Burning M-Disc DVD's with Pioneer BDR-209MBK?
opticalsupremacy
#1 Post by opticalsupremacy » Sun Apr 26, 2026 4:08 pm
I have a BW-16D1X-U External 16X Blu-ray Writer with a pioneer BDR-209MBK inside. The firmware is as follows:
OS device name: I:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Firmware date: 2020-07-21
Highest AACS version: 82
Drive platform: RS8F00
Firmware version: E113/ID76
I use this drive for making BD-R backups and occasionally for ripping. I also have a few Ritek DVD M-disc's that I'd like to burn.
While the 209MBK is a solid burner, I found out that it doesn't list the M-disc DVD as a supported media type . For context, M-Disc Blu-rays are writable by virtually any blu-ray writer, but an M-disc DVD needs a specialized writing strategy that is only available on certain dvd and blu-ray drives, mostly LG and ASUS drives. Most pioneer's don't appear to have support for them.
However, since my drive has a firmware named BDR-212T, and BDR-212 drives like the BDR-212UBK are compatible with M-disc DVD's (MID: MILLENIA001), does that mean my BDR-209MBK has the same write strategies as a BDR-212 drive, and is therefore able to write to M-disc DVD's properly?
The box the drive came in does reference M-disc DVD's in the max write speed's section as "DVD+R(SL, M-disc) 4x", but I'm wondering if this might be referring to the internal ASUS drive (ASUS BW-16D1HT) that sometimes ships with this enclosure, instead of the pioneer. There is also a disclaimer at the bottom saying "*product specifications are subject to change".
Thanks for any help, as the information is very scant on this niche medium.
Re: Burning M-Disc DVD's with Pioneer BDR-209MBK?
#2 Post by Billycar11 » Mon Apr 27, 2026 1:30 am
your drive is a 212
for some reason asus rebranded it as a 209
it likely does support the dvd m disc but if you want to be 100% sure we can flash your drive to a s12 and it will also do 4K UHD discs then if you want it to
opticalsupremacy
#3 Post by opticalsupremacy » Mon Apr 27, 2026 5:58 am
Billycar11 wrote: Mon Apr 27, 2026 1:30 am your drive is a 212
When I opened the enclosure, it clearly had it labelled as BDR-209MBK, MFD. September 2024. Are you saying that it uses the exact same hardware/firmware as a BDR-212, but is labelled as 209? Do you know this because of the platform module being RS8F00?
Thank you.
#4 Post by Billycar11 » Mon Apr 27, 2026 1:50 pm
opticalsupremacy wrote: Mon Apr 27, 2026 5:58 am
Thank you.
yes 8f00 is 212 platform and it says 212 in the fw
please lets do this through email as the forum has been really slow for days
opticalsupremacy
#5 Post by opticalsupremacy » Wed Apr 29, 2026 10:28 am
Thank you, that's excellent news! The drive is more capable than I thought. I will hold off on your flashing service for now, but will email if I need it.
