LibreDrive for Pioneer drives
audiotechnica
#1951 Post by audiotechnica » Sat May 02, 2026 2:26 pm
I have these two Pioneer UHD drives. A BDR-211UBK and a BDR-212UBK. The BDR-211UBK will not rip 4K discs, it errors out with "Can't read AACS VID from disc". The BDR-212UBK on the other hand rips all the 4K discs the BDR-211UBK won't rip. The highest seen AACS version on both drives is v60. Both drives have 2023 firmware so I'm puzzled why one works and the other one doesn't. Both drives were purchased brand new from B&H years ago in retail boxes, they're not Chinese recases. It looks like LibreDrive is not working on the BDR-211UBK even though MakeMKV says it's enabled? Is this a MakeMKV bug?
I also tried the same 4K discs on a BDR-209DBK crossflashed to a BDR-211M and a brand new Asus BW-16D1X-U crossflashed to the BW-16D1HT v3.10 firmware and they rip just fine as well. I emailed the .tgz file that MakeMKV created on the BDR-211UBK to svq@makemkv.com for analysis.
MakeMKV for the BDR-211UBK:
    OS device name: E:
    Manufacturer: PIONEER
    Product: BD-RW BDR-211M
    Revision: 1.54
    Serial number: QHDL004326WL
    Firmware date: 2023-02-08
    Bus encryption flags: 13
    Highest AACS version: 60
    Drive platform: RS8800
    Firmware name: PIONEER BDR-211
    Firmware version: 1.54/ID60
MakeMKV info for the BDR-212UBK:
    OS device name: F:
    Product: BD-RW BDR-212U
    Revision: 1.05
    Serial number: AGDL002378WL
    Firmware date: 2023-08-01
    Drive platform: RS8F01
    Firmware version: 1.05/ID58
Here's an example of a disc that the BDR-211UBK won't rip:
    Label: THE MARTIAN
    Timestamp: 2016-01-28 18:11:08 -08:00
    Capacity: 48.9 GB (25660960 sectors)
    Authoring: ScenaristScenaristBD
    Number of layers: 2
    BEE: 1
    BE : 0
    DiscID: EB75B987AD93BE13EFEE36DFB6792F58B6059F9E
    AACS: 2.0 v60
#1952 Post by Billycar11 » Sat May 02, 2026 2:58 pm
audiotechnica wrote: Sat May 02, 2026 2:26 pm I have these two Pioneer UHD drives. A BDR-211UBK and a BDR-212UBK. The BDR-211UBK will not rip 4K discs, it errors out with "Can't read AACS VID from disc". The BDR-212UBK on the other hand rips all the 4K discs the BDR-211UBK won't rip. The highest seen AACS version on both drives is v60. Both drives have 2023 firmware so I'm puzzled why one works and the other one doesn't. Both drives were purchased brand new from B&H years ago in retail boxes, they're not Chinese recases. It looks like LibreDrive is not working on the BDR-211UBK even though MakeMKV says it's enabled? Is this a MakeMKV bug?
    OS device name: E:
    Revision: 1.54
    OS device name: F:
    Revision: 1.05
    Label: THE MARTIAN
    Number of layers: 2
    BEE: 1
    BE : 0
    AACS: 2.0 v60
You likely have a HK download issue
Go to the UHD disc section and use the keydb
audiotechnica
#1953 Post by audiotechnica » Sat May 02, 2026 3:20 pm
Billycar11 wrote: Sat May 02, 2026 2:58 pm You likely have a HK download issue
If I had a key download issue, then how come three other drives work with all those 4K discs, and just the BDR-211UBK doesn't?
I put the latest keydb.cfg in the MakeMKV data directory but that did nothing.
Still getting "LibreDrive compatible drive is required to open this disc - video can't be decrypted."
#1954 Post by Billycar11 » Sat May 02, 2026 3:49 pm
audiotechnica wrote: Sat May 02, 2026 3:20 pm
Also download the latest drive sdf linked on bottom of guide
audiotechnica
#1955 Post by audiotechnica » Sat May 02, 2026 3:57 pm
Billycar11 wrote: Sat May 02, 2026 3:49 pm
I put sdf.bin in the MakeMKV directory and still getting the same error.
audiotechnica
#1956 Post by audiotechnica » Sun May 03, 2026 12:07 pm
I did more testing. I connected the BDR-211UBK drive via SATA and LibreDrive works fine now.
So leaving this post up for those who have the same problem.
Really bizarre that I have three other drives (2x Pioneer, 1x Asus) that work fine in three different USB enclosures.
Only this BDR-211UBK refuses to run in LibreDrive mode over USB (connected directly to computer, no hubs), but it works over SATA.
I'll do more testing and try different USB ports, too. This is so weird.
georgesgiralt
#1957 Post by georgesgiralt » Sun May 03, 2026 1:45 pm
audiotechnica wrote: Sun May 03, 2026 12:07 pm I did more testing. I connected the BDR-211UBK drive via SATA and LibreDrive works fine now.
