BDR-XS07S UHD Flash
Re: BDR-XS07S UHD Flash
#316 Post by MartyMcNuts » Sun Apr 19, 2026 9:27 pm
bkwashby wrote: Sun Apr 19, 2026 4:38 pm
MartyMcNuts wrote: Sun Apr 19, 2026 7:45 am
bkwashby wrote: Sat Apr 18, 2026 10:44 pm Hello
I'm looking to flash my drive so I can rip UHD discs, can anyone help?
OS device name: E:
Manufacturer: PIONEER
Product: BD-RW BDR-XS07U
Revision: 1.02
Serial number: CBDL008388UC
Firmware date: 2022-10-24
Bus encryption flags: 13
Drive platform: RS8E21
Firmware version: 1.02/ID05
This shouldn't need flashing. Have you tried a UHD disc yet?
Yes, when I try to load the disc it fails.
With what error?
bkwashby
#317 Post by bkwashby » Mon Apr 20, 2026 9:49 pm
MartyMcNuts wrote: Sun Apr 19, 2026 9:27 pm
With what error?
This is what it says:
MakeMKV v1.18.3 win(x64-release) started
Using LibreDrive mode (v02.1 id=CA5C627C459A)
Downloading latest HK to C:\Users\Bryan/.MakeMKV ...
Saved AACS dump file as C:\Users\Bryan/.MakeMKV/MKB20_v61_Ready_Player_One_6B49.tgz
#318 Post by MartyMcNuts » Tue Apr 21, 2026 12:13 am
bkwashby wrote: Mon Apr 20, 2026 9:49 pm
With what error?
So there are no actual read errors. Your issue is clear.
You need to fix your HK download issue otherwise you won't be able to rip a lot of UHD discs. MakeMKV needs to be able to download it's HK database to get the UHD decryption keys. Your computer is most likely geo-blocking Russia (that's where the HK is downloaded from). You should fix this geo-blocking or you could try running MakeMKV through a VPN.
bkwashby
#319 Post by bkwashby » Tue Apr 21, 2026 10:52 pm
MartyMcNuts wrote: Tue Apr 21, 2026 12:13 am
With what error?
I got it working. I do use a VPN, turns out my VPN was blocking.
Thanks for your help
zittrig
#320 Post by zittrig » Tue May 05, 2026 6:52 pm
I was able to buy a BDR-XS07TS surprisingly cheap. For 4K Support I would be very grateful:
OS-Gerätename: F:
Produzent: PIONEER
Produkt: BD-RW BDR-XS07
Revision: 1.01
Serienummer: XXXXX
Firmware-Datum: 2020-09-03
Markierungen der Bus-Verschlüsselung: 13
Highest AACS version: 82
Drive platform: RS8E20
Firmware version: 1.01
#321 Post by Coopervid » Tue May 05, 2026 7:44 pm
zittrig wrote: Tue May 05, 2026 6:52 pm I was able to buy a BDR-XS07TS surprisingly cheap. For 4K Support I would be very grateful:
OS-Gerätename: F:
Produzent: PIONEER
Revision: 1.01
Serienummer: XXXXX
PM sent.
zittrig
#322 Post by zittrig » Tue May 05, 2026 8:08 pm
Works perfectly, thank you very much! :-)
#323 Post by Billycar11 » Wed May 06, 2026 1:16 am
OS-Gerätename: F:
Produzent: PIONEER
Revision: 1.01
Serienummer: XXXXX
sure email me that info and all others email me no need to post your info here just reach out to me directly
see below for email
PudgeGrandDaddy
#324 Post by PudgeGrandDaddy » Wed May 27, 2026 6:22 pm
So I have I think the same (or similar) drive as zittrig. This is a new account for me as my old one I guess I can't get in (my old email is inaccessible. I'd love to be able to play UHD on it but cannot ATM.
Revision: 1.01
Serial number: SKDL000809UC
Firmware date: 2020-09-03
Highest AACS version: 68
#325 Post by Coopervid » Wed May 27, 2026 8:52 pm
PudgeGrandDaddy wrote: Wed May 27, 2026 6:22 pm So I have I think the same (or similar) drive as zittrig. This is a new account for me as my old one I guess I can't get in (my old email is inaccessible. I'd love to be able to play UHD on it but cannot ATM.
Revision: 1.01
PM sent.
#326 Post by Billycar11 » Wed May 27, 2026 10:45 pm
Revision: 1.01
see below for email
barish
#327 Post by barish » Tue Jun 02, 2026 5:30 pm
deleted by request
#328 Post by Billycar11 » Tue Jun 02, 2026 11:43 pm
barish wrote: Tue Jun 02, 2026 5:30 pm
Coopervid wrote: Wed May 27, 2026 8:52 pm PM sent.
Revision: 1.00
Serial number: TFDL001558UC
Firmware date: 2019-01-07
Highest AACS version: 81
Firmware version: 1.00
all others email me no need to post your info publicly here just reach out to me directly
see below for email
#329 Post by Coopervid » Wed Jun 03, 2026 8:27 am
Hey cooper, would you mind helping me too? I just registered so i can't PM you directly, but it would be greatly appreciated.
Revision: 1.00
PM sent.
rickygrove
#330 Post by rickygrove » Wed Jun 24, 2026 6:26 pm
I've got 1.01 firmware on this drive and would like to patch. Thanks in advance.
