nicholfd
Post by nicholfd » Sat Apr 25, 2026 10:18 pm
adradr wrote:
Sat Apr 25, 2026 8:44 pm
Hello all. Thought I'd post in this thread rather than opening a new one, but if it's preferred I post a standalone thread, I'd be happy to.
I am attempting to flash a Buffalo BRXL-16U3 on a Mac.
Product: BD-RE BH16NS58
Revision: 1.03
Firmware date: 2120-05-08 09:33
Bus encryption flags: 1F
I paid attention to the first post of this guide and downgraded my MakeMKV :wink: and downgraded my MakeMKV to 1.17.7 (I bought a license to satisfy the prompt that said I needed to. Afterwards the initial launch would say that the program failed, though it still started up alright).
I moved the
sdf.bin
file and the version of the firmware that my searches of the forum indicated I should use
HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin
to the /tmp directory and fired up the CLI to get the drive ID
$ cd /Applications/MakeMKV.app/Contents/MacOS
$ ./makemkvcon f -l
After that I ran the full command:
./makemkvcon f -d '/IOBDServices/B16D63D6' -f /tmp/sdf.bin rawflash main -i '/tmp/HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin'
Which completed with a "Done successfully"
Then I reinstalled the latest version of MakeMKV (because of the fatal error bug) and unplugged the drive and plugged it back in. But the firmware remains the original version.'
Happy to try again or take a new tack. Can I just use 1.18.3?
No need to downgrade or use an old version of MakeMKV on macOS. It's great that you bought a license of MakeMKV - need to support those who support our hobby. I'm not aware of any requirement to buy a license to use the tool, as long as you have a current/non-expired "beta" key.
That drive has encrypted firmware. You need to use the encryption option ("enc" I believe - check the instructions).
Thanks,
Frank
Lilspartan
Post by Lilspartan » Sun Apr 26, 2026 5:09 am
Hi, I'm trying to flash my BU40N but getting "No drive tool logic found in SDF.bin" on both Windows and Linux with the latest sdf.bin from makemkv.com.
Drive info:
Drive: HL-DT-ST BD-RE BU40N
Firmware version: FR07
Firmware date: 2118-01-22 15:36
Platform: MT1959
Highest AACS version: 72
Serial: 808HS043042
What I've tried:
Latest sdf.bin from makemkv.com
sdf_000000a5.bin extracted from appdata.tar
Both Windows (makemkvcon64.exe) and NixOS Linux (makemkvcon)
Firmware file: HL-DT-ST-BD-RE_BU40N-FR07-JM02202-211801221536.bin from the 2020 firmware pack
Is the FR07 variant supported? Is there an updated SDF.bin or alternative method I can try?
nicholfd
Post by nicholfd » Sun Apr 26, 2026 1:58 pm
Drive info:
Platform: MT1959
Serial: 808HS043042
What I've tried:
If using Windows, why not use the SDFtool at the start of this thread? Install latest/current MakeMKV in the standard location, make sure it has internet access & launch it once, connect the drive & launch the tool. Select the drive, select the firmware & click Start. No need to mess with "SDF.bin" - it just uses what the MakeMKV app downloaded, and for the BU40N, I suspect that hasn't changed in a long time.
adradr
Post by adradr » Sun Apr 26, 2026 3:18 pm
Ah, I see now, the downgrade is only necessary for linux. I misread that as Mac/linux:
Mac/linux commands to flash. the latest working version is 1.17.7 of makemkv for flashing do not use an newer version for flashing until further notice on linux
Good to know, I hadn't seen it in the list so wasn't sure about that.
It might be cool if the
makemkvcon info
command could include information about whether a drive has encrypted firmware or not.
I'm certainly grateful for the quick response from Billycar11 and you, Frank, but I wonder if it might be a good thing to help newbies fall into the pit of success.
Is the utility open source by chance?
At any rate, everything looks good to me after using the correct command :D So thanks all!
./makemkvcon f -d '/IOBDServices/B16D63D6' -f /tmp/sdf.bin rawflash enc -i '/tmp/HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin'
Firmware version: 1.02
nicholfd
Post by nicholfd » Sun Apr 26, 2026 9:03 pm
makemkvcon info
makemkvcon is the command line part of MakeMKV - not open source.
