Public KeyDB Disc Submissions
Captain Ron
Post by Captain Ron »
keydb_helper wrote: Wed May 06, 2026 3:17 pm
Captain Ron wrote: Wed May 06, 2026 2:49 pm Disc type: UHD (Sam Raimi's "Send Help" UK May 4th release)
Disc ID: 262CA37FAC35067436A9A45996EA5502E81A8FBF
Disc dump filename: MKB20_v82_SEND_HELP_B852.tgz
Thanks for providing that disc dump Captain Ron. Your disc has been added to the public keydb.
Thanks for that keydb_helper. I went to the download page and grabbed the latest english keydb.cfg download after receiving your notification.
I downloaded and opened the archive and copied out the keydb.cfg file into my C:\Users\<my user name>\.MakeMKV folder and launched MakeMKV.
Now when I try to do an unencrypted full backup of my Send Help disc I get MakeMKV telling me it doesn't know the volume label of the disc.
This process is quite new to me so apologies if I am misunderstanding it. I thought supplying these details and getting an update into the keydb.cfg file would allow MakeMKV to decrypt the disc as an alternative to native support while it is being worked on.
Is that not the case or am I missing something fundamental about the process?
alphawann
Post by alphawann »
Please can you decrypt this UHD Blu-ray for me ?
BLU RAY UHD FRENCH VERSION called l'agent secret 2025 (the secret agent)
Here is the link of the dump (24 HOURS) :
https://transfert.free.fr/8mXjNAE
Thank you in advance.
FootFungus07
Post by FootFungus07 »
Fight Club 4K UHD TGZ Dump
MKB20_v82_Fight_Club_ACE0.tgz
Label: FIGHT_CLUB
Timestamp: 2026-03-30 09:43:40
Protection: AACS2.0/C v82
Data capacity: 80.26 Gb
Disc type: BD-ROM UHD
Number of layers: 3
Bus encryption flags: 80
Product: BD-RE BP60NB10
LibreDrive status: Enabled
Google Drive link:
https://drive.google.com/file/d/1zPWUa1 ... drive_link
Thanks again!
keydb_helper
Post by keydb_helper »
Thanks to everyone who followed the template and provided new disc dump files. The following UHD discs have been added to the public keydb (new media keys are indicated with an asterisk):
*MKB20_v82_L_AGENT_SECRET_2356
*MKB20_v82_PANDORA_UHD_228A
Captain Ron wrote: Wed May 06, 2026 4:00 pm I thought supplying these details and getting an update into the keydb.cfg file would allow MakeMKV to decrypt the disc as an alternative to native support while it is being worked on.
Hey Captain Ron, your understanding is correct. Because the public keydb contains the keys for your disc MakeMKV can be configured to utilise it to create an unencrypted backup.
The first thing I'll ask you to confirm is that your extracted keydb.cfg actually contains the entry for your disc. Open up the keydb.cfg in any text editor and search for 0x262CA37FAC35067436A9A45996EA5502E81A8FBF. You should see something like this:
0x262CA37FAC35067436A9A45996EA5502E81A8FBF = SEND_HELP | D | 0000-00-00 | M | 0x3420<Redacted> | I | 0xB898<Redacted> | V | 0xCF18<Redacted> | U | 1-0xEFEF<Redacted> ; MKBv82/BEE (UHD)
If you can't find a match, you may have downloaded an old keydb.cfg file from a mirror site. Grab the latest keydb from the FindVUK home page as it contains the details for your disc.
The second possible issue is the location of the keydb.cfg file. You are correct that the default location on Windows will be C:\Users\<your user name>\.MakeMKV. But the actual location utilised by MakeMKV is determined by the 'MakeMKV data directory' setting and this can be modified by users.
Within MakeMKV you'll want to click on 'View', and then 'Preferences'. Click on the 'General' tab and note the directory listed under the 'MakeMKV data directory' heading. That is where you'll need to copy the extracted keydb.cfg file in order for MakeMKV to actually use it.
(The keydb.cfg file should end up in the same folder where you originally found your MKB20_v82_SEND_HELP_B852.tgz dump file but I figured there was some reuse potential in writing out the process)
alphawann
Post by alphawann »
Thank you very much the copye is in progress now.
