Old activatiion key no good anymore?
dchicks
Post by dchicks »
I have an activation key that I bought in 2016 that has been working fine until I just tried to upgrade to 1.18 on Linux. The registration box won't even take the pasting of the key into it. Is this a problem with the key? It's hard to tell, but it looks like there may have been some kind of problem with Linux installations and their credentials. Can someone fill me in? Am I going to have to buy another key? OR, should I just keep using 1.17?
Thanks,
Dave
Re: Old activatiion key no good anymore?
The key doesn't change between versions. However, did you "copy and paste" it in to the dialog, or simply install the new version over the top of the old?
Copy and paste doesn't always work, because of what gets copied in isn't always what you think it is. If your paste operation happens to include the <cr> at the end of the key string, it can be rejected.
16442496
Post by 16442496 »
Old key is just fine. Mine Key is from 2015 and works fine.
Install MakeMKV 1.18.3 from sources.
viewtopic.php?f=3&t=224
Now add your key from GUI.
or
You can use terminal and add your MakeMKV Key from there.
This command adds your key to the MakeMKV settings.conf file.
echo 'app_Key = "YourKeyGoesHere"' >> ~/.MakeMKV/settings.conf
Debian
MakeMKV 1.17.6 (Registered)
