Hi!
I am new here.
And i wonder if there is a way to flash PIONEER BDR-209.
It's an external drive from Asus. I can't get it to work with any 4K UHD movie. It says no disc inserted.
Is it possible to maybe flash it?
Can it still rip from regular Blu-Ray discs after a flash?
Following information below are from MakeMkv software:
OS device name: G:
Manufacturer: ASUS
Product: BW-12D1S-U
Revision: E401
Firmware date: 2013-09-10
Highest AACS version: 21
Drive platform: RS8600
Firmware version: E401/ID44
PIONEER BDR-209 UHD 4K support(flash?)
Re: PIONEER BDR-209 UHD 4K support(flash?)
Yeah email me see below
I believe I have the same unit, the Pioneer BDR-209DBK, and I wanted to ask if it can also be modified to burn 4K discs. If so, will it still be able to burn regular BD discs as well?
Thank you
Thank you
Post your Makemkv info and I will send the flasher. Burning will be still supported.MrNobody wrote: Thu Apr 16, 2026 3:42 pm I believe I have the same unit, the Pioneer BDR-209DBK, and I wanted to ask if it can also be modified to burn 4K discs. If so, will it still be able to burn regular BD discs as well?
Thank you
PM sent.HomeKino1337 wrote: Tue Nov 26, 2024 4:37 pm Hi!
I am new here.
OS device name: G:
Manufacturer: ASUS
Product: BW-12D1S-U
Revision: E401
Ostermosmergoll
I also have the Pioneer BDR 209, could I also get the flasher?
Thank youOS-Gerätename: D:
Produzent: PIONEER
Produkt: BD-RW BDR-209D
Revision: 1.30
Serienummer:
Firmware-Datum: 2014-12-05
Markierungen der Bus-Verschlüsselung: 13
Highest AACS version: 82
Firmware version: 1.30/ID61
yes email me that drive info see below for emailOstermosmergoll wrote: Fri Apr 17, 2026 1:56 pm Hi,
Produzent: PIONEER
Revision: 1.30
Serienummer:
PM sent.Ostermosmergoll wrote: Fri Apr 17, 2026 1:56 pm Hi,
Produzent: PIONEER
Revision: 1.30
Serienummer:
i just found the same unit in my stash, i would love to get the flasher.
Laufwerksinformation
OS-Gerätename: D:
Produzent: PIONEER
Produkt: BD-RW BDR-209M
Revision: 8.11
Serienummer: QGDL132068WL
Firmware-Datum: 2014-01-16
Firmware version: 8.11/ID52
Thank you.
OS-Gerätename: D:
Produzent: PIONEER
Revision: 8.11
Thank you.
