Help Please
mheaton58
Help Please
Post by mheaton58 » Wed May 06, 2026 2:27 am
I have a WP50NB40 drive that I'm attempting to flash with no luck. I have the SDFtool 1.3.6, MakeMkv 1.18.3, and found what I think are the flash files:
DE_LG_BP50NB40-NB50_1.01_MK_HBD.bin
DE_LG_BP60NB10_1.00_MK_HBD.bin
Using the tool, I select the drive, then Recovery, it asks for a file DE_LG_BP50NB40-NB50_1.01_MK_HBD.bin and I use DE_LG_BP60NB10_1.00_MK_HBD.bin for the Firmware to Write and select start. it runs with no errors or comments so I assume it worked. But the information data from MakeMKV does not seem to change.
Im at a lost for help or someone who can service the unit.
Thanks for your help.
Current profile: DVD-ROM
Product: BD-RE WP50NB40
Revision: 1.03
Serial number: SIK0CPBN84231
Firmware date: 2121-07-08 16:09
Disc Information
Label: WILLOW
Timestamp: 2001-09-27 12:09:44
Protection: CSS/CPPM
Data capacity: 7.82 Gb
Disc type: DVD-ROM
Disc size: 120mm
Maximum read rate: 10.08 Mbps [1x]
Number of layers: 2 (OTP)
Re: Help Please
Post by Billycar11 » Sun May 10, 2026 1:18 pm
see guide below you dont need to use the recovery function if you do it that way my guide says
martys way works too he actually made both ways possible as he made hbd fw before recovery function
