Lilspartan
Post by Lilspartan »
Hi, I'm trying to flash my BU40N but getting "No drive tool logic found in SDF.bin" on both Windows and Linux with the latest sdf.bin from makemkv.com.
Drive info:
Drive: HL-DT-ST BD-RE BU40N
Firmware version: FR07
Firmware date: 2118-01-22 15:36
Platform: MT1959
Bus encryption flags: 1F
Highest AACS version: 72
Serial: 808HS043042
What I've tried:
Latest sdf.bin from makemkv.com
sdf_000000a5.bin extracted from appdata.tar
Both Windows (makemkvcon64.exe) and NixOS Linux (makemkvcon)
Firmware file: HL-DT-ST-BD-RE_BU40N-FR07-JM02202-211801221536.bin from the 2020 firmware pack
Is the FR07 variant supported? Is there an updated SDF.bin or alternative method I can try?
nicholfd
Post by nicholfd »
Lilspartan wrote:
Sun Apr 26, 2026 5:09 am
Drive info:
Platform: MT1959
Serial: 808HS043042
What I've tried:
If using Windows, why not use the SDFtool at the start of this thread? Install latest/current MakeMKV in the standard location, make sure it has internet access & launch it once, connect the drive & launch the tool. Select the drive, select the firmware & click Start. No need to mess with "SDF.bin" - it just uses what the MakeMKV app downloaded, and for the BU40N, I suspect that hasn't changed in a long time.
adradr
Post by adradr »
nicholfd wrote:
Sat Apr 25, 2026 10:18 pm
No need to downgrade or use an old version of MakeMKV on macOS.
Ah, I see now, the downgrade is only necessary for linux. I misread that as Mac/linux:
Mac/linux commands to flash. the latest working version is 1.17.7 of makemkv for flashing do not use an newer version for flashing until further notice on linux
That drive has encrypted firmware. You need to use the encryption option ("enc" I believe - check the instructions).
Good to know, I hadn't seen it in the list so wasn't sure about that.
It might be cool if the
makemkvcon info
command could include information about whether a drive has encrypted firmware or not.
I'm certainly grateful for the quick response from Billycar11 and you, Frank, but I wonder if it might be a good thing to help newbies fall into the pit of success.
Is the utility open source by chance?
At any rate, everything looks good to me after using the correct command :D So thanks all!
./makemkvcon f -d '/IOBDServices/B16D63D6' -f /tmp/sdf.bin rawflash enc -i '/tmp/HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin'
Firmware version: 1.02
nicholfd
Post by nicholfd »
adradr wrote:
Sun Apr 26, 2026 3:18 pm
makemkvcon info
makemkvcon is the command line part of MakeMKV - not open source.
Fragpuss
Post by Fragpuss »
Hi. It's my first time flashing a drive and i have a few questions
i have a HL-DT BD-RE BU40N 1.05 UHD drive in an Icybox enclosure, the drive platform says MT1959, SDFTool Flasher for my drive has encrypted firmware ticked aswell as MT1959 Platform.
Am i still able to flash it to allow reading of discs in makemkv?
Fragpuss wrote:
Fri May 01, 2026 3:41 am
Yes. Flash it to BU40N 1.03-MK for UHD compatibility and to remoe the firmware encryption. You can now use it as is with MakeMKV and Xreveal but if you use Linux or other UHD ripping software, you should then flash it to BU40N 1.00.
babayaga
Post by babayaga »
Hi! I need to ask, i see so many use sata->usb converters for flashing, are there issues flashing drives connecting the drive directly to the computer by sata?
babayaga wrote:
Fri May 01, 2026 11:00 pm
No.
the_alquemist
Post by the_alquemist »
Hi! I wanna join the UHD ripping club, can someone recommend me a drive (hopefully from amazon) available today and makeMKV setup for my linux system? Im considering containers too. I see lots of options but not so sure where to start :D
babayaga
Post by babayaga »
the_alquemist wrote:
Sat May 02, 2026 2:50 am
There are several factors, what's your budget, where in the world are you located? There are several people on this board selling drives, it has it's own thread, and all the drive they are selling are UHD compatible, the difference is if you have any particular feature except UHD that you need. The general rule is that pioneer drives are the most sought after for being stable and good in their performance, and then you have other drives like LG which is often used internally in other brands like Asus and verbatim (they also have pioneer internals sometimes), but to make this short, you should use some time and read around the forum to get an idea of what you want, people have different opinions on this, and this is not the correct thread asking about joining the club, it's about the process and help of flashing firmware for a drive someone already have.
nicholfd
Post by nicholfd »
Hello!
I have several models available for purchase, on-hand, pre-flashed & in the US. All work equally well with macOS, Linux & Windows.
See links to my "For sale" threads in my signature. Or send me an e-mail if you have questions or need more details - drives@nicholasfamilycentral.com.
Thanks,
Frank
CaptainHowdy
Post by CaptainHowdy »
Hi!
I was reading through this forum this afternoon and decided to pull out my old Pioneer BDR-212V.
I'm thinking that this might be able to be modified to handle 4K.
Here's the information that appeared on my MakeMKV screen.
OS device name: E:
Manufacturer: PIONEER
Product: BD-RW BDR-212V
Revision: 1.00
Serial number: ADDL009948WL
Firmware date: 2020-08-07
Bus encryption flags: 13
Highest AACS version: 43
Drive platform: RS8F00
Firmware version: 1.00/ID06
So, I have two questions....
1). Can this drive be modified? and,
2). How do I go about it?
Many thanks for any assistance.
Captain
CaptainHowdy wrote:
Tue May 05, 2026 8:22 pm
Hi!
OS device name: E:
Revision: 1.00
Captain
sure email me that info and all others email me no need to post your info here just reach out to me directly
see below for email
SnakeQueenMedusa
Post by SnakeQueenMedusa »
Hi guys! I'd like to be able to rip my 4k DVD's to my laptop, but I've read all this and the SDFtool Flasher forum post and still can't make heads or tails of it :'(
I have a Verbatim Ultra HD 4K External Slimline Blu-ray Writer and this is the information given on MakeMKV
OS device name: E:
Product: BD-RE BU40N
Revision: 1.05
Serial number: MO3P7IB0419
Highest AACS version: 77
Is it possible for this to be flashed? I literally just bought it (arrived today) and I had no idea I'd have to do any of this. I can return it and get something else if I have to. Hopefully someone gets back to me before the return period runs out!
Thanks in advance <3
danieboy
Post by danieboy »
Sorry to bother you, I have been off the site for a while as my drive was (or still is) unable to rip 4k disc. Is this still the case for as it seem to spin the disc then spit it out.:-
OS device name: F:
Product: BD-RW BDR-XS07
Revision: 1.03
Serial number: CIDL007703WL
Firmware date: 2023-01-06
Drive platform: RS8E20
Firmware version: 1.03
