AACS dump file Ninth Gate
Ninth Gate Special edition released from Lionsgate.com
- MKB20_v82_The_Ninth_Gate_5C60.tgz
- (3.35 MiB) Downloaded 29 times
commandrbond
Re: AACS dump file Ninth Gate
Has anybody else been able to rip this? I get a bunch of AV sync issues and it just gets stuck at Output Size: 536.0 M. I've let it run for over an hour each time and it doesn't go anywhere. Never seen this happen before.
I can't get it to rip too. I've tried both drives I own. Gets about 1/10th done and will keep going with no progress for nearly an hour before I close it.
I was able to get this ripped. I was experiencing the same issue where it stopped (for me) ad 581MB ripped for the main title on the UHD disc.
What worked for me was to run a backup on the disc. Once that was done, the behavior repeated when I tried to rip the main title from the backup. However, after maybe 3-5 minutes, it continued ripping and completed without difficulty. The resulting MKV looks good, not seeing any issues.
Hope this helps.
Drive is BD-RE PIONEER BD-RW BDR-S12JX 1.01 if it matters.
Hope this helps.
commandrbond
That worked! Thank you!ds1972 wrote: ↑Mon Apr 27, 2026 5:08 amI was able to get this ripped. I was experiencing the same issue where it stopped (for me) ad 581MB ripped for the main title on the UHD disc.
Hope this helps.
Fantastic, glad it worked for you!
How were you able to "back up" the disc? I don't see any option to do a full-disc backup in MakeMKV (I'm on Linux).ds1972 wrote: ↑Mon Apr 27, 2026 5:08 amI was able to get this ripped. I was experiencing the same issue where it stopped (for me) ad 581MB ripped for the main title on the UHD disc.
Hope this helps.
Just an FYI, based on what you said I figured maybe it worked after the dump because reading from a HDD/SDD is a lot faster than reading from a disc. Based on that hunch, I gave a rip of the movie direct from disc another shot. Last time I let it go about 1h10min before realizing it was stuck and stopped it. If only I'd let it go another 10 minutes haha.. at about 1h20min the disc started ripping beyond that 581MB spot that it was "stuck". It was slower ripping, but kept going. The disc did end up fully ripping successfully. It just took a long time: 4h40min to be exact. But it worked, so moving on!ds1972 wrote: ↑Mon Apr 27, 2026 5:08 amI was able to get this ripped. I was experiencing the same issue where it stopped (for me) ad 581MB ripped for the main title on the UHD disc.
Hope this helps.
That makes perfect sense. As for backing it up, when you first mount the disc in MakeMKV (NOT read it), you should have an icon at the top that's a folder with a green arrow. That's the backup option.aostang wrote: ↑Thu Apr 30, 2026 11:49 pmJust an FYI, based on what you said I figured maybe it worked after the dump because reading from a HDD/SDD is a lot faster than reading from a disc. Based on that hunch, I gave a rip of the movie direct from disc another shot. Last time I let it go about 1h10min before realizing it was stuck and stopped it. If only I'd let it go another 10 minutes haha.. at about 1h20min the disc started ripping beyond that 581MB spot that it was "stuck". It was slower ripping, but kept going. The disc did end up fully ripping successfully. It just took a long time: 4h40min to be exact. But it worked, so moving on!
