Z2F7suD1TpGUH36JVSpZqy9ywNUHD09xb7o8bv1F+aAfwXteZmzWCL2AcZprwNS1tVBEv1ltkTnqNu4C68IMsBaR2oK4fw==
DISCID=5AB1EA1DA3FAAA1B5B4FB2C1C00135469F86985B
003025:0000 Title #00099.mpls has length of 106 seconds which is less than minimum title length of 5500 seconds and was therefore skipped
003025:0000 Title #00001.mpls has length of 5338 seconds which is less than minimum title length of 5500 seconds and was therefore skipped
003025:0000 Title #00100.mpls has length of 106 seconds which is less than minimum title length of 5500 seconds and was therefore skipped
003025:0000 Title #00051.m2ts has length of 18 seconds which is less than minimum title length of 5500 seconds and was therefore skipped
003025:0000 Title #00057.m2ts has length of 15 seconds which is less than minimum title length of 5500 seconds and was therefore skipped
003025:0000 Title #00062.m2ts has length of 0 seconds which is less than minimum title length of 5500 seconds and was therefore skipped
003025:0000 Title #00065.m2ts has length of 60 seconds which is less than minimum title length of 5500 seconds and was therefore skipped
003025:0000 Title #00069.m2ts has length of 120 seconds which is less than minimum title length of 5500 seconds and was therefore skipped
003025:0000 Title #00066.m2ts has length of 6 seconds which is less than minimum title length of 5500 seconds and was therefore skipped
003025:0000 Title #00098.m2ts has length of 53 seconds which is less than minimum title length of 5500 seconds and was therefore skipped
003025:0000 Title #00099.m2ts has length of 53 seconds which is less than minimum title length of 5500 seconds and was therefore skipped
003025:0000 Title #00095.m2ts has length of 5 seconds which is less than minimum title length of 5500 seconds and was therefore skipped
003025:0000 Title #00096.m2ts has length of 5 seconds which is less than minimum title length of 5500 seconds and was therefore skipped
003025:0000 Title #00097.m2ts has length of 5 seconds which is less than minimum title length of 5500 seconds and was therefore skipped
003025:0000 Title #00100.m2ts has length of 5 seconds which is less than minimum title length of 5500 seconds and was therefore skipped
003025:0000 Title #00101.m2ts has length of 143 seconds which is less than minimum title length of 5500 seconds and was therefore skipped
003025:0000 Title #00102.m2ts has length of 5 seconds which is less than minimum title length of 5500 seconds and was therefore skipped
003025:0000 Title #00525.m2ts has length of 5 seconds which is less than minimum title length of 5500 seconds and was therefore skipped
003025:0000 Title #00526.m2ts has length of 5 seconds which is less than minimum title length of 5500 seconds and was therefore skipped
003025:0000 Title #00527.m2ts has length of 5 seconds which is less than minimum title length of 5500 seconds and was therefore skipped
003025:0000 Title #00528.m2ts has length of 5 seconds which is less than minimum title length of 5500 seconds and was therefore skipped
003025:0000 Title #00529.m2ts has length of 5338 seconds which is less than minimum title length of 5500 seconds and was therefore skipped
003025:0000 Title #00530.m2ts has length of 147 seconds which is less than minimum title length of 5500 seconds and was therefore skipped
Application exited at Sun Apr 15 01:43:32 2012
crowfax
#4 Post by crowfax » Sun Apr 15, 2012 1:51 am
5500 seconds = 91.6666667 minutes
The movie is shorter than 91 minutes. Go to your preferences and lower it to 120 seconds.
ToXIc
#5 Post by ToXIc » Sun Apr 15, 2012 1:58 am
oh wow i totally didnt think to check the running time of the movie.. thanks for helping
i raised it that high to get rid of the fluff...
thanks again....
