Pioneer BDR-UD03 UHD possibility
Re: Pioneer BDR-UD03 UHD possibility
Retail.fu wrote: Sun May 03, 2026 3:59 am
I own a Verbatim External Slimline Blu-ray Writer and would greatly appreciate any help with the UHD cross-flash to BDR-UD04 firmware.
Coopervid, will you assist me in my efforts for a UHD cross-flash?
Specifically, I own a Verbatim External Slimline Blu-ray Writer (model code LPUBAA, P/N 70102).
Below is the drive Information:
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.10
Serial number: RBDL137986WL
Firmware date: 2017-04-18
Drive platform: RS8511
Firmware version: 1.10
(No disc inserted)
I am happy to provide any additional info if needed.
Thank you.
Retail Fu
sure email me that info and all others email me no need to post your info here just reach out to me directly
see below for email
elahaie
Post by elahaie »
I just got a Pioneer BDR-UD03 - Is there a way I can get help to flash it to UHD cross-flash to BDR-UD04 firmware ?
Here is the information.
Informations lecteur
Nom du lecteur SE : D:
Fabricant : PIONEER
Produit : BD-RW BDR-UD03
Révision : 1.11
Numéro de série : SIDL265458WL
Date micrologiciel : 2018-11-28
Marqueurs d'encryptage bus : 1B
Firmware version: 1.11
elahaie wrote: Mon May 04, 2026 12:09 am Hi,
Fabricant : PIONEER
Révision : 1.11
sure email me that info and all others email me no need to post your info here Publicly just reach out to me directly
see below for email
Fabricant : PIONEER
Révision : 1.11
PM sent.
elahaie
Post by elahaie »
I also have this one if it's possible to crossflash it. Thanks for your support.
Thanks,
Eric
OS device name: I:
Current profile: CD-ROM
Product: BD-RW BDR-209M
Revision: 1.55
Serial number: OBDL010526WL
Firmware date: 2023-02-16
Bus encryption flags: 13
Drive platform: RS8600
Firmware version: 1.55/ID60
Southy1978
Post by Southy1978 »
Hi, made an account as I have this drive and want to rip all my dvd's & blu-ray discs. Is it possible with this drive?
Thanks in advance!
Current profile: DVD-ROM
Revision: 1.10
Serial number: RLDL191242WL
Southy1978 wrote: Sat May 16, 2026 12:03 pm Hi, made an account as I have this drive and want to rip all my dvd's & blu-ray discs. Is it possible with this drive?
Thanks in advance!
Revision: 1.10
and all others email me no need to post your info here publicly just reach out to me directly
see below for email
elahaie wrote: Thu May 14, 2026 3:17 am I also have this one if it's possible to crossflash it. Thanks for your support.
Thanks,
Eric
OS device name: I:
Revision: 1.55
see below for email
E5Rod
Post by E5Rod »
Hi @CooperVid / BillyCar. I just picked up three identical (except SN) BDR-UD03's. Can one of you please help me with the cross-flash to BDR-UD04? Thanks!
OS device name: E:
Revision: 1.03
Serial number: PLDL331309WL
Firmware date: 2015-05-14
Highest AACS version: 76
Drive platform: RS8510
Firmware version: 1.03/ID19
Thanks in advance!
Revision: 1.10
PM sent.
E5Rod wrote: Fri May 22, 2026 8:53 pm Hi @CooperVid / BillyCar. I just picked up three identical (except SN) BDR-UD03's. Can one of you please help me with the cross-flash to BDR-UD04? Thanks!
OS device name: E:
Revision: 1.03
PM sent.
plattfot
Post by plattfot »
Coopervid wrote: Thu May 29, 2025 2:37 am
plattfot wrote: Sat May 24, 2025 4:53 pm Hi,
I just started collecting UHD but sadly my drive BDR-UD03 drive cannot read them. Any help would be appreciated.
OS device name: /dev/sr0
Revision: 1.11
Serial number: SE**********
Firmware date: 2018-11-28
Highest AACS version: 81
PM sent.
A thousand apologizes! I was expecting to get a notification via email if anyone responded, so I didn't login to check... Then life happened, one thing being my server I store my rips on died. Finally got everything sorted so I can start again. Do you mind sending another PM?
(This time I'll make sure to periodically login to check my notifications...)
plattfot wrote: Fri May 22, 2026 10:49 pm
Revision: 1.11
PM sent.
see below for email
E5Rod
Post by E5Rod »
Coopervid wrote: Fri May 22, 2026 9:38 pm
OS device name: E:
Revision: 1.03
PM sent.
Thank you Coopervid! You guys are awesome.
Revision: 1.11
PM sent.
PM sent. You must activate that function to receive emails.