Fragpuss
Post by Fragpuss » Fri May 01, 2026 3:41 am
Hi. It's my first time flashing a drive and i have a few questions
i have a HL-DT BD-RE BU40N 1.05 UHD drive in an Icybox enclosure, the drive platform says MT1959, SDFTool Flasher for my drive has encrypted firmware ticked aswell as MT1959 Platform.
Am i still able to flash it to allow reading of discs in makemkv?
Post by MartyMcNuts » Fri May 01, 2026 10:25 pm
Yes. Flash it to BU40N 1.03-MK for UHD compatibility and to remoe the firmware encryption. You can now use it as is with MakeMKV and Xreveal but if you use Linux or other UHD ripping software, you should then flash it to BU40N 1.00.
babayaga
Post by babayaga » Fri May 01, 2026 11:00 pm
Hi! I need to ask, i see so many use sata->usb converters for flashing, are there issues flashing drives connecting the drive directly to the computer by sata?
Post by MartyMcNuts » Sat May 02, 2026 12:43 am
No.
the_alquemist
Post by the_alquemist » Sat May 02, 2026 2:50 am
Hi! I wanna join the UHD ripping club, can someone recommend me a drive (hopefully from amazon) available today and makeMKV setup for my linux system? Im considering containers too. I see lots of options but not so sure where to start :D
babayaga
Post by babayaga » Tue May 05, 2026 4:47 pm
There are several factors, what's your budget, where in the world are you located? There are several people on this board selling drives, it has it's own thread, and all the drive they are selling are UHD compatible, the difference is if you have any particular feature except UHD that you need. The general rule is that pioneer drives are the most sought after for being stable and good in their performance, and then you have other drives like LG which is often used internally in other brands like Asus and verbatim (they also have pioneer internals sometimes), but to make this short, you should use some time and read around the forum to get an idea of what you want, people have different opinions on this, and this is not the correct thread asking about joining the club, it's about the process and help of flashing firmware for a drive someone already have.
nicholfd
Post by nicholfd » Tue May 05, 2026 5:22 pm
Hello!
I have several models available for purchase, on-hand, pre-flashed & in the US. All work equally well with macOS, Linux & Windows.
See links to my "For sale" threads in my signature. Or send me an e-mail if you have questions or need more details - drives@nicholasfamilycentral.com.
Thanks,
Frank
CaptainHowdy
Post by CaptainHowdy » Tue May 05, 2026 8:22 pm
Hi!
I was reading through this forum this afternoon and decided to pull out my old Pioneer BDR-212V.
I'm thinking that this might be able to be modified to handle 4K.
Here's the information that appeared on my MakeMKV screen.
OS device name: E:
Manufacturer: PIONEER
Product: BD-RW BDR-212V
Revision: 1.00
Serial number: ADDL009948WL
Firmware date: 2020-08-07
Bus encryption flags: 13
Highest AACS version: 43
Drive platform: RS8F00
Firmware version: 1.00/ID06
So, I have two questions....
1). Can this drive be modified? and,
2). How do I go about it?
Many thanks for any assistance.
Captain
Post by Billycar11 » Wed May 06, 2026 1:18 am
Hi!
OS device name: E:
Revision: 1.00
Captain
sure email me that info and all others email me no need to post your info here just reach out to me directly
see below for email
SnakeQueenMedusa
Post by SnakeQueenMedusa » Thu May 07, 2026 5:50 pm
Hi guys! I'd like to be able to rip my 4k DVD's to my laptop, but I've read all this and the SDFtool Flasher forum post and still can't make heads or tails of it :'(
I have a Verbatim Ultra HD 4K External Slimline Blu-ray Writer and this is the information given on MakeMKV
OS device name: E:
Product: BD-RE BU40N
Revision: 1.05
Serial number: MO3P7IB0419
Highest AACS version: 77
Is it possible for this to be flashed? I literally just bought it (arrived today) and I had no idea I'd have to do any of this. I can return it and get something else if I have to. Hopefully someone gets back to me before the return period runs out!
Thanks in advance <3