This does not surprise me. Not all the SATA/USB interface chips are born equal and some function are not working or marginally so. I bet that the chip in your case is somewhat not speaking correctly to the computer and the optical drive... Remember these chips are "intelligent" and stuffed with software...
audiotechnica
#1958 Post by audiotechnica » Sun May 03, 2026 7:03 pm
Sure, but what's weird is that I've tried three different enclosures with four different drives.
Only one drive doesn't like being on USB and it doesn't matter which USB enclosure it's in.
The other three drives work perfectly fine in all three USB enclosures.
tomty89
#1959 Post by tomty89 » Tue May 05, 2026 2:35 pm
audiotechnica wrote: Sun May 03, 2026 7:03 pm Sure, but what's weird is that I've tried three different enclosures with four different drives.
FWIW, the bus encryption flags of the two drives are different. While I'm not entirely sure how the flags should be interpreted exactly, I have an S08XLT which also has 1B like your 212UBK does. (While I don't have access to the drive at the moment, IIRC its flags haven't changed after I crossflashed it into a "rev.1" / RS8800 BDR-211UBK 1.53 -- I don't think that the firmware version matters either.) And I suspect that flags 1B basically means that the drive is not "bus encryption enabled (BEE)". (At least mine isn't; before and after being crossflashed.)
Pioneer drives, at least older ones like mine, are essentially "inherently Libre", that is, MakeMKV doesn't really need to do anything to the drive to be able to "raw data read" a BD or UHD BD. This might even be the case with latest firmware and newer models (that are not bus encryption enabled). In other words, if that's the case with your BDR-212UBK, it might not really be surprising that it works with the enclosure while your BDR-211UBK doesn't.
P.S. AFAIK, non-BEE drives will not become BEE after they have been crossflashed with firmware from models that are supposed to be BEE / updated. Is your 212UBK a crossflashed drive (e.g. originally a 212EBK/DBK)?
#1960 Post by Coopervid » Tue May 05, 2026 3:54 pm
All non-UHD drives flashed for UHD might say that they are BEE enabled but they "lie". The chip to do so is missing.
This 211 should be used internally. If you want to rule out the root cause you should get a Benfei USB -> SATA adapter like this. If it works with that your enclosures don't support all functions. Why this happens with this 211 I don't know.
https://www.amazon.com/BENFEI-Drive-Ada ... 9hdGY&th=1
wellwelllwell
#1961 Post by wellwelllwell » Wed May 06, 2026 4:19 am
I have a BDR-XU03 that I recently acquired and I heard the tool has been updated to support these drives.
OS device name: G:
Product: BD-RW BDR-XU03
Revision: 1.03
Serial number: RBDL911580UC
Firmware date: 2015-06-29
Highest AACS version: 82
Drive platform: RS8520
Firmware version: 1.03
If this drive can be flashed a flashing tool link would be great!
wellwelllwell
#1962 Post by wellwelllwell » Wed May 06, 2026 4:30 am
I heard there is now support for the Pioneer BDR-XU03 and I was wondering if this drive could get flashed.
OS device name: G:
Revision: 1.03
#1963 Post by Billycar11 » Wed May 06, 2026 6:19 am
wellwelllwell wrote: Wed May 06, 2026 4:19 am Hello,
OS device name: G:
Revision: 1.03
sorry no cant be flashed
need to be 8510 or 11
audiotechnica
#1964 Post by audiotechnica » Wed May 06, 2026 2:03 pm
tomty89 wrote: Tue May 05, 2026 2:35 pm
Both the BDR-211UBK and BDR-212UBK are *not* crossflashed. They are actual UHD models purchased brand new years ago.
Both drives were flashed to the latest Pioneer firmware a couple of years back before I discovered MakeMKV.
I just got the Benfei USB-SATA adapter and the BDR-211UBK finally works with it.
So it looks like the official 1.54 firmware for the BDR-211UBK is a lot more picky with bus encryption over USB than the official 1.05 firmware for the BDR-212UBK.
Last edited by audiotechnica on Thu May 07, 2026 12:15 am, edited 1 time in total.
audiotechnica
#1965 Post by audiotechnica » Wed May 06, 2026 2:10 pm
Coopervid wrote: Tue May 05, 2026 3:54 pm All non-UHD drives flashed for UHD might say that they are BEE enabled but they "lie". The chip to do so is missing.
My enclosures are Vantecs (two different revisions purchased several years apart) and the Asus BW-16D1X-U one.
So it looks like the BDR-211UBK on official 1.54 firmware is a lot more picky about USB-SATA chipsets than the BDR-212UBK on the official 1.05 firmware.
Why? Pioneer only knows. But at least now I can use the BDR-211UBK externally. Thank you for this suggestion!
Last edited by audiotechnica on Thu May 07, 2026 12:18 am, edited 1 time in total.
