TY! I will use a file host going forward.keydb_helper wrote: Sat May 02, 2026 1:52 am Thanks to everyone who followed the template and provided new disc dump files. The following UHD discs have been added to the public keydb (new media keys are indicated with an asterisk):Code: Select all
*MKB20_v82_BODY_HEAT_6008 *MKB20_v82_FIGHT_CLUB_7318 *MKB20_v82_Patchwork_2986 *MKB20_v82_Shelter_3260 *MKB20_v82_THE_WIZ_UHD (0xBC85E946C4141D125B87641A744086B30904139C) *MKB20_v82_UHD_ARCO_ADB2Hi DiscVaultKeeper13, thanks for the submission and welcome to the forum. Your disc has been added to the public keydb. In the future please use a file host such as Google Drive, Dropbox, OneDrive, MEGA, Swisstransfer etc instead of attaching files to your post. The forum has very limited storage capacity and it causes a headache for the forum admins when they have to clean up larger attachments.DiscVaultKeeper13 wrote: Fri May 01, 2026 6:18 pm MKB20_v82_Shelter_3260.tgz
Submitting dump file for the European UHD Blu-ray release of Shelter (2026) starring Jason Statham.
Public KeyDB Disc Submissions
DiscVaultKeeper13
KEYDB does actually contain your disk. But unfortunately, MakeMKV had failed to enable LibreDrive, and so bus encryption was still active.player7 wrote: Thu Apr 30, 2026 5:32 am yes tried the keydb without success, manually scanning the file i found plenty of entries for this title, but neither the sha1 was to be found nor the 6D8E name ending, so I assume this is a new type.
Wired For Chaos 2024
MKB20_v82_WiredForChaos_5A38
https://www.swisstransfer.com/d/4201727 ... 7e7f29a71d
keydb_helper
Hey Germán, welcome to the forum. Your disc has been added to the public keydb. Thanks for following the template so carefully.German wrote: Sat May 02, 2026 4:30 am Hi,
Submitting dump file for Point Blank (1967) 4K UHD:
Disc type: UHD
Disc ID: E640894CC9B2200DCC2A72365F3B1D8C5BE46882
Disc dump filename: MKB20_v82_POINT_BLANK_E706
Hey jump4joy, thanks for the new disc dump. Your disc has also been added to the public keydb.
Thanks, I'm sure that will be appreciated by the forum admins and moderators.
Good call MrPenguin. I'm not sure how I missed the fact it was already present in the keydb.MrPenguin wrote: Sat May 02, 2026 11:41 am KEYDB does actually contain your disk. But unfortunately, MakeMKV had failed to enable LibreDrive, and so bus encryption was still active.
snowsneakers
Hey,
Disc type: UHD
Disc ID: 7CFD0CD8ABE45923BD39DD34A8DB0229F90E7EF1
Disc dump filename: MKB20_v82_Fallout_Season_One_Disc_1_3FFD
Drive: BD-RE BU40N
Drive firmware: 1.03
LibreDrive status: Enabled
MKB_RO.inf link: https://drive.google.com/file/d/1OdwUEh ... drive_link
Disc dump link: https://drive.google.com/file/d/1wftcGO ... drive_link
Disc type: UHD
Disc ID: 50F5BEBE3E0971F721FD3B271F2658063482B4F9
Disc dump filename: MKB20_v82_Fallout_Season_One_Disc_3_0D03
Drive: BD-RE BU40N
MKB_RO.inf link: https://drive.google.com/file/d/1wTChs4 ... drive_link
Disc dump link: https://drive.google.com/file/d/1XTkhG0 ... drive_link
Disc type: UHD
Drive: BD-RE BU40N
Disc type: UHD
