Issues With Verbatim 43888
Sayaka
Re: Issues With Verbatim 43888
Post by Sayaka »
I will let someone more experienced than me check the log (it looks like you've got a download error as well ?), but I will say that as far as I know the KEYDB.cfg file (which is supposed to be placed inside the MakeMKV config folder, as you probably already know) does have a key for the 4K version of Pride and Prejudice. Whether that key works with every 4K disc that was ever created for this movie, I have no idea.
I would advise not doing anything with your firmware until someone with lots of experience flashing Pioneer drives answers that particular question. (Although after doing some research on the forum on that particular topic, I would say the answer is most likely that you *shouldn't* do anything with it.)
Thought maybe the key is not yet in the database, so I fired up FindVUK 1.83 but it seems DVDfab can't read my disc.
As far as I know, DVDFab, and most likely Passkey and therefore FindVUK as well, aren't UHD/4K compatible with Pioneer drives.
Kodahond
Post by Kodahond »
Sayaka wrote: Thu Apr 30, 2026 8:51 pm I will let someone more experienced than me check the log (it looks like you've got a download error as well ?), but I will say that as far as I know the KEYDB.cfg file (which is supposed to be placed inside the MakeMKV config folder, as you probably already know) does have a key for the 4K version of Pride and Prejudice. Whether that key works with every 4K disc that was ever created for this movie, I have no idea.
Thanks for the answer :)
Had to update my database with the help of KeyDB helper before it started working, so I must have missed something before.
But happy to say that the movie is now fully ripped :)
Kodahond wrote: Sun May 03, 2026 7:56 am
Your log shows that internet access for Makemkv is not enabled or blocked. Therefore you could not rip the disc without the help of KeyDB.
