Pioneer BDR-X13 (The actual drive is a BDR-213M)
Xandros
Post by Xandros » Sun Apr 26, 2026 3:47 pm
I have a Pioneer BDR-X13 external USB enlcousre, although the actual drive inside it is a BDR-213M according to the label, it has Firmware 1.03 on it which I knew was the crippled & encrypted FM. I did search for info on this and found a few posts recently about it but got a bit confused on some things, so would just like to check specifically; is this drive now flashable so it can read/rip UHD movie discs or is it still a no-go? Thanks!
Here's the info from MakeMKV:
OS device name: F:
Manufacturer: PIONEER
Product: BD-RW BDR-X13
Revision: 1.03
Serial number: CGDL000353WL
Firmware date: 2022-12-12
Highest AACS version: 77
Drive platform: RS9400
Firmware name: PIONEER BDR-213T
Firmware version: 1.03/ID56
Re: Pioneer BDR-X13 (The actual drive is a BDR-213M)
Post by Billycar11 » Mon Apr 27, 2026 1:32 am
Xandros wrote: Sun Apr 26, 2026 3:47 pm I have a Pioneer BDR-X13 external USB enlcousre, although the actual drive inside it is a BDR-213M according to the label, it has Firmware 1.03 on it which I knew was the crippled & encrypted FM. I did search for info on this and found a few posts recently about it but got a bit confused on some things, so would just like to check specifically; is this drive now flashable so it can read/rip UHD movie discs or is it still a no-go? Thanks!
OS device name: F:
Revision: 1.03
i can flash that drive to do 4K UHD email me see below i can give you early access to the cross flasher for 12/22+ drives
Xandros
Post by Xandros » Tue Apr 28, 2026 11:34 am