Thank you KEYDB_HELPER
mattmak464
Post by mattmak464 »
Disc type: UHD
Disc ID: 0x98D51B20626EC82A7EE574E84DD258B5660B1322
Disc dump filename: MKB20_v82_Hamnet_E89C.tgz
Drive: BD-RE BU40N
Drive firmware: 1.00
MKB_RO.inf link: https://drive.google.com/file/d/1-GYnnT ... share_link
Disc dump link: https://drive.google.com/file/d/16oMuWp ... share_link
keydb_helper
mattmak464 wrote: Thu May 07, 2026 6:52 am Disc type: UHD
Thanks mattmak464, your disc has been added to the public keydb.
Captain Ron
keydb_helper. I had indeed downloaded the correct keydb.cfg file but it needed relocated to the MakeMKV data directory. Now my "Send Help" UHD is decrypting and backing up fine. :D Thanks for your help with this. I understand the process properly now. 8)
rdschouw
Post by rdschouw »
Disc type: Blu-Ray
Disc ID: f77536fc7b34e964c2e293f12dc4efb51c85c80c
Disc dump filename: MKB_v82_Gilmore_Girls_The_Series_Season_1_Disc_1_B0DE
Drive: BD-RE WH16NS60
Drive firmware: 1.03
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://drive.google.com/file/d/1QJJhgg ... F9ZhwJ899n
Disc dump link: https://drive.google.com/file/d/1VrN2HR ... drive_link
MrPenguin
Post by MrPenguin »
Captain Ron wrote: Thu May 07, 2026 8:43 am keydb_helper. I had indeed downloaded the correct keydb.cfg file but it needed relocated to the MakeMKV data directory. Now my "Send Help" UHD is decrypting and backing up fine. :D Thanks for your help with this. I understand the process properly now. 8)
Seeing as you are also a Windows user, may I suggest SamuriHL's KeyDB Helper utility as :idea: the next step :idea: on your Path to Enlightenment?
This utility acts as a convenient front-end to the FindVUK program, allowing you to perform incremental updates to your local KEYDB.cfg file, as well as copying this file to the correct directory for MakeMKV to use. And in some cases, it may even be able to infer what a missing entry should be, validate it against your disk and then upload that entry into the online KEYDB without any outside assistance at all 8).
Validating existing "(NOTVALIDATED)" entries for any disks you may own is also useful, of course... :).
FootFungus07
Alice in Wonderland 4K UHD
MKB20_v82_Alice_In_Wonderland_E2E4.tgz
Label: ALICE_IN_WONDERLAND
Timestamp: 2026-03-05 14:20:04
Data capacity: 56.2 Gb
Number of layers: 2
Here's my Google Drive link:
https://drive.google.com/file/d/1arDLeQ ... drive_link
xokia
Post by xokia »
Disc Information
Label: GOAT
Timestamp: 2026-03-10 18:44:39
Data capacity: 68.64 Gb
Number of layers: 3
https://limewire.com/d/bArDK#volhdZPsAk
Linked to uploaded MKB20_v82_GOAT_431A.tgz
jabbo13
Post by jabbo13 »
Bridesmaids (2011)
Disc type: UHD
Disc ID: 57707cccb4d980dad039b6d4ce0d0edbf24338be
Disc dump filename: MKB20_v82_Bridesmaids_C946
Drive: BD-RE BU40N
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): Link
Disc dump link: Link
keydb_helper
*MKB20_v82_Bridesmaids_UPK75_C946
Thanks for the update. Glad to hear you got it working.
xokia wrote: Fri May 08, 2026 12:51 am Disc Information
Label: GOAT
Hey xokia, thanks for the attempt but it is really weird that you ignored the submission template except for a single line which wasn't even correct as your disc was added to the public keydb on April 23.
All of these details are either irrelevant for the purposes of this thread or they can be obtained from the disc dump file:
xokia wrote: Fri May 08, 2026 12:51 am Timestamp: 2026-03-10 18:44:39
Number of layers: 3
mattmak464
Disc type: UHD
Disc ID: 0xC6B1F37D8FC5BA0EFFBC211CD4CA2B2B510E955E
Disc dump filename: MKB20_v82_Halloween_4_3872.tgz
Drive: BD-RE BU40N
MKB_RO.inf link: https://drive.google.com/file/d/1xPyBKw ... share_link
Disc dump link: https://drive.google.com/file/d/10h1gxD ... share_link