Drive: BD-RE BU40N
buffalobossie
Disc type: UHD
Disc ID: 18b44e4c81993b1f94db13f31899db3674cbbe61
Disc dump filename: MKB20_v77_John_Carpenter's_Ghosts_Of_Mars_4707.tgz
Drive: BD-RE WH16NS60
Drive firmware: 1.02
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://drive.google.com/file/d/1OvJTeA ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1H55hP8 ... sp=sharing
keydb_helper
*MKB20_v82_10_to_Midnight (0x52B4DD8E2A5B88C4DE99CDDC707F500E0AE05E87)
*MKB20_v82_BLU-RAY_UHD_1894
MKB20_v82_COLD_STORAGE_A2CB
MKB20_v82_Die_Dämonischen_10C5
*MKB20_v82_TRAQUE_UHD_E306
MKB20_v82_WE_BURY_THE_DEAD_3147
apophis906
Disc type: UHD
Disc ID: 807955AE81DA7B68E3F1E1291949D58D7B165558
Disc dump filename: MKB20_v82_ALICE_IN_WONDERLAND_7522.tgz
Drive: BW-16D1HT
Drive firmware: 3.10
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://drive.google.com/file/d/1r7p3Sh ... drive_link
Disc dump link: https://drive.google.com/file/d/1n6CF74 ... drive_link
Drive: BW-16D1HT
arrange5051
Disc type: UHD
Disc ID: 502483C64B4FCC3314BF3F8449E342839C902B25
Disc dump filename: MKB20_v76_Miami_Connection_5143.tgz
Drive: Pioneer BD-RW BDR-212U
Drive firmware: 1.01/ID83
MKB_RO.inf link: https://drive.google.com/file/d/1K91f6m ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1VQa0SA ... sp=sharing
keydb_helper
Thanks apophis906, your disc has been added to the public keydb.apophis906 wrote: Tue May 05, 2026 3:58 pm Disc type: UHD
Thanks arrange5051, your disc has also been added to the public keydb. As the media key was already known for your disc you could've added it to the keydb by running SamuriHL's KeyDB Tool.arrange5051 wrote: Tue May 05, 2026 5:30 pm Disc type: UHD
keydb_helper
*MKB20_v82_FACTORIS_1035_3701623403649_THELEGENDOFFONGSAIYUK_3C80
*MKB20_v82_The_third_man_5068
Imprint Films Halloween box set:
Disc type: UHD
Disc ID: 0x06B62CA227C84FD82076323D86B5C37B812771A0
Disc dump filename: MKB20_v82_Halloween_838A.tgz
Drive: WH16NS60
Drive firmware: 2118-10-29
MKB_RO.inf link: Here
Disc dump link: Halloween
Disc ID: 0xEA967009C3E229A4497EFE97B289DCD68BB039BA
Disc dump filename: MKB20_v82_Halloween_II_3930.tgz
Disc dump link: Halloween II
Disc ID: 0xCD9DBA0F280046335F07E22D60694B6E82CD41AD
Disc dump filename: MKB20_v82_Halloween_III_7DE8.tgz
Disc dump link: Halloween III
Disc type: UHD
Drive: WH16NS60
keydb_helper
Thanks for the submission rusty100, all three discs have been added to the public keydb.rusty100 wrote: Wed May 06, 2026 8:09 am Imprint Films Halloween box set:
Disc type: UHD
Captain Ron
Disc type: UHD (Sam Raimi's "Send Help" UK May 4th release)
Disc ID: 262CA37FAC35067436A9A45996EA5502E81A8FBF
Disc dump filename: MKB20_v82_SEND_HELP_B852.tgz
Drive: ASUS BW-16D1HT
Drive firmware: 3.02
MKB_R0.inf link: https://www.dropbox.com/scl/fi/6z7sts3x ... mky51&dl=0
Disk dump link: https://www.dropbox.com/scl/fi/brak6y1j ... sa6ma&dl=0
keydb_helper
Thanks for providing that disc dump Captain Ron. Your disc has been added to the public keydb.Captain Ron wrote: Wed May 06, 2026 2:49 pm Disc type: UHD (Sam Raimi's "Send Help" UK May 4th release)
