Please Help - Unable to Flash Firmware (New User)
masterdrowzee
Post by masterdrowzee »
Hi Everyone,
I purchased an Archgon drive on Amazon, and I've been trying to flash it with the firmware but when I click "start" nothing happens. See specs below...
Product: BD-RE BU40N
Revision: 1.02
Serial number: MO6P55G3234
Bus encryption flags: 1F
Harware support: Yes
Firmware support: No
Firmware version: 1.02
I'm running Windows 11 on a 1440p monitor. I've tried running the program as an administrator, I've tried power cycling the drive, and I've tried multiple downloads of the files but to no success.
I'm trying to use the following firmware: DE_LG_BU40N_1.03_MK
Re: Please Help - Unable to Flash Firmware (New User)
masterdrowzee wrote: Thu May 07, 2026 10:54 pm Hi Everyone,
Revision: 1.02
The Archgon enclosures don't allow flashing commands or libredrive.
You have 2 options:
1. Return it.
2. Remove the drive from the enclosure permanently. Flash it and use it outside the enclosure or get another, different enclosure.
lvthunder
Post by lvthunder »
I did the same thing and would like to go with #2. I assume there are screws under the rubber feet. Does anyone have a recommendation for a different enclosure to get? Preferably one with USB-C.
