BDR-XS07S UHD Flash
Re: BDR-XS07S UHD Flash
Post by MartyMcNuts » Sun Apr 19, 2026 9:27 pm
bkwashby wrote: Sun Apr 19, 2026 4:38 pm
MartyMcNuts wrote: Sun Apr 19, 2026 7:45 am
bkwashby wrote: Sat Apr 18, 2026 10:44 pm Hello
I'm looking to flash my drive so I can rip UHD discs, can anyone help?
OS device name: E:
Manufacturer: PIONEER
Product: BD-RW BDR-XS07U
Revision: 1.02
Serial number: CBDL008388UC
Firmware date: 2022-10-24
Bus encryption flags: 13
Drive platform: RS8E21
Firmware version: 1.02/ID05
This shouldn't need flashing. Have you tried a UHD disc yet?
Yes, when I try to load the disc it fails.
With what error?
bkwashby
Post by bkwashby » Mon Apr 20, 2026 9:49 pm
MartyMcNuts wrote: Sun Apr 19, 2026 9:27 pm
With what error?
This is what it says:
MakeMKV v1.18.3 win(x64-release) started
Using LibreDrive mode (v02.1 id=CA5C627C459A)
Downloading latest HK to C:\Users\Bryan/.MakeMKV ...
Saved AACS dump file as C:\Users\Bryan/.MakeMKV/MKB20_v61_Ready_Player_One_6B49.tgz
Post by MartyMcNuts » Tue Apr 21, 2026 12:13 am
bkwashby wrote: Mon Apr 20, 2026 9:49 pm
With what error?
So there are no actual read errors. Your issue is clear.
You need to fix your HK download issue otherwise you won't be able to rip a lot of UHD discs. MakeMKV needs to be able to download it's HK database to get the UHD decryption keys. Your computer is most likely geo-blocking Russia (that's where the HK is downloaded from). You should fix this geo-blocking or you could try running MakeMKV through a VPN.
bkwashby
Post by bkwashby » Tue Apr 21, 2026 10:52 pm
MartyMcNuts wrote: Tue Apr 21, 2026 12:13 am
With what error?
I got it working. I do use a VPN, turns out my VPN was blocking.
Thanks for your help
zittrig
Post by zittrig » Tue May 05, 2026 6:52 pm
I was able to buy a BDR-XS07TS surprisingly cheap. For 4K Support I would be very grateful:
OS-Gerätename: F:
Produzent: PIONEER
Produkt: BD-RW BDR-XS07
Revision: 1.01
Serienummer: XXXXX
Firmware-Datum: 2020-09-03
Markierungen der Bus-Verschlüsselung: 13
Highest AACS version: 82
Drive platform: RS8E20
Firmware version: 1.01
Post by Coopervid » Tue May 05, 2026 7:44 pm
zittrig wrote: Tue May 05, 2026 6:52 pm I was able to buy a BDR-XS07TS surprisingly cheap. For 4K Support I would be very grateful:
OS-Gerätename: F:
Produzent: PIONEER
Revision: 1.01
Serienummer: XXXXX
PM sent.
zittrig
Post by zittrig » Tue May 05, 2026 8:08 pm
Works perfectly, thank you very much! :-)
Post by Billycar11 » Wed May 06, 2026 1:16 am
OS-Gerätename: F:
Produzent: PIONEER
Revision: 1.01
Serienummer: XXXXX
sure email me that info and all others email me no need to post your info here just reach out to me directly
see below for email
PudgeGrandDaddy
Post by PudgeGrandDaddy » Wed May 27, 2026 6:22 pm
So I have I think the same (or similar) drive as zittrig. This is a new account for me as my old one I guess I can't get in (my old email is inaccessible. I'd love to be able to play UHD on it but cannot ATM.
Revision: 1.01
Serial number: SKDL000809UC
Firmware date: 2020-09-03
Highest AACS version: 68
Post by Coopervid » Wed May 27, 2026 8:52 pm
PudgeGrandDaddy wrote: Wed May 27, 2026 6:22 pm So I have I think the same (or similar) drive as zittrig. This is a new account for me as my old one I guess I can't get in (my old email is inaccessible. I'd love to be able to play UHD on it but cannot ATM.
Revision: 1.01
PM sent.
Post by Billycar11 » Wed May 27, 2026 10:45 pm
Revision: 1.01
see below for email
barish
Post by barish » Tue Jun 02, 2026 5:30 pm
deleted by request
Post by Billycar11 » Tue Jun 02, 2026 11:43 pm
barish wrote: Tue Jun 02, 2026 5:30 pm
Coopervid wrote: Wed May 27, 2026 8:52 pm PM sent.
Revision: 1.00
Serial number: TFDL001558UC
Firmware date: 2019-01-07
Highest AACS version: 81
Firmware version: 1.00
all others email me no need to post your info publicly here just reach out to me directly
see below for email
Post by Coopervid » Wed Jun 03, 2026 8:27 am
Hey cooper, would you mind helping me too? I just registered so i can't PM you directly, but it would be greatly appreciated.
Revision: 1.00
PM sent.
rickygrove
Post by rickygrove » Wed Jun 24, 2026 6:26 pm
I've got 1.01 firmware on this drive and would like to patch. Thanks in advance.
